Acratech Leveling Base
Price$100.00
PayPal
The Acratech Leveling Base is used between your tripod and your ballhead, tripod head, panorama head or video head. It quickly and easily levels the bottom of your head to produce accurate and properly aligned images for panoramas, landscape or architectural photography. Price is net to me.
It is sturdy, lightweight and weighs only 1/2 lb. (.24kg) Available for both 3/8-16 (most common) and 1/4-20 tripod heads. If you are not sure what size tripod stud you have, watch the short video below.
Top Diameter 2.375” (60mm)
Base Diameter 2.375” (60mm)
Weighs 1/2 lb. (.24kg)
Easily holds over 25 lbs. (11.4 kg)
Allows 15 degrees of movement in any direction
Fits all standard tripods (3/8-16 threads)
Fits all standard 3/8-16 tripod heads
Oil free and greaseless ball will not attract or hold dirt and debris
Precision bullseye level for accurate positioning
Low profile design, only 1.77" tall (not including stud)
