       2       3       4       end
Hasselblad XCD 35-100mm vs 90mm vs Sony 50-150mm GM
bwcolor
p.1 #1 · Hasselblad XCD 35-100mm vs 90mm vs Sony 50-150mm GM
I suspect that many of you had a series of primes prior to purchasing the 35-100mm zoom. No surprise here, but when shot wide open for portraiture the 90mm provides slightly better sharpness and micro-contrast as well as better ergonomics and the zoom provided more flexibility and marginally better continuous autofocus. These were Manny Ortiz’s conclusion when both XCD lenses were shot wide open. What he didn’t do was evaluate them outside of the fast aperture, portrait distances and the studio. Manny states that the Hasselblad zoom was the second best zoom that he ever used. The Sony 50-150mm GM was the best. It seems that the Sony barely managed mention on these forums. I’m guessing that price, size and weight resulted in few of us purchasing. Anyway, lots of use cases for the zoom and various primes. The 90mm is a wonderful lens with great bokeh.. and the 35-100mm is one big and ergonomically challenging lens. Are you selling your Hasselblad primes?
?si=KP92lmyY8u8ryBbk
Jun 01, 2026 at 07:48 AM
RoamingScott
p.1 #2 · Hasselblad XCD 35-100mm vs 90mm vs Sony 50-150mm GM
I would never pick between a 28-80 and 50-150 for the same job, so how the Sony stacks up is pretty irrelevant.
Jun 01, 2026 at 08:47 AM
Ne314satel
p.1 #3 · Hasselblad XCD 35-100mm vs 90mm vs Sony 50-150mm GM
Full-format cameras are rapidly approaching medium-format in sensor quality. Medium-format Hasselblad lenses are also rapidly declining in optical quality (even compared to old XCD lenses). For now, Phase One cameras remain the true medium-format camera in terms of image quality (not resolution).
Jun 01, 2026 at 08:57 AM
bwcolor
p.1 #4 · Hasselblad XCD 35-100mm vs 90mm vs Sony 50-150mm GM
Not sure what is rapid regarding full frame cameras, but we have seen faster sensor readout times, better dynamic range and a slow increase in sensor resolution, but these are all characteristics that involve many tradeoffs. Sensor photosite density is a pretty tough bit of physics to work around and so larger sensors will have some real world resolution advantages and smaller sensors will have faster readout times. The current Hasselblad X2Dii/XCD design favors a smaller/lighter medium format package. Slight optical compromises have entered here, much like in the full frame world, where some optical distortions are addressed through firmware. I sold my A7CR, but still own a number of fine, but small lenses. The same design considerations apply to my small Sony and Sigma lenses that apply to the newer XCD lenses. Lastly, I am greatly drawn to the leaf shutter and will probably retain this bias until there is a high resolution global shutter with any light source sensor. So, there is a market for both full frame and medium format. I think that the risk for both is that Sony is the prime supplier of sensors, with a bit of a nod to Canon, but Sony’s eye is on emerging sensor markets, such as self driving cars and perhaps winning back smartphone sensor business. It will be interesting to see what compromises Leica is willing to make when it goes back to using non-Sony sensors. In short, as you said, everything is improving, but I’m hoping that the camera market can find some sensor/electronics innovation outside of the Sonysphere.
Jun 01, 2026 at 10:29 AM
bwcolor
p.1 #5 · Hasselblad XCD 35-100mm vs 90mm vs Sony 50-150mm GM
Agreed.. I was hoping that someone would sing the praises of the 50-150mm GM in that it seems that few have/use this lens. On paper it is an amazing lens.
Jun 01, 2026 at 10:38 AM
SlowDriver
p.1 #6 · Hasselblad XCD 35-100mm vs 90mm vs Sony 50-150mm GM
I just did a road trip of a month. I took the 28P, the 38V and the 75P with me. I only used the 28P on one occasion. I normally use the 38V all the time, and that was mostly also the case on this trip, but there were stretches where I ended up continuously swapping between 38V and 75P. Having a 35-100 handy would have been convenient, and it is definitely on my list now whereas it wasn't before the trip. I also took a non-Hasselblad longer lens solution with me which I probably used on 5 occasions. Not a lot, but when you need it you need it. I sincerely hope a 100-200mm or 100-250mm is in the works. I am not selling my primes but I might add the 35-100 to the toolbox.
Jun 01, 2026 at 10:50 AM
Ne314satel
p.1 #7 · Hasselblad XCD 35-100mm vs 90mm vs Sony 50-150mm GM
bwcolor wrote:
Sonysphere.
My thought was that Hasselblad didn't create a professional line of new XCD V-lenses – they were lightweight and convenient, but their optical quality was inferior to the older lenses XCD. Lenses like 80/1.9 ​​or 90/3.2 are already legendary. Unfortunately, there was no comparison with the 90 3/2 or 80/1.9 ​​(and 45p and 65/2.8 too) in this video - those lenses would have killed this zoom.
That's why I really like some Fuji lenses for medium format, but the overall photo quality was better with Hasselblad. With the new XCD V-lenses, I no longer say that. Therefore, the Phase One sensor and excellent optics are a significant leap in quality (and price) from small medium format and full format.
Jun 01, 2026 at 11:33 AM
SlowDriver
p.1 #8 · Hasselblad XCD 35-100mm vs 90mm vs Sony 50-150mm GM
...Show more →
Hugh Brownstone tested this zoom and he came to the conclusion that on the X2D II it outresolved the APO Summicron-SL 35mm on the SL3.
If you don't mind that is good enought for me...
The P and the V lenses might not be perfect lenses but they are still very very good lenses.
Jun 01, 2026 at 11:51 AM
bwcolor
p.1 #9 · Hasselblad XCD 35-100mm vs 90mm vs Sony 50-150mm GM
...Show more →
Not sure how we should define professional, but if I understand you correctly, Hasselblad created heavier & older lenses that are more optically perfect that might best serve the obsessive landscape photographer that would have been and might still be using 8X10 film cameras. They also make more portable lenses that serve those that need to compromise a very slight amount of optical quality that makes their cameras useful for those that might have used the Mamiya 7 (ii), Bronica RF645 shooters of the film era. Personally, I still shoot the Hasselblad, Mamiya, Bronica and Leica cameras. I’ve always preferred a more portable solution. So, high praise for Hasselblad’s lineup. I just hope they don’t lose their way under Chinese ownership and the same wish for Leica post sale.
Jun 01, 2026 at 12:02 PM
RomanMF
p.1 #10 · Hasselblad XCD 35-100mm vs 90mm vs Sony 50-150mm GM
I recently used the 35-100 for a few days and came away mostly positive on it. It's chunky and Hasselblad should have added rubber to the zoom ring (or made their cute little Hs convex) to improve the handling, but it's a super useful range and the image quality results are fantastic. I've been lukewarm on the 55V since I got it, and it did make me think about ditching that and the 90V to simplify my setup. I decided to cover an event with it on the X2D II, it was a hot day, I had no artificial light, no assistant, just pure run & gun stuff. It kept up well, the camera got quite hot, but never shut off, and the continuous AF was solid. Again, it's no Sony, but it's a smidge stickier than the other 3 primes I own (25V, 55V, and 90V).
Event: https://www.rmf.studio/events/laf-voterace
Jun 01, 2026 at 03:24 PM
Pkash
p.1 #11 · Hasselblad XCD 35-100mm vs 90mm vs Sony 50-150mm GM
I have used the older xcd lenses and currently the V lenses. I have the 38, 55 and 90. Compared to the 80mm 1.9 the 90 V is slightly sharper especially in mid zone and corners but it is very harsh and contrasty. The 55mm is the weakest of the V lenses. The older lenses have a more sublime rendering. The V lenses also have other optical comprises to accommodate the smaller size. I also had the zoom but sold it. The zoom mirrors the characteristics of V lenses and in addition it’s heavy but it’s a personal choice. The resolution and the files are unbeatable though.
Ps. I have the SL apo lenses and the Hasselblad lenses do not even remotely compare to them optically. The X2d out resolves the SL3 even though they have the same pixels, not sure how to explain. No I am not on the Leica forum.
Jun 03, 2026 at 07:03 PM
bwcolor
p.1 #12 · Hasselblad XCD 35-100mm vs 90mm vs Sony 50-150mm GM
“Ps. I have the SL apo lenses and the Hasselblad lenses do not even remotely compare to them optically. The X2d out resolves the SL3 even though they have the same pixels, not sure how to explain. No I am not on the Leica forum.”
The SL APO lenses are praised by all, but I don’t understand how this lens on a much lower resolution camera can out-resolve the better XCD lenses ( not saying better than SL APO..that statement can’t be proven one way or the other given the mismatched sensors ) on a much higher resolution camera. I understand that the better Hasselblad lenses are also APO, but no marketing claims as we see with Leica.
Jun 03, 2026 at 07:51 PM
RoamingScott
p.1 #13 · Hasselblad XCD 35-100mm vs 90mm vs Sony 50-150mm GM
@RomanMF the Hassy just shines for midday natural light, it's rare to see a camera that renders that kind of light SO accurately. Glad to hear it performed well.
Jun 03, 2026 at 08:11 PM
tsdevine
p.1 #14 · Hasselblad XCD 35-100mm vs 90mm vs Sony 50-150mm GM
I have the 50-150, but don't have any Hasselblad equipment to compare it to. I rented it soon after it was released, and then bought the rental.
I shoot it a fair amount and enjoy the images it produces and its flexibility. I consider it to be one of my best zooms.
I'm not the typical shooter that this lens was probably intended for though, so my feedback may not be very relevant.
Jun 03, 2026 at 09:29 PM
SlowDriver
p.1 #15 · Hasselblad XCD 35-100mm vs 90mm vs Sony 50-150mm GM
For some reason I don't seem to be able anymore to quote posts anymore... To PKash:
We don't shoot lenses in isolation, so again, why should I care if as you put it the resolution and the files are unbeatable anyway?
You say that the 35-100 mirrors the characteristics of V lenses. How does that show in the 2 attached files? The images look great to me.
Jun 04, 2026 at 05:40 AM
tsdevine
p.1 #16 · Hasselblad XCD 35-100mm vs 90mm vs Sony 50-150mm GM
I had the same issue last night, and now, so it's not just you. I cobbled together a quote manually yesterday.
Jun 04, 2026 at 06:15 AM
dalegaspi
p.1 #17 · Hasselblad XCD 35-100mm vs 90mm vs Sony 50-150mm GM
here we go again...why are we comparing the 35-100 to the 50-150?
apples, meet oranges.
"Hugh Brownstone tested this zoom and he came to the conclusion that on the X2D II it outresolved the APO Summicron-SL 35mm on the SL3."
that information absolutely brings no value to anyone. the two camera and lens combos were built for different use case and target market. why on earth would i lug around a big-ass zoom if my use case calls for a fast 35/2?
also.. Hugh Brownstone? seriously? i wouldn't listen to whatever that guy says...but that's just me.
Jun 04, 2026 at 06:31 AM
bwcolor
p.1 #18 · Hasselblad XCD 35-100mm vs 90mm vs Sony 50-150mm GM
Tim:
I love what you do with the 50-150mm. I’ve never traveled with such a heavy/large lens, but your results are impressive. Maybe other ways to capture the flowers, but this lens sure brings the micro-contrast, colors and contrast.
Why did you choose the 50-150mm vs/or in addition to the 70-200mm GM ii? Was it simply the f/2.0, or performance with teleconverter? I appreciate your insight.
Edited on Jun 04, 2026 at 07:27 AM · View previous versions
Jun 04, 2026 at 07:13 AM
SlowDriver
p.1 #19 · Hasselblad XCD 35-100mm vs 90mm vs Sony 50-150mm GM
The Summicron-SL 35mm is his reference lens for testing all other lenses against... and he is a huge Leica fanboy, so I felt and still do feel his comments are relevant...
The zoom is relatively lightweight and only 144g heavier than the Summicron-SL, and f2.8 on medium format is very close to f2 on full frame, not that much difference really...
About the different target market, Leica has always positioned the SL against medium format systems like Hasselblad. There are a lot of people who own both. Even though both systems are (in my opinion very) different, I at the same time also believe to a large extent it is the same target market.
Jun 04, 2026 at 07:16 AM
tsdevine
p.1 #20 · Hasselblad XCD 35-100mm vs 90mm vs Sony 50-150mm GM
bwcolor wrote:
Tim:
For a long time, I've generally gravitated to primes, generally smaller "f/2"'ish type lenses. The Sigma 28-45 f/1.8 intrigued me, so I bought one. Turns out I really enjoyed the flexibility of prime like performance in a faster than normal zoom lens solution. Sure it's a bit big and heavy, but it's lighter than my CV 28/35/50 trio combined. I had a lot of fun shooting that lens. So when the 50-150 f/2 was announced...I was a bit more intrigued than I would have been had I not bought the Sigma. No way I would have dropped that kind of money on more of an experiment. I don't shoot a ton of telephoto, that's more of a niche "with purpose" type shooting style for me. The difference between 50mm and 70mm as a starting FL is noticeable for me. So timing wise, we were going to Michigan for vacation...the lens was available to rent. So I figured, why not? Yes, arguably it's heavy, but it feels lighter than it looks (which doesn't matter in the bag though I guess). The rental looked brand new.....and I couldn't bring myself to send it back.... So I pulled the keep option on the Lensrentals rental.
I have a Mindshift PhotoCross 15 that harkens back to DLSR size equipment. I can put the Sigma 14-24, 28-45 and Sony 50-150 in that bag and I have arguably near prime performance in 3 lenses with a lot of flexibility. You have UW to wide in one lens, slightly wide to near normal in another, and near normal to telephoto in just those 3 lenses. All relatively fast, granted the 14-24 is just f/2.8 but for an UWA zoom lens, it has excellent performance.
I haven't used the 70-200 GM II much since buying the 50-150. But the 70-200 takes TCs (I have the 1.4x) and the 50-150 doesn't. So I hesitate to sell it. But unless I want the longer coverage of the 70-200 (with or without TC), I'll grab the 50-150 every single time.
I find the difference in f/2 and f/2.8 is noticeable from a blur perspective. It won't blow out backgrounds as much as a f/1.4, but I don't feel I absolutely need that.
I don't take it out on every outing, and I'm splitting time between GFX and Sony, but it definitely gets in the mix. I'm not taking it on vacation this year, no slight to the lens. But going to Maine this year and given my shooting there, I have a slightly different mix of equipment than what I took to Michigan last year.
I tend to be a bit "abnormal" when it comes to the amount of equipment I'm willing to carry.
Some shots with the 50-150. There is quite a mix, but you have to slog through 2 pages to see it.
https://www.flickr.com/photos/timdevinephotography/albums/72177720327185783/
Edited on Jun 04, 2026 at 08:51 AM · View previous versions
Jun 04, 2026 at 08:26 AM
       2       3       4       end
       2       3       4       end
