Your Workflow for BW Noritsu Scans
Leickor
p.1 #1Your Workflow for BW Noritsu Scans
I shoot exclusively B&W film, lab-processed and scanned on a Noritsu. Because I don't control development contrast and lab scans tend to come back a bit flat, I’ve been building a Lightroom workflow specifically for editing the converted JPEGs I receive from the lab.
Right now, I'm using a base import preset as follows:
Contrast +10, Highlights -10, Shadows -12, Whites +10, Blacks -10, Clarity +5, Dehaze +5 and Sharpening 0
The plan is to pair this base with a set of modular "contrast grade" S-curve presets (similar to darkroom Multigrade filters).
Does anyone else run a similar workflow for BW lab scans? What key adjustments or preset stacks do you rely on to bring out the best in your scans? Are there any good presets available for this use case?
Aug 09, 2026 at 06:56 AM
bjhurley
Details
p.1 #2Your Workflow for BW Noritsu Scans
Before I started developing and scanning my B&W films myself, my lab scanned them with a Noritsu.
I use Capture One, not Lightroom, but my basic procedure was to first apply auto-levels, which improved everything immediately, including contrast; I sometimes brought in the black point a little more to taste.
After that everything was image-specific, typically applying a bit of selective midtone detail/clarity, selective dodging and burning, selective shadow recovery (I've found highlight recovery is pretty much useless in film scans, the results never look good to me), and then lots of dust and hair spotting. I never sharpened or dehazed.
I now scan my own films (35mm with a Plustek; 120 with an Epson V600) and my scans generally look better than anything I ever got from the lab. I scan them flat using the same settings for every B&W film (no adjustments at the scanning stage), and apply the same routine that I did to the Noritsu scans, although I often increase contrast in addition to setting levels. For images with a lot of sky, I often apply contrast selectively as I think clouds look better with less contrast, so instead of increasing contrast globally I add it selectively to areas that could use it.
Aug 09, 2026 at 08:52 AM
theHUN
Details
p.1 #3Your Workflow for BW Noritsu Scans
...Show more →
Black point, white point, gray point are the big ones. Curves and gray point would be next, the details depend on the scene, light, ... .
But really, stop editing jpgs, and buy a used V850 or similar, so you can scan/edit tiffs.
Aug 09, 2026 at 10:13 AM
bjhurley
Details
p.1 #4Your Workflow for BW Noritsu Scans
Have you actually found a difference? I tried with 20-25 images, high-res TIFF and JPEG, some B&W and some colour films, and never was able to get anything more out of the TIFFs than I could from the JPEGs. But I don't do very heavy editing or extreme colour changes (mainly just changes in saturation and occasionally hue, white balance changes on colour film, etc).
Aug 09, 2026 at 11:00 AM
theHUN
Details
p.1 #5Your Workflow for BW Noritsu Scans
bjhurley wrote:
theHUN wroteBut really, stop editing jpgs, and buy a used V850 or similar, so you can scan/edit tiffs.
The key qualifier was "flat". If the black/white points are appropriate then a jpg might suffice. But a flat jpg will not survive level/curve adjustments.
Aug 09, 2026 at 11:15 AM
bjhurley
Details
p.1 #6Your Workflow for BW Noritsu Scans
Mine always do, but I export my JPEGs from TIFFs for editing. I make flat scans and save them as TIFFs for archiving and edit the exported JPEGs. I've never seen any artifacts. I don't think I've ever seen any artifacts from lab JPEGs either, which are usually lower-res than the ones I export from my TIFFs.
Aug 09, 2026 at 11:18 AM
Leickor
Details
p.1 #7Your Workflow for BW Noritsu Scans
Thx for the replies!
I would prefer to scan myself, but lack the time.
The key challenge with the lab has been to get them to expose properly during scanning, especially for back-lit shots where you believe yourself to have done an ok job with metering!
Aug 09, 2026 at 09:56 PM
bjhurley
Details
p.1 #8Your Workflow for BW Noritsu Scans
If you get the negatives, you can pretty easily confirm whether you did indeed meter correctly (underexposed negatives will look "thin" and overexposed negatives will be very dark and hard to see through). I doubt any under- or overexposure you may see in your shots is due to their scanning.
Aug 10, 2026 at 05:06 AM
Leickor
Details
p.1 #9Your Workflow for BW Noritsu Scans
bjhurley wrote:
Leickor wroteThe key challenge with the lab has been to get them to expose properly during scanning, especially for back-lit shots where you believe yourself to have done an ok job with metering!
I do receive the negatives back, I need to check, thanks!
Is the correct exposure of the negatives during not that variable/decisive for good scans?
Aug 11, 2026 at 04:28 PM
bjhurley
Details
p.1 #10Your Workflow for BW Noritsu Scans
On my scanning setup, exposure seems to be automatic; I use the same settings for all B&W films and never adjust anything during the scanning process. I'm not sure how the Noritsu works in this respect, but when I got underexposed or overexposed scans from my lab, the negatives were also underexposed or overexposed. My lab makes flat scans to give its customers latitude to adjust to taste in post; many labs do this but not all.
I've never done camera scanning and am not sure how exposure works there.
Aug 11, 2026 at 05:01 PM
FM ForumsFilm Is Not Dead ForumJoin Upload & Sell
Switch to mobile view
