FPS Reduction when using autofocus
Graham_216
p.1 #1FPS Reduction when using autofocus
I have a Sony A9 II, and I recently updated it from the 2.00 firmware to 3.20. After updating it, I noticed that when I have a third-party lens attached and turn the autofocus on while in AF-C, the frame rate drops noticeably. Here's a video showing the issue: https://youtu.be/Mq4m9KHX5CU?si=yKaTmHHQpQqI3bIT]
The frame rate drops only when in Continuous Autofocus; when in Single, DMF, or Manual Focus, the frame rate stays the same.
I have also set my AF-C priority to release rather than AF, and am still having this issue. Does anyone know how to fix this, or is this just normal behavior?
Nov 02, 2026 at 06:15 PM
Choderboy
Details
p.1 #2FPS Reduction when using autofocus
It is normal for 15 FPS for third party lenses on Sony.
Nov 02, 2026 at 07:13 PM
GraysonLake1987
Details
p.1 #3FPS Reduction when using autofocus
That's how 3rd party lenses works on Sony bodies. It's one of the 3rd party limitations.
Nov 02, 2026 at 07:55 PM
Graham_216
Details
p.1 #4FPS Reduction when using autofocus
Okay, I appreciate it. I knew they limited the FPS, but I didn't realize it only applied while autofocusing.
Nov 02, 2026 at 08:47 PM
Switch to mobile view
