p.1 #1Why are the used A7CII and A7CR not $500 cheaper?
I can't seem to see why the A7CII and A7CR are the same used price as the A7RIV and A7RV? I like the idea of a smaller body but if you put a Sony 35mm GM on it will you notice?
p.1 #2Why are the used A7CII and A7CR not $500 cheaper?
They are basically the same tech with the smaller cameras having compromises for their size and the bigger cameras have compromises for their bigger and heavier size.
If you plan on using the bigger GM lenses, then just get the larger cameras. Many buy the compact camera to use with compact lenses.
p.1 #3Why are the used A7CII and A7CR not $500 cheaper?
I am scratching my head too. I am just guessing, maybe a lot more A7RVs were sold than A7CRs, therefore, there are a lot more used A7RVs available, putting downward pressure on the price. Or maybe A7CR owners love their CR so much that they don't want to sell!😂
p.1 #4Why are the used A7CII and A7CR not $500 cheaper?
They are current generation cameras, and in the case of the a7CR it's actually first generation.
I also imagine supply of used cameras is dfferent, as others have noted.
