Loxia - After a Decade is There Anything Unique/Special?
bwcolor
p.1 #1Loxia - After a Decade is There Anything Unique/Special?
I purchased the 21mm/35mm/85mm and then let the lenses sit and eventually forgot about them. Construction is first rate and weather sealing looks to be quite impressive.. at least by judging by the body/lens seal. Some control surfaces are a bit cramped and large hands might have a bit of a time removing a lens from the body. I believe they are still in use for video work. I don’t remember why I never used them and I can say that as a portrait lens the 85mm is an appealing choice, but just now I searched Flickr and it seems that as of the A7Rv, these lenses are rarely used. Is there a use case for these lenses? I ask because with the bright, high resolution EVF’s manual focus seems so much easier than when these lenses were introduced.
Aug 25, 2026 at 03:08 PM
JDug
Details
p.1 #2Loxia - After a Decade is There Anything Unique/Special?
I love my Loxia 21, but also do not reach for it often as most of my shooting has switched to family and action shots right now. But when I have time to go for walks or landscape shooting the Loxia is always my favorite.
Aug 25, 2026 at 03:49 PM
bwcolor
Details
p.1 #3Loxia - After a Decade is There Anything Unique/Special?
What I remember was/is the micro-contrast.. perhaps mostly after f/4-5.6 with the 35mm. This generally gives a more saturated look right out of the camera. Skin tones with the 85mm were impressive as was bokeh and the sharp to blur smooth transition. I have Zeiss lenses for my RTS series, G2 lenses, Contax T2 as well as 21mm Biogon and two 35mm ZM lenses..for the ‘M’ mount. I always liked the look. So, this makes it even more surprising that these lenses lived in my safe.
Aug 25, 2026 at 03:55 PM
jeffbuzz
Details
p.1 #4Loxia - After a Decade is There Anything Unique/Special?
The only "weather sealing" on Loxia lenses is that rear gasket. There are no other seals. It's more an effort to protect the camera from ingress at the mount rather than protecting the lens in any meaningful way.
Aug 25, 2026 at 04:16 PM
philip_pj
Details
p.1 #5Loxia - After a Decade is There Anything Unique/Special?
They are a genuine cine-style range, same placement of rings, same external diameter, filter sizes, fine build. I have the 85mm and it surprises with portrait ability, flowers and nature work in less harsh environs. Rich but balanced saturation.
The lenses were designed, branded, and engineered by Carl Zeiss. The production was handled in Japan by Kenko Tokina through an official partnership with Zeiss. Kenko Tokina ceased production of the Loxia line, and the lenses have been officially discontinued in 2025.
.a short video on the Loxias.
Aug 25, 2026 at 04:47 PM
bwcolor
Details
p.1 #6Loxia - After a Decade is There Anything Unique/Special?
I’ve been regularly using Grok 4 as a means of doing searches and analyzing issues. I don’t take the output at face value and many times need to correct the assumptions, but this one threw me a bit of a curve ball.. for baseball cultures.. I provided a list of all of my Hasselblad X2D2 and Sony FE lenses. I recently purchased the 20-35mm E and 35-100mm E XCD lenses..and then the A7R6 was announced where I have sold most of my Sony equipment short of small lenses. I purchase camera equipment these days to help me copy film images, or for travel. I have an opportunity to return to South Korea with my wife, who has never been to South Korea. My previous month trip covered Seoul, Gyeongju and Busan with an X2D and a 38mm v lens. My photographic intent was to return to the exact same locations, but come away with very different looking images. I decided to pickup the 16-35mm GMII and 50-150mm GM and my 24mm GM for low light. My intention was to challenge myself with shooting mainly the long zoom at f/2.0. I added all of my other XCD and FE lenses and listed them for Grok 4 and to my amazement the suggested kit was to take the Loxia 21, 35 and 85mm lenses. It made a strong argument regarding all the characteristics of these Zeiss lenses and recognized what I was attempting to do with my selection. Other than inclement weather, there is a good argument that the A7R6/Loxia make the best counter to the X2D/38v of my first trip…. Wow, lenses that i forgot about and running counter to thousands spent recently. As Phillip mentioned in a previous post.. more with less.. simplify.
Aug 25, 2026 at 05:13 PM
philip_pj
Details
p.1 #7Loxia - After a Decade is There Anything Unique/Special?
There is no shortage of advice out there, everything from a single lens (I read the other day that the Q series sells twice the volume of M cameras) right through to 'take it all with you'. It's a challenge which ever way you go.
I do think it's best to work through the images you want to take, down to what focal lengths, what range3 of subjects etc. Travel work is very rewarding but being a bit of a masochist helps. all the best.
Aug 25, 2026 at 05:49 PM
Planetwide
Details
p.1 #8Loxia - After a Decade is There Anything Unique/Special?
I just found a new trio - 21, 25, & 85mm Loxia lenses, so I bought them. I had them years ago, and sold them off. Testing on the A7r5 and A7r6 show the lenses are still very good on those bodies. From what I remember, the 35 & 50mm were a little behind, but my memory could be suspect.
Aug 25, 2026 at 08:00 PM
bwcolor
Details
p.1 #9Loxia - After a Decade is There Anything Unique/Special?
Congratulations…
I know that the 35mm really doesn’t start to shine until stopped down to f/4. The 21, 25 and 85mm are the best.. The 85mm really is a very special lens.. a bit heavy, but it has a beautiful rendering.
Aug 25, 2026 at 10:21 PM
philip_pj
Details
p.1 #10Loxia - After a Decade is There Anything Unique/Special?
The Loxia 85mm is better (in MTF sharpness) terms than Leica's 90/2 APO-Summicron-M, APO-Summicron-M 75/2, and about equal to Milvus 85/1.4 and APO-Summicron-SL 90/2. A few mixed ones from this forgotten lens:
Aug 25, 2026 at 10:40 PM
dakel
Details
p.1 #11Loxia - After a Decade is There Anything Unique/Special?
...Show more →
Before you get too excited about this, there is a known problem with Zeiss Loxia lenses and newer Sony bodies where the view jumps in and out of 100% focus magnification, randomly. I have experienced it on my A1 and A7RVI with my Loxia 21. It's quite frustrating. There is a thread on this board somewhere about it.
Aug 25, 2026 at 11:51 PM
jeffersoncasey
Details
p.1 #12Loxia - After a Decade is There Anything Unique/Special?
I switched to Sony recently and gotten myself a Loxia 35mm for cheap. Very nice lens, but even at just f2 the coma is worse than 35lux FLE at f1.4. Fortunately my copy is sharp from corner to corner wide open. Probably will get the 28mm Nokton down the road as the Thypoch isn't doing well on Sony, and 35mm now felt foreign to my eyes...
Aug 26, 2026 at 01:39 AM
Douglas L
Details
p.1 #13Loxia - After a Decade is There Anything Unique/Special?
I had the Loxia 21 a few times. Have been using the Voigtlander 21 f1.4 ever since it came out. Love it but it's on the heavy side. I don't need f1.4. So I am carrying the unnecessary weight. I may pick up another copy of the Loxia 21 if the price is right. I have seen them going for $400. For me, the main draw of both the Loxia and Voigtlander is the sunstar, but that's just me.
Aug 26, 2026 at 05:50 AM
bwcolor
Details
p.1 #14Loxia - After a Decade is There Anything Unique/Special?
dakel wrote:
bwcolor wroteI’ve been regularly using Grok 4 as a means of doing searches and analyzing issues. I don’t take the output at face value and many times need to correct the assumptions, but this one threw me a bit of a curve ball.. for baseball cultures.. I provided a list of all of my Hasselblad X2D2 and Sony FE lenses. I recently purchased the 20-35mm E and 35-100mm E XCD lenses..and then the A7R6 was announced where I have sold most of my Sony equipment short of small lenses. I purchase camera equipment these days to help me copy film images, or for travel. I have an opportunity to return to South Korea with my wife, who has never been to South Korea. My previous month trip covered Seoul, Gyeongju and Busan with an X2D and a 38mm v lens. My photographic intent was to return to the exact same locations, but come away with very different looking images. I decided to pickup the 16-35mm GMII and 50-150mm GM and my 24mm GM for low light. My intention was to challenge myself with shooting mainly the long zoom at f/2.0. I added all of my other XCD and FE lenses and listed them for Grok 4 and to my amazement the suggested kit was to take the Loxia 21, 35 and 85mm lenses. It made a strong argument regarding all the characteristics of these Zeiss lenses and recognized what I was attempting to do with my selection. Other than inclement weather, there is a good argument that the A7R6/Loxia make the best counter to the X2D/38v of my first trip…. Wow, lenses that i forgot about and running counter to thousands spent recently. As Phillip mentioned in a previous post.. more with less.. simplify.
I generally change the AF-ON but to focus magnification and turn off auto magnification. I haven’t yet seen an issue with the 35mm with this setup, but I’ll be on the lookout for this issue.
I’m next going to look at the 16-35mm GMii as a replacement for the Loxia 21 & 35mm. I suspect that in the longer range I’ll end up with a technically better image with the GMii, but an esthetically more appealing image with the Loxia 35mm. The two Loxias are a bit heavier than the zoom, but of course the Zoom when mounted to the camera is less balanced, but perhaps reasonably balanced when using the vertical grip.
The 85mm doesn’t require any further investigation.
Aug 26, 2026 at 12:37 PM
msadat
Details
p.1 #15Loxia - After a Decade is There Anything Unique/Special?
one thing for sure, amazing eye you have!
Aug 26, 2026 at 04:36 PM
philip_pj
Details
p.1 #16Loxia - After a Decade is There Anything Unique/Special?
you are too kind. It's a shame to see them go, but so many lenses have been released and then the arrival of the Chinese lenses, it's very hard to keep up.
Aug 26, 2026 at 06:19 PM
Switch to mobile view
