Brad, my opinion is that issues with lenses, more often than not, are focus related. On rare occasion, there will be a high quality lens that is actually soft. Much more frequently, the issue is focus calibration (back focus or front focus). You state that you have ruled out focus as the issue in your test, which I believe is incorrect. That first shot, of the ornament is not focused correctly by the macro lens, whether by fault of the lens, or by user error. Remember that the focus sensors in the camera are bigger than the focus screen box, and not always perfectly aligned. At this range, you should be able to see when the object is sharply focused in the viewfinder. Did it look sharp before you took that shot? If it does not look sharp in the viewfinder, you need to adjust the camera until you know for sure that the AF is locking on the contrast edge that you want it to lock on.
It strikes me also that it may be difficult to get square to a hanging ornament on a tree, which could move. The close up shots at f/8 are really not necessary, because the larger DOF alone will make the image sharper if it not focused sharply to begin with. My guess is, your lenses are fine, but there are lots of variables in your test. Take a look at the 9 volt battery test in the thread entitled "frontfocus". That test, if square to the target, tells you quickly and accurately if you have a focus issue. You only need to do this test at f/2.8. Many people do this test with the batteries too far apart, which can mask smaller calibration errors.
Then, go around outside with your tripod and macro lens and shoot some static objects. Are they sharply focused? Remember that you will rarely use the Macro at f/2.8 for macro objects due to the extremely thin DOF. Also, you may find that your zoom is better at f/4 & f/5.6 than at f/8.
