Pulsar Helion XP28 640 Thermal Monocular – 22° Wide FOV, 3 Batteries
Available 1 following
Price$2,000.00
PayPal
Selling probably the best thermal out there for finding wildlife for photography. Nearly every 640 thermal on the market now uses a 35–50 mm lens, which gives about 12–15° of view. The XP28’s 28 mm lens gives 22°, so you see about 117 ft of treeline at 100 yd instead of 65–77 ft. That’s the reason I’ve used this unit to find owls for years.
Specs:
640×480 @ 17 µm sensor, 50 Hz
28 mm f/1.2 lens
1.4–11.2× zoom (2×/4×/8× digital)
22° × 16.6° FOV
~1,100 yd detection, deer-size
AMOLED display
8 GB built-in video/photo recording
Wi-Fi with the Stream Vision app
IPX7 waterproof
Included:
Helion XP28 (77403)
1 Pulsar IPS14 battery pack (12,800 mAh), brand new, good for about 21–26 hr on the Helion
2 Pulsar IPS7 battery packs (6,400 mAh), the original OEM batteries. They’re about 7 years old and hold noticeably less charge than new, so treat them as backups.
Pulsar carry case with shoulder strap
Hand strap
Lens cap
2 spare eyecups
USB wall charger and micro-USB cable
It works perfectly and shows normal cosmetic wear from field use. This model is discontinued and out of factory warranty, and it charges via micro-USB, not USB-C.
$2,000 net to me takes it. I'll cover shipping and insurance in the CONUS.
