The most impressive Triplet lenses you've encountered
simplejoy
p.1 #1The most impressive Triplet lenses you've encountered
I'm very interested in old lenses and I've been thinking a lot about Triplet lenses recently... and while today they're perhaps mostly known for being basic or budget lenses, they've apparently been among the most expensive lenses when they first were released, very challenging to manufacture in good quality and advertised as superior in many aspects. And I've seen some incredible results taken with very old Triplets on large format cameras which makes me believe it wasn't just marketing...
So I've been wondering: Are there some Triplet (3/3) lenses out there which you still hold in high regards?
I've heard the Elmar 90 mm f/4 mentioned several times, when I've asked a similar question before... the Tair 3 has also been mentioned, the Takumar 105 mm f/2.8. The Carl Zeiss Triotar series was also brought up several times in different places, where I've looked into the matter. The Nikkor-T 10.5 cm f/4 got its own page by Nikon at its Thousand and One Nights series. Corfield made a Triplet lens labeled "Apo" for whatever that means... There are slightly longer lenses by Minolta, Asahi and Topcon. Of course almost any lens maker with a significant history has created its own attempt at a "Cooke lens". And of course everyone knows the Trioplan (though mainly for its bubble bokeh... even though its history is certainly more than that).
So I'm curious to know some of the Triplet lenses you've encountered and which have impressed you. I'll share some of the ones I have some experience with as well, even though I'm afraid, they won't be the most well-known ones.
Sep 03, 2026 at 05:19 PM
retrofocus
Details
p.1 #2The most impressive Triplet lenses you've encountered
The only triplet lens which I own to my limited knowledge is the mentioned Leitz 90/4.0 Elmar lens which I own as collapsible version. Mine is in nearly mint condition and works very well even on my digital M cameras. I admit that I googled the definition how triplet lenses are defined, and I found a good discussion thread on a different manual lens focused site which describes it and deviations from it. I assume you specifically refer to three single lens based lens arrays only? Or do you consider triplet lenses also when in one of the three lens groups have additional lenses attached to it?
Sep 04, 2026 at 06:56 AM
rico
Details
p.1 #3The most impressive Triplet lenses you've encountered
That 90mm is 4 elements. I own the collapsible, the rigid with same 4-element formula, and the late-era 3-element circa 1961 which was only rigid.
Sep 04, 2026 at 07:29 AM
fjablo
Details
p.1 #4The most impressive Triplet lenses you've encountered
Neither of them is a triplet. The Takumar 100mm f3.5 is a triplet.
The Meyer-Görlitz Trioplan 100mm f2.8 is quite popular and there's a much more affordable copy now with the TTartisan 100mm f2.8 Bubble Bokeh: https://phillipreeve.net/blog/review-ttartisan-100mm-f-2-8-a-modern-and-affordable-trioplan/
There is also a 50mm f2.9 Trioplan: https://phillipreeve.net/blog/review-meyer-optik-gorlitz-trioplan-50mm-f-2-9-v-soap-bubble-bokeh-treasure-or-garbage/
Sep 04, 2026 at 08:29 AM
retrofocus
Details
p.1 #5The most impressive Triplet lenses you've encountered
rico wrote:
retrofocus wroteThe only triplet lens which I own to my limited knowledge is the mentioned Leitz 90/4.0 Elmar lens which I own as collapsible version.
Thanks for correcting - then it seems I don't even have one at all !
Sep 04, 2026 at 09:24 AM
simplejoy
Details
p.1 #6The most impressive Triplet lenses you've encountered
Thanks for making sure!
Yes, exactly! I'm referring to the so-called "Taylor-Triplet" from 1893 with 3 elements in 3 groups (there were more variants in the initial patent, but this one had the most impact).
Lenses with more than 3 elements which were based on the Triplet are sometimes called "Triplet derivatives" which I find a good distinction, even though I'm aware that lenses with more than 3 elements were called Triplets as well in the earlier days of photography.
Sep 04, 2026 at 09:47 AM
simplejoy
Details
p.1 #7The most impressive Triplet lenses you've encountered
fjablo wrote:
simplejoy wrotethe Tair 3 has also been mentioned, the Takumar 105 mm f/2.8.
Thanks a lot for the clarification! Since I don't own any of these lenses, I didn't know. The person mentioning the Takumar could have been wrong on the version. The Tair-3 seems to be a 3 elements in 3 groups design, though it doesn't fully resemble a Taylor Triplet. I have no idea how that design is called though. Do you perhaps know?
(source: allphotolenses)
Thanks. Yes, of course I'm aware of the Trioplan and its remakes, as I've mentioned. I don't think they're uninteresting lenses, but far from the only relevant Triplets in my opinion.
Sep 04, 2026 at 10:15 AM
freaklikeme
Details
p.1 #8The most impressive Triplet lenses you've encountered
The only triplet I've spent a significant amount of time with is the Zeiss-Opton Triotar 85/4. It didn't blow me away with resolution, but my copy, at least, was pleasingly soft (good with the big definition, not much for details) regardless of aperture setting. I only used the post-war, coated version.
Sep 04, 2026 at 09:57 PM
simplejoy
Details
p.1 #9The most impressive Triplet lenses you've encountered
Thanks! I'm sure that's a solid lens, though perhaps somewhat limited by the f/4 speed. I'm sure however Zeiss had its reasons to keep it limited to that. As far as I know there were f/3.5 Triotars for the 35mm format, but I don't think any of them were faster than that. Only for 8/16 mm.
Do you have any sample shots taken with your Triotar online?
Sep 05, 2026 at 08:08 AM
James Markus
Details
p.1 #10The most impressive Triplet lenses you've encountered
...Show more →
Wollensak made a bunch of triplets. It would be problematic for 35mm in the longer focal lengths, but they made short focal lengths as well. Easily adaptable, and I have been surprised by the image quality. These are from my favorite one - the 162mm f4.5 - I use it on the Pentax 645Z and 645N
645Z-w_Wollensak_162mm-f4.5-EnlargingLens-6450341 by James Markus, on Flickr
645Z-w_Wollensak_162mm-f4.5-EnlargingLens-0258 by James Markus, on Flickr
Sep 05, 2026 at 09:40 AM
simplejoy
Details
p.1 #11The most impressive Triplet lenses you've encountered
Thanks! The shots look very good and it's of course possible (and likely) that Wollensak made some Triplets. But the Enlarging Raptars are 4/3 Tessar designs, as far as I know and all the sources, I've been able to find confirm that:
https://photocornucopia.com/1061.html
A series called "Tricor" Anastigmat are Triplets according to the Lens Vademecum... but it doesn't seem very common. That being said, it's of course possible that they made Triplets for enlarging as well, but I doubt it's any of the Raptar labeled ones.
Sep 05, 2026 at 09:54 AM
James Markus
Details
p.1 #12The most impressive Triplet lenses you've encountered
simplejoy wrote:
James Markus wroteWollensak made a bunch of triplets. It would be problematic for 35mm in the longer focal lengths, but they made short focal lengths as well. Easily adaptable, and I have been surprised by the image quality. These are from my favorite one - the 162mm f4.5 - I use it on the Pentax 645Z and 645N
https://www.simplejoy.at/wp-content/uploads/2026/09/wollensak_enlargingraptars.jpg
Sorry, My mistake. I have had the first two of that diagram completely apart, and couldn't see that the last two elements were cemented together. When I asked AI if Wollensak made triplet lenses it replied that "yes" it had, and in two varieties. When I asked again i inserted the word "enlarging" lenses - and that answer is "no" - as you already know.
I suspect I made the same mistake with this lens the Thornton Pickard-Beck Symmetrical Lens 11" from the 1910 era. I thought it was only two elements, but maybe I missed one? Btw - I like your work on your Flickr galleries
https://flic.kr/p/2ria6zB
Sep 05, 2026 at 11:10 AM
simplejoy
Details
p.1 #13The most impressive Triplet lenses you've encountered
Did the AI tell you which series that may be besides the "Tricor" Anastigmat?
EDIT: If it's hard to find the series names, nevermind... I just found that there might be more than 4 different Triplet series by Wollensak.
I don't know anything about that specific lens, but according to the Lens Vademecum it might be a "Rapid Rectilinear" design, so it would be 4 elements in 2 groups:
Thanks a lot!
Sep 05, 2026 at 01:42 PM
James Markus
Details
p.1 #14The most impressive Triplet lenses you've encountered
Here is the AI response
______________________________________________________________________________________________________
Query:"Did Wollensak make triplet lenses?"
Answer:
"Assuming you are referring to the Wollensak Optical Company (often misspelled phonetically as Wallin sack), yes, they did make triplet lenses. [1, 2]
Wollensak, a historic American manufacturer of photographic optics based in Rochester, New York, produced several famous lenses utilizing a Cooke triplet configuration (three distinct, spaced glass elements: a positive front, a negative middle, and a positive rear)
Wollensak Varium
This is one of their most famous specialized lenses. Introduced in 1926, it was a high-end, fast (f/3.5) portrait lens designed specifically around a Cooke-type triplet layout to compete with European portrait lenses
Wollensak Anastigmat
Wollensak produced smaller-format triplet lenses under the general "Anastigmat" or "Velostigmat" labels. For instance, the Wollensak 44mm f/3.2 Anastigmat lens (frequently found on vintage Bolsey 35mm cameras) was highly marketed as their signature version of a classic triplet. [1, 2]
Wollensak Raptar
While many Wollensak Raptar lenses were based on the 4-element Tessar formula, several focal lengths (especially for movie cameras or specific medium format applications) were designed as triplets. [1, 2]
(Note: Don't confuse their "triplet lenses" with Wollensak's "Triple Convertible" lenses. A triple convertible lens usually has more than three glass elements, but gets its name because a photographer can use the front group alone, the rear group alone, or both combined to achieve three different focal lengths.) [1, 2]
If you are trying to identify a specific vintage lens you have, please let me know its exact markings or maximum aperture (f-stop). I can help you figure out its exact optical formula!"
________________________________________________________________________________________________________
The "Triple Convertible" lens sounds fascinating. My 191mm (7.5 inch) looks like it was regularly taken apart both front and rear. However, it is labelled a Raptar.
Sep 05, 2026 at 03:35 PM
simplejoy
Details
p.1 #15The most impressive Triplet lenses you've encountered
Answer:
Wollensak Varium
...Show more →
Thank you! You may be able to see the specific sources, but of course I only see numbers there...
There's an excellent source on Wollensak here however:
https://alphaxbetax.com/
It does indeed verify the "Varium" claim, and also adds another Triplet type, the Velostigmat Series VII.
The claim about Raptar lenses being Triplets is also true, since some of the Cine Raptar lenses are Triplets according to the catalogs i've looked at.
Sep 05, 2026 at 05:07 PM
simplejoy
Details
p.1 #16The most impressive Triplet lenses you've encountered
Okay, here's one of the more interesting/unique Triplet lenses I've encountered so far:
The Corfield Apo-Lumar 50 mm f/3.5
It's the only "APO" labeled Taylor Triplet lens, which I've ever seen. Since that label often doesn't mean all that much, I'm not trying to claim, that it really is apochromatic, but it certainly has to be pushed to show any chromatic abberations. That being said, it isn't really sharp wide open and quality does drop towards the edges, so I would suspect that it was likely recommended to stop it down in order to use it as it was intended, which was for enlarging as far as I know. Wide open, quality at distance is quite poor, but for close-ups it has a wonderful look to my eyes.
Apo-Bloomar by simple.joy, on Flickr
Stopped down it is a decent macro lens:
Writings on love by simple.joy, on Flickr
Stacked against me... by simple.joy, on Flickr
Here are a couple more shots:
Sep 06, 2026 at 07:28 AM
James Markus
Details
p.1 #17The most impressive Triplet lenses you've encountered
...Show more →
Really lovely macro set, and non-macro. I envy your 20mm flange distance on the eos 5r, or leica's 28.8 mm would work too. Fortunately, there is always more than one way to do anything photographically.
Sep 06, 2026 at 10:39 AM
Juha Kannisto
Details
p.1 #18The most impressive Triplet lenses you've encountered
I own or have owned these 5 Triplet lenses, 4 of them are tiny special artisanal hand-assembled low volume production lenses by MS-Optical / MS-Optics released 2010-2015, and one is a 1950's legacy rangefinder lens. My favorite from these is MS-Optical Super-Triplet Perar 35/3.5 II. I still have all of them except the MS-Optical 24/4 (I traded that one away, as I much prefer their later release Aporia 24/2 which is similarly tiny but not a Triplet).
MS-Optical / MS-Optics:
https://photos.app.goo.gl/iJ5q6anCPSp3fuwC7
https://photos.app.goo.gl/g2Kjpso5VsRqsq777
https://photos.app.goo.gl/LFWntZhsQsUkeDRz5
Super-Triplet Perar 28/4
https://photos.app.goo.gl/bPpWgVArsYBdcYKh8
https://photos.app.goo.gl/mmoxicwjabNxFRJK9
Super-Triplet Perar 24/4
https://photos.app.goo.gl/utXbcnar2HcQLfwy8
https://photos.app.goo.gl/Y59z7euRr9Ajfid2A
Super-Triplet Perar 21/4.5
https://photos.app.goo.gl/upBnAHX3aTJzvJ398
https://photos.app.goo.gl/1YeLgEDpvZHAgxra7
Topcor 9cm f3.5 LTM:
https://photos.app.goo.gl/14jFXxqS5M8i3pex5
Edited on Sep 07, 2026 at 04:33 AM · View previous versions
Sep 06, 2026 at 10:53 PM
simplejoy
Details
p.1 #19The most impressive Triplet lenses you've encountered
Thank you very much! I didn't know about the MS-Optical Perar and really like your sample shots. The Topcor 9 cm seems to be a nice lens as well. I wasn't aware Tokyo Kogaku made a Triplet lens as well. Do you have a source for that lens being a Triplet, or is it your own observation?
Sep 07, 2026 at 01:58 AM
Juha Kannisto
Details
p.1 #20The most impressive Triplet lenses you've encountered
simplejoy wrote:
Juha Kannisto wroteI own or have owned these 5 Triplet lenses, 4 of them are tiny special artisanal hand-assembled low volume production lenses by MS-Optical / MS-Optics released 2010-2015, and one is a 1950's legacy rangefinder lens. My favorite from these is MS-Optical Super-Triplet Perar 35/3.5 II. I still have all of them except the MS-Optical 24/4 (I traded that one away, as I much prefer their later release Aporia 24/2 which is similarly tiny but not a Triplet).
All the internet sources about the Topcor 9cm f3.5 LTM refer to it as a true Triplet lens (3 elements in 3 groups).
The first/second site in list below is a dedicated Japanese site for Topcor legacy lens info, and you can see the lens optical design diagrams on the first link:
http://www.topgabacho.jp/Topconclub/lenscut.htm
http://www.topgabacho.jp/Topconclub/lens6.htm
http://www.topgabacho.jp/Topconclub/index.htm
https://flashbackcamera.jp/en/products/015736_leica_copy_topcor_90mm_f3-5_l
https://leica-copies-japan.com/Leotax.html
Brochure
^^ The Leotax Brochure is also a very official looking Leotax F brochure that has a table of Topcor lenses with element counts, listing 9cm f3.5 with 3 elements. However, the barrel design of the lens shown in the brochure looks a bit different from the usual version that is shown in other sources.
There was a time when I was really into those old Topcor LTM lenses and I acquired this 9cm f3.5, 2 copies of the Topcor-S 5cm f2 (Panda version, 2nd gen that is considered the best of them) and 5cm f2.8 (Heliar type).
The 9cm f3.5 is fairly easy to find in Tokyo for around 20K to 40K yen depending on condition nowadays, I saw several copies in current I.C.S. Used Camera Fair last weekend as well (http://ics1972.jp/).
Sep 07, 2026 at 02:40 AM
FM ForumsLeica & Alternative GearJoin Upload & Sell
Switch to mobile view
