Leica M4 rangefinder vertical and horizontal misalignment question
geekcop
p.1 #1Leica M4 rangefinder vertical and horizontal misalignment question
I could use some help understanding what I am seeing in the viewfinder of my new to me Leica M4 and recommendations on what to do next.
I got the camera last week from Kenmore Camera. The camera is in amazingly good physical condition and I am happy with it. Today I got my first lens, a new 35mm CV 2.5 Color-Skopar lens. So, today was the first time I could see how the camera worked with a lens attached.
When I look through the viewfinder with the lens attached the double image doesn't align. It is off both vertically and horizontally. I assume it needs to go either back to Kenmore or to someone else to be serviced.
I am completely new to the Leica ecosystem. Could I being doing something wrong when I mount the lens so much so that I am causing the issue? The lens locks in and appears to be correctly lined up on the body. BTW the correct 35mm frame lines appear as expected. Or is it likely just out of alignment? The camera appears to have been serviced by DAG as it has the "92" wax seal in the mount. The camera otherwise is smooth as glass. I am not inclined to mess with adjusting anything internal to the camera myself FYI. I tried to get an iPhone photo showing the issue in the finder but it didn't work well enough to illustrate the issue.
Any advice or suggestions are appreciated.
Jul 20, 2026 at 09:59 AM
davidsee
Details
p.1 #2Leica M4 rangefinder vertical and horizontal misalignment question
Send itback to Kenmore tell them what is wrong and fix it
Jul 20, 2026 at 10:08 AM
Desmolicious
Details
p.1 #3Leica M4 rangefinder vertical and horizontal misalignment question
...Show more →
You’re not doing anything wrong. They sold you a camera with the RF out of whack.
It needs to be serviced. You need to factor that cost into the decision whether you want to keep it, send it back, or have Kenmore pay for the service.
Jul 20, 2026 at 10:33 AM
burchyk
Details
p.1 #4Leica M4 rangefinder vertical and horizontal misalignment question
Rangefinder alignment is something you do every once in a while on an M. Sometimes it happens, no need to panic yet.
Check the original listing and talk to the shop, see whether the camera was sold "as-is" or "full working condition". There is a possibility that an old camera was fine while in the shop, but got knocked about in shipping, which can definitely make the RF alignment move.
Don't recommend DIY. Get a respected technician known for working on Leicas to do it properly.
Jul 20, 2026 at 01:55 PM
geekcop
Details
p.1 #5Leica M4 rangefinder vertical and horizontal misalignment question
No panic. Just taking the next steps. Jim Patterson who works at Kenmore is on FM and he is helping me get it resolved one way or the other. This is literally my first Leica purchase and it is just a little sideways at the moment.
Jul 20, 2026 at 02:11 PM
1bwana1
Details
p.1 #6Leica M4 rangefinder vertical and horizontal misalignment question
...Show more →
This is actually a more complex question than it first seems. The camera does not need a lens attached for the Range Finder to work. So we must isolate whether it is the lens or camera that is out of adjustment. Best to send your lens(es) and camera in together to be tested and aligned for perfect focus.
But for information purposes here is a link to a process to follow.
https://www.google.com/search?q=with+leica+m4+cameras+how+do+you+test+to+see+if+it+is+the+lens+or+the+camera+that+needs+to+be+adjusted+for+accurate+focusing%3F&sca_esv=3271cc0dab4982ea&rlz=1C1UEAD_enUS1063US1063&sxsrf=APpeQnvgJIvnl6lv86yL200psC1JtBvbXA%3A1784580230108&ei=hoheavGWBsC6i-gPyYyL0Q8&biw=1567&bih=1045&ved=0ahUKEwjx8cC1j-KVAxVA3QIHHUnGIvoQ4dUDCBE&uact=5&oq=with+leica+m4+cameras+how+do+you+test+to+see+if+it+is+the+lens+or+the+camera+that+needs+to+be+adjusted+for+accurate+focusing%3F&gs_lp=Egxnd3Mtd2l6LXNlcnAifXdpdGggbGVpY2EgbTQgY2FtZXJhcyBob3cgZG8geW91IHRlc3QgdG8gc2VlIGlmIGl0IGlzIHRoZSBsZW5zIG9yIHRoZSBjYW1lcmEgdGhhdCBuZWVkcyB0byBiZSBhZGp1c3RlZCBmb3IgYWNjdXJhdGUgZm9jdXNpbmc_SABQAFgAcAB4AJABAJgBAKABAKoBALgBA8gBAPgBAZgCAKACAJgDAJIHAKAHALIHALgHAMIHAMgHAIAIAQ&sclient=gws-wiz-serp
Jul 20, 2026 at 02:48 PM
Oldwino
Details
p.1 #7Leica M4 rangefinder vertical and horizontal misalignment question
You could also ask Don (DAG) about it. He has service records for everything he repairs.
Jul 21, 2026 at 07:58 AM
geekcop
Details
p.1 #8Leica M4 rangefinder vertical and horizontal misalignment question
Thanks for the suggestions all. I am going to return it to Kenmore Camera. They want to see it before they decide what they want to do with the camera. I'm going to take a refund and call it a day. I'm just going to stick with my 35mm SLR's.
Jul 21, 2026 at 12:52 PM
Desmolicious
Details
p.1 #9Leica M4 rangefinder vertical and horizontal misalignment question
Yeah. It was an expensive purchase and for that (or any purchase really) you expect for it to work straight out of the box.
A couple of years ago I bought a 'perfect' M4 from Camerawest, and it just had a shutter service (new curtains etc) from DAG. They included the receipt. When I got it I immediately saw the curtains were dragging and bouncing! No idea how that happened but it shows that even the best can sometimes not have a good day.
Sent it back, got a refund. Annoyingly though they asked to see evidence of the issue before accepting return. Which was easy enough - I sent them a short video of the shutter bouncing - but it left a little bit of a bad taste to me.
They should have checked it was ok before taking my money.
Jul 21, 2026 at 01:04 PM
geekcop
Details
p.1 #10Leica M4 rangefinder vertical and horizontal misalignment question
This was my second attempt at buying a Leica. I also ordered two lenses when I ordered the M4. One I can return for a refund the other hasn't arrived yet and was bought here. So I'll see what I can do with the second lens. It was not expensive, but I don't expect the seller to take it back. In all a $2300+ experiment with most money coming back to me.
Jul 21, 2026 at 01:09 PM
Desmolicious
Details
p.1 #11Leica M4 rangefinder vertical and horizontal misalignment question
If the second lens is a wideangle, you could get a zone focus Leica M like an MD (they don't have VFs!) and not have to ever worry about RFs being off!
Personally I would not get one as my one and only M, but it's an option. I occasionally use one.
Jul 21, 2026 at 01:24 PM
geekcop
Details
p.1 #12Leica M4 rangefinder vertical and horizontal misalignment question
It is a collapsable 90mm f/4. Would have been fine for the price and super small.
Jul 21, 2026 at 01:36 PM
Desmolicious
Details
p.1 #13Leica M4 rangefinder vertical and horizontal misalignment question
That would be fun on a mirrorless camera. Or resell it.
I have a 90mm Macro M, but I have to remind myself that I have it, it is so rarely used.
SLRs IMO are way better for that and longer.
Jul 21, 2026 at 03:22 PM
treacle
Details
p.1 #14Leica M4 rangefinder vertical and horizontal misalignment question
I recently got an M4 too (while I was in Japan in the spring) and I'll probably send mine off for a CLA over winter but it has been working pretty well. Since they haven't been made since 1975 there is a good chance after 51 years there would be some issues. At this point I would probably return it as repairs on older equipment can take a while.
Jul 21, 2026 at 04:50 PM
geekcop
Details
p.1 #15Leica M4 rangefinder vertical and horizontal misalignment question
FYI camera was returned. Thank you to everyone who offered advice. YYe did return an email with advice on adjusting the camera, but he felt that it was likely too far out for a manual adjustment and that the prism was likely out of place which would necessitate an in shop repair.
Jul 27, 2026 at 04:53 AM
madNbad
Details
p.1 #16Leica M4 rangefinder vertical and horizontal misalignment question
If the prism was out of place, the camera was either dropped or had a hard knock. Kenmore Camera should have preformed a more thorough inspection before putting it out for sale.
Too bad. I've owned a couple of M4's and a M4-2 and they're great cameras.
Jul 27, 2026 at 04:43 PM
FM ForumsLeica & Alternative GearJoin Upload & Sell
Switch to mobile view
