The Sigma will have elements to help correct for the barrel distortion. The fisheye does not have this so straight lines will curve causing a bubble-like appearance. Even though both are 15mm, they will give very different results. With either lens, you will need to be literally right next to the person for them to be big in the frame. If you're more than a yard or two so away from them, they will appear tiny in the photo.
Answer 1) The Sigma can go wide, but the 15mm fisheye is wider still. The Sigma is a normal (or rectilinear) lens, meaning that straight lines remain straight. A fisheye allows lines to bend as they approach the edge of frame, but circles remain circles. Both serve a photographic purpose. Other differences include size, cost, light fall-off.
Answer 2) I own the Canon. Word around town says the Sigma has considerable sample variation (nothing new there), but if you get a good copy, the image seems better. Big price diff, too.
I own the sigma 15-30 and the Canon 2.8/15 mm Fish. The problem of all fisheyes are their distortion, which can be corrected with programs like Lensdoc for example.
The picture quality of the Canon fish is very good (we've testet it against the 17-40L, it is on par), clearly better then the Sigma 15-30, and even on the 10D one keep a angel of 114°, much more then the Sigma with its 15 mm. On the link you will find some samples of the fish.
Instead of the sigma 15-30, which I used before, I now use 2 primes in combination: the fish and the even exellent Canon 2.8/24. Both are small, handy lenses. http://www.digitale-slr.net/foren/canon/session_index.php?cat=2&startrec=50,
select "Neues vom Fish"
As has been pointed out already, because the fisheye isn't rectalinear, it does not conform to the same rules in terms of the relationship of focal length to actual angle of view. Among other things, a "defished" fisheye image isn't actually 3:2 . The 15mm fisheye, on a 1.6x crop factor camera (ie. 10D, etc) produces an image that, after de-fishing in software, has the horizontal field of view about equivalent to a 19mm lens on a standard SLR, and a vertical field of view of about a 22mm lens on a standard SLR. In contrast, at 15mm, a rectalinear lens on a 1.6x crop camera will give you both horizontal and vertical field of views equal to a 24mm lens on a standard SLR.
Hope that helps I really like my Canon 15mm f/2.8 fisheye, though I've not had the chance to do a lot with it yet. I'm hoping to use it in the near future for some panoramics and such.
Rico, I can't count the number of times I have referred people to your fisheye article. Well done and thanks from me and them.
ppwj, Ben is right about how close you have to be with the fisheye, and for that matter with any extreme wide angle, to capture a sense of action.
De-fishing with something like Panotools is said to be quite easy, but I have not yet felt the need to do it. I like the way the images look right out of the camera. Here are two examples.
In this one I could have easily reached out and touched the catcher on the head from where I was standing:
Hope that helps I really like my Canon 15mm f/2.8 fisheye, though I've not had the chance to do a lot with it yet. I'm hoping to use it in the near future for some panoramics and such. ...Show more →
Actually, after doing some measurements with my corrected fisheye images cropped to 3:2, I determined the corrected fisheye image was about equivalent to that of a 12.5mm rectilinear wideangle lens. These were done full frame. Of course I was using fairly crude methods by optical standards to measure the resultant AOV of my image, but did also compare it to some older images shot with a 15mm rectilinear lens, so I am fairly confident of my result.
Just for fun, I timed myself while remapping Nill's second FE shot. It took me less than a minute to steal it, put it in PS, correct it and save it to my desktop as you see it here. Nill and I have had this discussion before, and we both agree the original FE image is perhaps more interesting, but this points out how it looks when corrected.
With this image, I took a more painstaking approach to conversion, which yields a slightly wider and sharper image. But as pointed out earlier, note what happens to the round lights when they are rectilinearized near the edge of a frame. Again, I think the original is a far more interesting image, but post this for comparison purposes. (And special thanks to Nill for letting me rip off his images )
Any thoughts about the Sigma 8mm fisheye? That isn't something that could be anything but a novelty straight out of the camera, but would the required cropping of a de-fished photo loose too much of the value of the ultra-wide angle? (12.8mm less a little more for cropping on a 10D) I'm looking to get one for spherical panos, but thought to use it for uwa once defished.
WTLLOYD: I've never tried one out. Panotools has a routine to turn spherical FE images into rectilinear ones, but I am suspect of the quality of the final image as it seems it would require a huge remap to get everythng straight. If you can get me a circular FE image, I would be happy to try and adjust it and see what we get.
Frances: You need to first get the Panotools plug-in for PS. It's free if you can find a mirror site to download it from. There are several ways to correct an image with this program, but the easiest is to run the fisheye to rectilinear remap routine. Try: http://www.path.unimelb.edu.au/~dersch/
Yes I have Panotools...........but in less than a minute...GEEEE!
I'll try rectilinear remap routine, thanks again.
Ha, I'm actually looking at the exact same thing right now. A Sigma 15mm fisheye for use in an EWA waterproof housing for wakeboarding. With a little modification, it should work well.
).............I'm going for the sigma also.........which Ewa are you referring to?
Hi, Nill! Glad to see you here. When it comes to the EF 15mm, I think we see fisheye-to-fisheye!
Jack, thanks for the defished samples of Nill's pics. For architectural verisimilitude (other than Gaudi), the fisheye needs remapping, but people are badly deformed. Here are cropped comparisons of Nill's originals (top row), and your remappings (bottom row): http://patternassociates.com/rico/d30/misc/ntoulme1.jpg
First soccer player, being nearly centered, is fine. Second soccer player is partly off-center, and showing distress. Third frame is from the baseball games, left edge, and the "weight gain" is pretty frightening!
wtlloyd, the 8mm clearly suffers from the 1.6x crop: http://patternassociates.com/rico/d30/misc/10D8mm.gif
There's enough info on the left and right to attempt the impossible: 180° AOV rectilinear, or 0mm focal length! You'll crop the 8mm after defishing for that reason, because of poor optical quality at the edge, and because the pixels are seriously overextended. Other than that, I like some posted results. The FF is still the preferred article.
