Leofoto G6 thoughts?
NatalieSch
p.1 #1Leofoto G6 thoughts?
I'm in need of a head with geared movements that can deal with heavier setups. My partner is taking a trip to China in a few weeks and I was thinking of having them pickup a Leofoto G6 for me while there. My plan is to put a GR2 on top to get geared panning too. Anyone have experience with the G6? Not much written about them online. I wish I could afford an Arca-Swiss Cube, but even used they're out of budget.
Sep 01, 2026 at 10:15 PM
JBPhotog
Details
p.1 #2Leofoto G6 thoughts?
I purchased the Leofoto G4 online and when it arrived I was a bit concerned by its small size. Despite the specifications stating Max load 20 Kg the locking knobs would not stop it from creeping with less than a 5 Kg load. I returned it. FWIW, I would take their max capacity specifications with a grain of salt if that is a concern for your gear setup.
Sep 03, 2026 at 12:44 PM
OregonSun
Details
p.1 #3Leofoto G6 thoughts?
For what it's worth, I have the G20 (similar rated capacity to the G6) and it is rock solid with my Pentax 67 set up (6-8lbs depending on the lens). That said, I can't imagine it would actually handle the stated capacity (20 or 30kg, depending on what Leofoto site you look at). I use it with a Sunwayfoto leveling base (LB-75) to extend the limited adjustment range. Stated capacity for the LB-75 seems more believable at 15kg.
Sep 03, 2026 at 01:43 PM
FM ForumsGeneral Gear-talkJoin Upload & Sell
Switch to mobile view
