I have tried many camera bags. I am sure many of you are in the same boat. The boat with destination - "The best camera bag"! !! There are plenty of bags by many manufacturers when it comes to carrying lenses and bodies and accessories. But when you think of carrying your super tele lenses it gets tricker especially when traveling by airplane.
So far I found that Gura Gear 30L v2 is the bag that fits 600 f/4 + 300 f/2.8 + two camera bodies + two TCs + more accessories. I can also carry laptop in it but I don't. I choose to carry ipad pro in travel. This is all great but this bag doesn't have wheels and its a lot of pain to carry it around when walking long distances at airports between terminals.
Having said that, I still like that this bag has a form factor that makes it fit in many airlines including small jets that have limited - short overhead compartments. For that reason alone I still continued to use it as I can be assured that it fits on so many planes both domestic and international and I can always be assured that my gear is always with me and not checked in.
I would still like to consider similar sized bag with rollers. I don't know if anything would rollers would satisfy requirements of as many airlines as this bag does. Plus yes having a roller bag puts it at a risk of being targeted to be checked in. But that is something I am ok with as I could still talk to airline folks and try and not check it in.
I did think of another option which is carrying portable dolly to haul this bag at airports. However I have not come across any super compact dolly that will do this. Also at times dolly itself can be counted as personal item thereby not allowing me to carry personal item - like a smaller bag that can house little bit more gear. I do use WANDRD 9L for this purpose and at times I can carry - say a drone and another lens in it. That is really relatively small and carries enough that it can also be used as a waist pack looking like a smaller personal item bag along with Gura Gear 30L which becomes primary carry on backpack.
So now that I've shared my setup, can you help me find the perfect bag with rollers that can still carry super teles like I mentioned above.. more like carry 600 and 300 and some more gear? Also if it can be carry on compatible for travel domestically and internationally?
The Gura Gear works because as a backpack/bag, it can be relatively unstructured and thinly padded to allow stuffing that much gear in it and still fitting US carry-on size requirements. Even a 'soft sided' roller by necessity of its build/structure, will cannibalize some space that could otherwise go towards gear in a backpack. This compromise is at its most extreme if you consider hard sided rollers, such as from Pelican, Nanuk, etc.
Back in the DSLR days I used to travel by air with the Pelican 1510 roller, usually with a 400/2.8, a couple Canon 1D series bodies and a couple zooms. Instead of the 400 I could fit a 600/4, but its additional length reduced the amount of other gear I could fit in the case. I don't think I could have fit a 300/2.8 with the 600. But maybe it would be possible with a soft sided roller. Based on your recent posts, I'm guessing you're a Sony user. If so, then the very compact nature of the FE 300/2.8 would certainly be beneficial...
My current solution is a Tenba Roadie backpack. I can fit my Canon 200-400 plus bodies, lenses, etc. But it's a backpack and I carry it as such through airports and on airplanes. I check a Thule Chasm 110L wheeled duffel packed with my clothes, etc. At the destination, the clothes stay wherever I'm staying and the backpack goes in the roller duffel and that combo goes with me to the destinations where I'm working. I currently like this solution because the Thule has a wide wheelbase and larger than average wheels, so it handles rougher surfaces, grass, etc., better than the smaller wheels and narrower, more wobbly wheelbase of typical photographic rollers that work best on smooth surfaces (like in airports ). I can also throw a lot more stuff in the duffel in addition to the backpack, such as a monopod or tripod, rain gear or other bulky items such as a helmet, burly kneepads, water bottles, etc. The design of the Thule is that of a hard-shell base or tub on the bottom third, onto which is sewn a very durable non-woven (at least the outer surface) pliable material that appears to be effectively waterproof (the zippers are not waterproof). I don't fly as much as I used to, but so far it has survived 4-5 trips, including internationally and so far the top half of the duffel is surprisingly unscathed. And without any holes or cuts in the pliable material. It also survived being sent as a parcel via a baggage forwarding service in Japan, though I'm guessing based on how things run in Japan, it wasn't at much risk of damage. As an alternative to the Thule, which is technically 62" linear length and 2" too long for most airlines, though I have yet to have any problems checking it in, I picked up a Pelican AEGIS 28" Check-In Rolling Hybrid Duffel because it was discounted at B&H. It can do the same tasks as the Thule, but is slightly smaller and therefore has less room for extras in addition to the backpack. But it's also not built as robustly as the Thule. On discount currently $200 off, and I suspect it might be perennially discounted, it's probably not a bad deal. I paid full price for the Thule. It wasn't cheap for what it is, but I feel it is robust and well made. And worth the money. The Pelcan is worth <$200. I would not pay full retail for it.
The downside of these two bags, based on your post, is that they're too large for carry-on. While these would not be in-airport carry solutions, they could be worthwhile considerations once at the destination. And for closer to home trips by car, which I do much, much more frequently than flights and therefore is mostly how I use the Thule and Tenba Roadie combination.
Buy the $30 Samsonite folding luggage cart which folds down and easily fits inside the aircraft overhead bin with the Gura Gear bag on top of it. Back with wheels have reduced interior space and are 2 inches taller and less likely to fit in an overhead bin.
I have V1 of the Roller Durby by Thinktank and it's by far the best rolling bag I've ever owned, regardless of purpose. The V2 comes with some improvements. You'll have to measure, but they give accurate dimensions and show you multiple configurations to help you determine if it's for you. Mine fits in standard airline overhead bins without issue. Only issue you might have are the hoods on those tele's.
I use a Gura Gear 32L for travel and also take a Samsonite folding cart to use to carry the bag and also a personal bag through airports. The Samsonite sells for $30 and is very compact when folded. All the bags with built in wheels sacrifice space for the wheels and not great for air travel with photo gear. I take a bag that qualifies as a personal item and fits under the seat in front and put as much weight as possible inside it.
I traveled to Costa Rica last month with the same setup and after walking many miles through the Miami airport using my Gura gear vowed I would not do again. I was looking at the Think tank airport security which technically is too large for check-in but everyone tells me is not a problem. Then I came across the PGYtech rolling 30L with removable wheels which seems like the perfect bag. Wildalaska on YT said you can fit a 600mm and another telephoto. It even expands another 10l.
I am hoping for some real world feedback from someone that has one
I have a trip to Churchill planned for next year and the Calm Air carry-on baggage limitations are max for two bags combined being 10 x 16 x 12 inches and 20 pounds. Apparently, Calm Air is strict about this. The person leading the tour says that he uses an older ThinkTank Streetwalker. My Gura Gear Kiboko 22L and 30L packs are too large. The 16L version does not have sufficient depth for my thickest lens which is 4.9" (Sony 300/2.8). I plan to take the 300/2.8 and another long lens, either the 200-600 or possibly the new 100-400/4.5.
So, I too am on the lookout for a recommendation that will work. So far, I have not found a suitable backpack owing usually to being too long, but sometimes, the interiors won't work.
I am wondering if it would be possible to fit both lenses in the 16" Chobe, and then using the Samsonite folding cart (which I already own) to haul it through the airport. This is not an ideal option, but one that I am looking into.
Any recommendations from people who have flown with long lenses with this kind of carry-on restriction?
I mean one of the reasons I drive now to places more than flying is the hassle of luggage restrictions. Unfortunately driving to Churchill is not an option. Well, if it was, it would be a really long drive from Winnipeg.
I looked briefly at the train option and decided that I would rather fly. For certain, I would not be able to sleep and that would start out my time in Churchill being exhausted. That said, I totally agree with you about doing other means of transportation when it works out.
Thanks for the like to Scott's thread. I really appreciate it and will message him to see what he did.
NP. As you can see from his thread, he was very analytical about that trip. However, he hasn't posted for a few months after being pretty regular here on FM, so I hope you're able to connect with him.
Thanks. I hope that I can connect with him too. Sent a PM yesterday but have not heard back yet. Hopefully he's ok.
