       2       3       4       end
Anyone here shooting anamorphic stills?
pingflood
p.1 #1 · Anyone here shooting anamorphic stills?
Just curious to hear if anyone is actively doing this. Have seen a few discussions regarding them but so far haven't seen a lot of finished work. Got this idea to get a Blazar Remus 50 (PL mount) and adapt to my M10 Monochrom. Should yield a horizontal angle of view not too far off the 35mm I am used to. It being PL mount lets me use it on the S1R as well. With the S1R I can probably desqueeze the image on an external monitor I have which might aid in composition.
Am aware that this is not the path to ultimate IQ but I am very curious as to how street/city shooting on the M10M might work out with it.
Thoughts?
Edited on May 31, 2026 at 12:05 PM · View previous versions
May 31, 2026 at 05:48 AM
thrice
p.1 #2 · Anyone here shooting anamorphic stills?
If you want an M mount solution the Panomicron Bismuth is coupled, single focus and compact.
May 31, 2026 at 06:09 AM
pingflood
p.1 #3 · Anyone here shooting anamorphic stills?
I looked at it but it’s about twice the price and they aren’t shipping yet. Don’t feel like I need rangefinder coupling either.
May 31, 2026 at 07:47 AM
bjhurley
p.1 #4 · Anyone here shooting anamorphic stills?
There's a Flickr group devoted to anamorphic lenses in photography; some really amazing images there on digital and on film: https://flic.kr/g/3gH6W2
Loads of anamorphic lenses are available in PL, Canon EF, or mirrorless mounts, not so much for other mounts. There's also the SLR Magic adapter but image quality suffers and it has some other limitations. In some cases people are using anamorphic projection lenses attached to conventional lenses, which might be an option for M mount if you have a digital M and can use live view for focusing.
May 31, 2026 at 08:09 AM
ftllens
p.1 #5 · Anyone here shooting anamorphic stills?
I did use a lot of 2x and 1.5x scopes in the early GFX100 days, but switched to sphericals. But with the Mercury Atlas and Kaizen, I'm looking to re-enter it, though I would just grab stills in Resolve from footage (primary workflow now).
I still have my Leitz PL-M adapter, but haven't tried any of the newer compact scopes, I like the DZO Arcana that was just released for the size and look.
That Bismuth is actually genius cause the RF bypasses the desqueeze preview. All it would have to do in the cams is bring up the 35mm frame lines and framing would be pretty accurate too
May 31, 2026 at 08:33 AM
markhout
p.1 #6 · Anyone here shooting anamorphic stills?
Interesting! Had not heard of this before. The Bismuth is great for M but beyond my budget as anamorphs are for me still an experimental project - money-wise I am looking at the Sirui line.
But the Alum (https://www.panomicron.com/alum-anamorphic) looks worth considering for my on my Distagon 1.4 35mm.
I did not see any examples on the project page - as this is v3, has anyone any experience with the Alum?
May 31, 2026 at 09:18 AM
fjablo
p.1 #7 · Anyone here shooting anamorphic stills?
@josh-himes does!
https://www.fredmiranda.com/forum/topic/1931775/1?keyword=anamorphic#16978914
May 31, 2026 at 09:35 AM
bjhurley
p.1 #8 · Anyone here shooting anamorphic stills?
A few other companies make 1.33 front adapters, notably Laowa. The Laowa is designed to optimize image quality and brightness, and has a control dial so you can place flares where you want them. It has a 77mm thread but comes with step-up rings for lenses with 55mm or 62mm threads. It's desgned to be used with their Nanomorph lenses to bring them up to 2x, but can be used with any lens (although I'm not sure which focal lengths work best).
Look up the Laowa 1.33x Front Anamorphic Adapter (I'd link to it but it automatically goes to my reseller in Canada so you'd see the prices in Canadian dollars).
Edited to add: looks like you need at least a 50mm lens to avoid vignetting on full-frame with this adapter.
May 31, 2026 at 09:56 AM
pingflood
p.1 #9 · Anyone here shooting anamorphic stills?
Saw that Sirui was doing 62% off the Saturn and Venus line so ordered a Saturn 50mm in L mount for 549 eur. It obviously won’t work on M but I can at least get a feel for whether I like shooting anamorphic using it on the S1R.
Jun 02, 2026 at 07:24 AM
hanay78
p.1 #10 · Anyone here shooting anamorphic stills?
Thank you very much for this thread. I discovered anamorphic thanks to this, knew nothing about it, but trying to get informed.
I am trying to discover if there is some small adapter that makes sense to take panoramic pictures, with small lenses, loxia or M-mount like.
Anyway it is a very very interesting topic!
Jun 03, 2026 at 03:20 PM
RoamingScott
p.1 #11 · Anyone here shooting anamorphic stills?
I wrote to Sirui to see if they'd like to work together on the Astra line, because I have some ideas about this genre that I haven't seen done yet...the biggest issue is that basically no stills camera has desqueeze internal, though there are number of remote shutter type apps that can help if you don't want to lug a monitor around.
Jun 03, 2026 at 03:24 PM
josh-himes
p.1 #12 · Anyone here shooting anamorphic stills?
This is a good place to start. I have all of the Saturn lenses in both E & L mounts and they are really excellent for the price. They are what I use for most of my work, as they are much easier to use and more dependable than the various anamorphic adapter solutions. I would also look at the 35, as it is really small & light with great IQ.
With that said, Anamorphic adapters give you the most flexibility and usually will deliver more interesting results than the Sirui lenses.
I use Anamorphic adapters on M mount & Nikon lenses across several camera systems. If you want to see shots from various anamorphic adapters and lenses on multiple systems (RED/Leica M/Sony/Lumix), take a look through these albums:
https://flic.kr/s/aHBqjCDyJ2
https://flic.kr/s/aHBqjCwKZu
https://flic.kr/s/aHBqjCh5Dt
https://flic.kr/s/aHBqjCgNeC
https://flic.kr/s/aHBqjBVLWc
Jun 03, 2026 at 04:03 PM
bjhurley
p.1 #13 · Anyone here shooting anamorphic stills?
I love your work with anamorphics!
I wonder how these adapters can work on M mount if you don't have a camera with Live View, since my understanding is that you need to ensure horizontal flare alignment and correct image compression, and for some adapters it can be hard/impossible to do that without actually looking through the lens. Plus you'd need Live View for focusing the adapter.
I guess a lot of these adapters also vignette on full-frame cameras with wider lenses.
I'm interested in trying an adapter on a film camera; easy enough with an SLR but I'm not sure how it would work with a film rangefinder camera. I know some of these adapters are quite heavy as well; I have a baseplate and rails so I could mount the adapter on that to take strain off the camera's lens mount, but I think that would only work for lenses with internal focusing (i.e., the length of the lens doesn't change as you focus, nor does the front element rotate). It's possible to desqueeze a TIFF film scan in Resolve, Photoshop, etc.
Jun 03, 2026 at 04:19 PM
freaklikeme
p.1 #14 · Anyone here shooting anamorphic stills?
I bought the Saturn 35 for the same reason, mostly for the FX3, but I did use it a bit on the a1. The 1.6x I didn't find difficult so far as focus and depth since it's not a particularly fast aperture or long lens. I loaded the Blazer App on my phone in case I wanted to review desqueezed images, but never found the need to open it. Overall, I had good time with the lens and no regrets about owning it, but I found I was more comfortable working out quick, two shot panos when I can with one of my little 35s, or I could shoot wider (with the Loxia 21/2.8, for example) and crop to match the perspective with the only difference in detail captured favoring the Loxia.
Jun 03, 2026 at 04:57 PM
hanay78
p.1 #15 · Anyone here shooting anamorphic stills?
I have enjoyed a lot watching your photographs. The are fantastic, with a very strong visual identity!!!!!
The set of converters you utilized look like brilliant and compact too.
Your set of lenses are also very nice.
Can I ask you, which converter-lens do you utilize with which camera?
I learn a lot from your pictures. thank you very much for sharing!
...Show more →
Jun 03, 2026 at 05:03 PM
josh-himes
p.1 #16 · Anyone here shooting anamorphic stills?
...Show more →
Thank you. There is definitely a learning curve, but nothing that can't be overcome. I'll try to step through my approach below. Warning - information overload ahead.
I have used Anamorphic adapters mounted on M lenses with my M mount film cameras. It's doable, but it is definitely a multi-step process. Nikon bodies are a bit easier just because you have the SLR viewfinder for framing. It still won't provide critical close focus, as focus with anamorphic adapters can be a bit of a black art.
As far as aligning the adapter and checking focus, you definitely need to do that on a mirrorless camera, but it could be almost any system if you are using an M lens. You need precisely calibrated lens-mount adapters to know that the focus settings will transfer across systems, and the Rayqual adapters are the best I've found. I use them for M mount to both E and L and the focus is usually spot on. Once you have your M lens mounted on a mirrorless body, align the adapter by using a flashlight to get perfect horizontal flares and lock it down.
First step for preparing to shoot on the film body is to figure out infinity focus. If you get lucky, that will also be infinity focus on the lens (but not always the case). After that, you are ready to shoot on an M mount film camera, but you will be winging it on framing and close focus. If you care about precise framing and focus, first set up the shot on a tripod mounted mirrorless body by setting the focus and desired framing. Then carefully mount the lens/adapter on the film body and put it on the tripod. You really need a quick release baseplate on each camera to do this efficiently and repeatably. I use Arca mount baseplates on all of my cameras and that allows them to easily be tripod mounted and the framing is usually spot on. This isn't a quick process, but you can do it in the field pretty efficiently once you have it down.
The real hurdle is finding a suitable adapter that can be used on a variety of lenses and has wide coverage. I have some exotic adapters that took forever to find, usually from halfway around the world. The Zeiss Ikon Anamorphot/1.5x is my favorite, but they are very expensive. Usually $2K+. With the right lens (Leica M 50mm Elmar f/3.5), it will cover 50mm on full frame, which is pretty great. But it's not a practical solution for most people.
In my experience, the adapter with the widest coverage is the relatively new Blazer Nero 1.5x. The image quality isn't perfect, but it is totally usable. Image quality is also somewhat lens dependent, so experimentation will definitely be required. Generally, longer lenses will deliver the best results with adapters in general, with 55-75 probably being the sweet spot. I believe they may have stopped making the Blazar Nero adapters, but I see used copies on ebay every few months. These will cover 45mm on full frame with the right lens. I like the newer Nikon 45mm 2.8, as it is tiny and sharp. I use this combo on both Nikon film bodies and mirrorless cameras with good results. Very wide with great flares. Ken Rockwell on Nikon 45
That's why the Sirui 35 is such a winner if you want to go wide on mirrorless - no amount of experimentation with adapters will get you to 35mm coverage on full frame 3:2 and that lens is sharp corner to corner. I even use it for astrophotography with good results. But for film, the Blazar adapter or one of the various PL/EF mount cine lenses are the best bet for wide. Once you get up to around 65-75mm focal length, the options open up quite a bit for adapters. The cine lenses can be great because the focus is well marked and easy to track across different systems once the back focus is calibrated. Some of the newer cine lenses like the Laowa Nanomorph LF have easily adjustable back focus calibration, which is really handy.
De-squeeze is easy for film scans, you can even do it on your phone. That's usually the last step in the process for me. I use a great app called Vertiscoper that can handle DNG, JPEG and video. The developer worked with me to implement a few of my suggested improvements not too long after he released the app and it is an excellent solution.
Anyway, probably way too much to absorb in one sitting, but good luck and let me know if I can clarify anything.
Jun 03, 2026 at 05:43 PM
josh-himes
p.1 #17 · Anyone here shooting anamorphic stills?
Thank you for the kind words. In essence, the beauty of anamorphic adapters is that they are usable across many different systems and formats. I really don't have any that I would exclusively use with only one camera system. See my post above for a little more info on the details.
I have acquired many good lenses over the years during the course of my work, and it's helpful to have a deep library of lenses to experiment with. The Anamorphic adapters are a little more elusive and can be very hard to find. It can also be a challenge to figure out the best methods for mechanical attachment to the lenses which will maximize the optical performance/potential of each combination. I would try to do some more research and gather a little more info. There is a ton of good info out there. Tito Ferradan's you tube channel is a good place to start: https://www.youtube.com/channel/UC8nvNpXmCZmg_YJFkrQsryw
I have tried most of the more common small adapters for 8/16 mm film and these usually work okay on full frame with the right lenses. Baby Bolex & Kowa adapters for 8mm or 16mm are a generally a good starting point for 75-90mm lenses on full frame.
Jun 03, 2026 at 06:02 PM
bjhurley
p.1 #18 · Anyone here shooting anamorphic stills?
Thank you so much, this is really wonderful! I appreciate your taking the time to walk through all of it.
Hopefully in a few months I can post a few examples to this thread; in the meantime I'll enjoy the inspiration from your photos and those of other folks who are using anamorphic lenses for photography.
Thanks again.
Jun 03, 2026 at 06:58 PM
HereIAm
p.1 #19 · Anyone here shooting anamorphic stills?
Anyone want to give this behemoth an adapting shot lol
Jun 03, 2026 at 08:36 PM
josh-himes
p.1 #20 · Anyone here shooting anamorphic stills?
https://i.imgur.com/I2EyIKH.jpg
That's a big boy! Looks like a projector lens with an anamorphic attachment?
Jun 03, 2026 at 09:16 PM
       2       3       4       end
       2       3       4       end
