Mamiya 645 Pro Lot w/MINT 80 f/1.9+ MORE!! LOOK!!
Price$1,800.00
PayPal
Shipping instructions
PP G&S
Hello, all! I’ve decided to sell my Mamiya 645 kit.
——> PLEASE read everything for an accurate description.
- Located in Rockford, Illinois.
- Local meetup or PayPal G&S.
- eBayer with 300+ 5-Star reviews.
Looking to sell first as a lot: $1,800 OBO
I HAVE 30 PHOTOS OF THIS LOT, SO PLEASE REACH OUT AND ASK FOR MORE, IF INTERESTED!
Items:
1. Mamiya 645 Pro Body
- w/body + ground glass caps
- Camera is near mint with slight scuffs. More scuffing on the bottom, but less than normal.
- Ground glass is clear and near perfect.
- Battery check light works, battery compartment is pristine with no wear. Battery cap is strong and tight.
- All digital connections are clean and perfect.
- All buttons function perfectly.
- Shutter button (on and off) + timer works.
- Shutter speeds are all accurate.
- Hot shoe is near mint.
- All wording on camera is intact.
- Multi Exposure button functions.
- MLU functions.
- Lens release is tight and accurate.
- PC sync is perfect.
- Lugs are clean.
- Metal connection point to film back is strong and intact.
- Cloth curtain is perfect. No tears, rips, or ripples.
- Top dial is flawless, smooth and accurate.
- TOP Shutter dual cover is missing (VERY common) Thankfully, I have included two custom 3D printed dials ready to be glued on.
- Shutter advance winder sounds grand. Tight, accurate, solid.
2. 2x 120 Film Backs
- Both work flawlessly.
- Digital connectors are clean.
- Advance wheels are accurate and clean.
- 1x Red + 1x Blue darkslide. The blue has a small dent on the grip point to remove. Looks like a camera strap caught it. Works perfect.
- Both come with a plastic film protector.
- 1x Film back has a 1/2” crack running down from a screw in the plastic. This is very common and has no effect on stability or letting light in.
- Both ISO dials are accurate and work flawlessly.
- 1x Back has a new roll of TRI-X loaded.
- Both advance dials work and accurately portray what exposure you are on.
3. AE Finder FK402
- w/cap.
- Diopter is flawless.
- Light paint chipping on top (very common.)
- VERY minimal dust.
- Super clean.
4. Fotodiox Pentax 67 to 645 adapter.
- Brand new. Works flawlessly.
5. K&F Concept 67mm Variable ND filter, 1-9 stops.
- Brand new. Flawless. Purchased for 80 1.9
6. Installed TYPE E RANGEFINDER Spot/Microprism.
- NOS, Mint.
7. TYPE A (Matte) Screen w/removal and installation tool.
8. Mamiya Sekor C 80mm f/2.8 N
- Body is near mint.
- Aperture ring and manual override work perfectly.
- Moderate dust under close inspection. I doubt it would affect picture quality. “I” have not had a problem in the rolls I have put through with the lens.
- Looks like a small amount of fungus? Pictured in a photo. Does not seem to affect photos.
- Glass looks great under quick inspection, so it’s not detrimental.
- Body Cap.
- Original rubber hood. No cracks, works perfectly.
9. Mamiya Sekor C 80mm f/1.9
- WHAT A BEAUTY.
- The TINIEST MOST TRACE AMOUNTS OF DUST. You have to LOOK to find it.
- No mold.
- No fungus.
- Body is mint, EXCEPT for small chipping on the silver band at the tip of the lens.
- Aperture is smooth.
- Focus is smooth.
- A near PERFECT example of this legendary lens.
10. Lensrentals branded SKB case.
11. 3x Rolls of Ilford Ortho ISO 80 b&w film.
- Expires 2/2027
12. Mamiya RZ67 Waist Level finder leather zipping pouch.
13. DISMANTLED Prism Finder FE401
- Taken apart to clean fungus off the glass.
- Was completed, but needed a soldering iron to complete.
- It’s in pieces, but ALL is there, all the screws, components, everything.
- Meter worked flawlessly before being disassembled.
- Schematic online to fix.— in Loves Park.
