p.1 #1Infrared on Sony - anyone doing it these days?
Happened across some IR images I shot several years ago on a full-spectrum a6000, and it inspired me to try it again. So...my old a7R is on its way to LifePixel for a 590nm conversion (I wasn't a fan of having to use filters with the full-spectrum body, and the 590nm images were my favorites).
Looking forward to playing with it soon.
Anyone else here shooting IR on a Sony body?
Meanwhile, here's a couple old shots...
ILCE-6000FE 16-35mm F4 ZA OSS lens20mmf/9.01/320s200 ISO+1.0 EV
ILCE-6000E 25mm F2 lens25mmf/9.01/160s100 ISO+0.7 EV
p.1 #2Infrared on Sony - anyone doing it these days?
I have the exact same plans. I have an old A7r that has served me well, but I don’t use it anymore. I have shot IR with an old canon dslr that was converted, but don’t really have any canon lenses for it anymore. The A7r would be a great camera for ir.
p.1 #4Infrared on Sony - anyone doing it these days?
I did. I enjoyed my 830nm A7VIII so much that I had an A7RIV converted, disaster with the banding in the sky, just the nature of Sony PDAF. The higher the resolution, the darker the conversion, the more visible the banding shows. I bought a Canon R5 specifically for 830 nm conversion because they don't use PDAF.
p.1 #6Infrared on Sony - anyone doing it these days?
I've considered it, also considered doing a dedicated mono conversion. Reality for me is I'm not sure how long before I got tired of the effect or even the effort to use it -- it's already about all I can manage to get out and shoot enough with my normal cameras...
If I did IR, I'd do Full Spectrum on an older body, probably something like an A7RV or better an A7Cr so it fit in my bag easier so it was there if/when I wanted it. Then I'd get the Kolari snap in body filters for true color, and then probably the 590 or 665 in order to do false-color as well as partial mono IR. But then as soon as I consider doing this, I think I'd actually use a true mono camera a lot more often, so start thinking in that direction. Note that mono can still do IR, just not false color. So here I'd probably get an 850 nm IR filter, again with appropriate internal, removable IRUV cut filter for normal mono. Then I look at the costs, and look at my converted color files and think, "why bother." But I get the appeal.
p.1 #11Infrared on Sony - anyone doing it these days?
Did you get the anti-reflective coating? I've just started researching this and I'm seeing conflicting information as whether it helps, does nothing, or makes things worse (with respect to hotspots).
I suppose the various services that do conversions might use different coatings which muddies the waters.
p.1 #12Infrared on Sony - anyone doing it these days?
I just got the standard stuff; wanted to keep the price as low as possible, as I’m not sure how much I’ll actually use it. We’ll see.
p.1 #15Infrared on Sony - anyone doing it these days?
There is some false colour with the A7r 720nm and the 16-35PZ, custom white balance is a must.
I find in colour hotspot may be there, but in mono it's better behaved
p.1 #16Infrared on Sony - anyone doing it these days?
I have always some sort of IR body in my set, ever since the Canon 20d. I currently have a full spectrum a7iii, with which I most frequently use an IR-Chrome filter on the lens. I shoot that mostly but occasionally shoot 590 or 720. I can pop in an OEM filter via the Kolari magnetic clip and instantly have a vis spectrum second body. I appreciate that flexibility.
In the Canon EOS system, its L lenses generally behaved well with IR. By contrast, most GM lenses have either a spot or “hot haze” in the center. The clip in Hot Spot Killer filter from Kolari does a pretty good job of mitigation. My go-to is the 24GM. The old Zeiss 16-40/4 OSS was good for hot spots but had fairly soft corners in IR. 16-35/2.8 GM II plays reasonably well with the hot spots killer filter, at least with IR-Chrome.
p.1 #17Infrared on Sony - anyone doing it these days?
My converted camera has shipped from LifePixel, so I'm starting to think about which of my lenses might work best/worst. Looking at the various online databases which document IR performance, it seems that none of them are updated any more; they only list older e-mount lenses.
Anyone have experience with any of these?:
Primes:
12mm ƒ5.6 Voigtlander
14mm ƒ4 Viltrox
24mm ƒ1.4 Sony GM
35mm ƒ1.4 Sony GM
50mm ƒ1.4 Sony GM
110mm ƒ2.5 Voigtlander
135mm ƒ2.8 Zeiss
Zooms:
28-60mm Sony
20-70mm Sony G
@Grenache - I see you're using the 24mm GM; that's good to know, as it's one of my favorites.
ChatGPT found some reports that the two Voigtlanders are goo.
p.1 #18Infrared on Sony - anyone doing it these days?
Primes:
14mm ƒ4 Viltrox
24mm ƒ1.4 Sony GM
35mm ƒ1.4 Sony GM
50mm ƒ1.4 Sony GM
135mm ƒ2.8 Zeiss
Zooms:
28-60mm Sony
20-70mm Sony G
@Grenache@ - I see you're using the 24mm GM; that's good to know, as it's one of my favorites.
Can't help you much on the GM's because I've only just got the 24 and 35.
