What would you choose? Has someone had the chance to use both cameras?
I initially opted for the A7CII due too it's handy size and lens selection but had the chance to use the Z5II for a short while and it's very mature for a Nikon camera.
A7CII
+ much smaller and lighter than the Nikon, better suited for travel
+ much better lens selection
+ probably better AF
+ the Tamron 25-200 is arguably the best travel super zoom atm
- expensive
- more noise in raw files in dark conditions
- poor EVF, I use glasses and don't know if this could be a deal braker
- subpar plasticky build quality, flimsy dials and knobs
- questionable ergonomics
- the Tamron might be too uncomfortable on a small body
- low resolution & dark back screen
Z5II
+ exceptional price-perfomance ratio unmatched by any Sony camera
+ build quality
+ better low light AF (?)
+ the Z 24-120 is arguably the best 24-105/120 lens atm
+ good evf and high-res bright back screen
+ great low light sensor
+ can be used for professional work
- big and heavy
- lens selection is limited
- most Z lenses are expensive, big and have subpar build quality
- 24-120 has less range and is bigger and heavier than the Tamron 25-200
Can’t go wrong either way. You’ve listed your pros and cons for each so now it’s time to decide which are the most important. I like the size and weight and resolution of the Sony and the range of the Tamron lens. I’ve never been too dependent on EVF or even the LCD as I’m not a chimper and rarely look at photos on camera. But I have other Sony gear so it makes sense for me to choose Sony. But I would be happy with the Nikon if I starting from scratch.
I had 6700 and got rid of it because of two reasons. Too small for hand and useless EVF (at least for me).
I assume A7C has similar EVF?
A7CII
+ smaller and lighter than the Nikon, better suited for travel
+ greater lens selection
+ low resolution & dark back screen
- expensive
Z5II
+ exceptional price-perfomance ratio unmatched by Sony
+ build quality
- big and heavy
A7CII
- expensive
Z5II
+ build quality
- big and heavy
You have laid out the pros and cons very well (except I disagree about Nikon lens build quality, I’ve owned a bunch from both brands), so it’s up to personal preference to choose what you like best.
I have owned both cameras and I prefer the build, feel in hand, overall ergonomics, and EVF of the Z5II by a mile. Also, that 24-120 is one of the best midrange zooms ever designed. I am in my 4th year shooting Sony (A7RV and now A7R6) after decades with Nikon and both brands are fully capable in the right hands. I enjoy the vast number of native E mount lenses available (I tried adapting on a Nikon body and the experience was not enjoyable for me).
But that’s just me, the important thing is to go with what feels most right for you.
I am just curious who told you that nikon's lenses have subpar build quality. I think they are one of the best build in any given price class.
I agree that both zooms are kind of big (though I don't mind even for travel). I think 20-70mm will pair better with A7cii. A7cii has more pixels so you can crop more. You can use it on nikon too with adapter (lots of people do), but nikon also has it's own 24-200mm which is a bit more balanced on bigger Z5, and they have a lighter, but slower, 24-105mm too.
I will say this though. After having owned A7cr and A6700 several times, the lack of buttons and focus point joystick are really missed. I am much happier taking A7riii (or nikon Z6/z7) on a trip with me then azcxxx.
I happen to be a Sony user, with aps-c and ff kit. I would suggest looking to finder, fit and feel in hand as a first priority. Then lens availability for your purposes.
Try before you buy/choose a body/system intitally based on the evfs. Not everyone likes the small body evf, sometimes it's working with glasses, eyepoint, resolution, or just placement. And there are better or worse finders in the full size bodies, too. I don't mind using my A6700, I don't know how the evf compares to the A7Cii finder. I believe the A7CR finder is said to be better but haven't tried it either.
I don't follow Nikon so not sure on lens offerings. Probably there would be suitable offerings. Sony has been doing mirrorless longer and more open to third party lenses. Sony could have a broader range of choices. If either has bodies that work for you, then maybe look lens first.
I have a Tamron 28-200. It's fairly typical of a number of "super-zooms" on the ff side when it comes to lens size and weight. I think it's kind of at the edge point for use on the smaller bodies. Smaller and lighter is nicer, of course, for walk around. If one's lens selections tend to start there and go heavier/bigger, then I'm not sure the smaller bodies are worth the trade off in features not there to be smaller. But I don't think it's so big as to not be a reasonable walk-around lens, either. (Nikon has a different set of body sizes so how that might work for you could be different.) One might decide to go with two or three lenses and maybe choose differently. For example, there's the Sony 20-70. Smaller and lighter, at least some, compared to the 20-200, 25-200 and 28-200s. But if wanting longer than 70mm, 100mm or out to 200mm, maybe there's a different all-in-one choice. And some might want a 16-xx or 17-xx zoom and then go with a 25-200 or 28-200 to get 200mm in a two lens kit. (I find swapping between a 17-29/2.8 and 28-200 frequent in a compressed "old city" urban environment but 28-200 almost all I need in other more open or non-urban settings.)
I have a Tamron 28-200. It's fairly typical of a number of "super-zooms" on the ff side when it comes to lens size and weight. I think it's kind of at the edge point for use on the smaller bodies. Smaller and lighter is nicer, of course, for walk around. If one's lens selections tend to start there and go heavier/bigger, then I'm not sure the smaller bodies are worth the trade off in features not there to be smaller. But I don't think it's so big as to not be a reasonable walk-around lens, either. (Nikon has a different set of body sizes so how that might work for you could be different.) One might decide to go with two or three lenses and maybe choose differently. For example, there's the Sony 20-70. Smaller and lighter, at least some, compared to the 20-200, 25-200 and 28-200s. But if wanting longer than 70mm, 100mm or out to 200mm, maybe there's a different all-in-one choice. And some might want a 16-xx or 17-xx zoom and then go with a 25-200 or 28-200 to get 200mm in a two lens kit. (I find swapping between a 17-29/2.8 and 28-200 frequent in a compressed "old city" urban environment but 28-200 almost all I need in other more open or non-urban settings.)...Show more →
I completely agree with your point of view regarding the 28-200. But we have one point of view (shooting long works for us) and many others really prefer the 20-70G for the wide angle flexibility.
These are two examples of lenses that are unique to the e-mount ecosystem and for me at least, the 28-200 alone is the reason I would not switch from e-mount. I feel that this decision should be made on the glass available and not the bodies. Personally, I would make a system decision based on glass that suits your shooting style as opposed to a specific body. As the cliche goes, date your bodies, marry the glass.
I think they have the same EVF. What bothers me more is that the A6700 has better ergonomics and a better button layout than the A7CII.
I will say this though. After having owned A7cr and A6700 several times, the lack of buttons and focus point joystick are really missed. I am much happier taking A7riii (or nikon Z6/z7) on a trip with me then azcxxx. ...Show more →
Nikon Z lenses are build of low quality plastic and metal compared to Sony G(M) lenses or even chinese lenses like Viltrox or Meike and they lack an aperture ring and other function elements. In newer Z glass like the 24-120 and 2nd gen 24-70 and 70-200 the quality is a bit better.
As for now every person which has had the chance to use or at least hold both cameras favours the Nikon.
aCuria wrote:
I would get the A7V or R6iii over the Z5II.
Usually my first lens would be a f/1.4 prime. Shooting with a zoom in low light is hopeless, while the prime works just fine in the day.
The second lens can be a zoom
The A7V seems almost ideal but the price is just to high for a hobbyist. R6II (not III) would be preferred for commercial work, It's arguably better than any Nikon but the extremely limited lens selection makes it the worst choice for an amateur.
As for shooting in low light, I've shot steel mills and coal mines with zero issues with an F4 zoom. It's great to have a modern BSI sensor and in body stabilisation.
