Architecture with the GFX100s II and GF20-35
fotodik
p.1 #1Architecture with the GFX100s II and GF20-35
I had the opportunity to spend a weekend at the River rock house . The last house designed by Frank Lloyd Wright.
River Rock House
  GFX100S    GF20-35mmF4 R WR lens    23mm    f/16.0    2s    800 ISO    0.0 EV
May 25, 2026 at 06:07 PM
engardeknave
Details
p.1 #2Architecture with the GFX100s II and GF20-35
You would love a shift lens. There's a GF 30/5.6 Tilt/Shift I have never tried because I ceased shooting much around when it arrived. I still want it even though I will never use it.
May 25, 2026 at 09:34 PM
gdanmitchell
Details
p.1 #3Architecture with the GFX100s II and GF20-35
I see two copies of this thread. No one has replied to the other one yet, so if you are quick you can go back and deleted it! :-)
May 26, 2026 at 12:25 AM
q-w-z
Details
p.1 #4Architecture with the GFX100s II and GF20-35
Would love to see shifted picture with proper verticals and sunstars)
But the shot is great even like that (may be a very little to saturated and HDR-ish - to my taste).
Composition is cool.
May 26, 2026 at 01:43 AM
gyoung143
Details
p.1 #5Architecture with the GFX100s II and GF20-35
You can 'correct'verticals in post processing very well, though better to start with a lens that has low or no native distortion rather than one that relies on software correction. You can't simulate a 'tilt lens function in sofware as you are moving the focus plane, bit that's not so useful for archite ture anyway.
Gerry
May 26, 2026 at 06:10 AM
Creative Edge
Details
p.1 #6Architecture with the GFX100s II and GF20-35
great shot, no matter what lens was used. Great composition and great lighting.
May 26, 2026 at 07:33 AM
fotodik
Details
p.1 #7Architecture with the GFX100s II and GF20-35
Thank you. I do have the fuji 30mm t/s but space limitations forced me to use a wider lens.
I did think I got all my verticals correct.
Roy
May 26, 2026 at 12:09 PM
SGinNorcal
Details
p.1 #8Architecture with the GFX100s II and GF20-35
Roy
Kinda funny that the only one who knows what is accurate is you. The rest of us don't know if the rock "point" should be straight or slightly leaning or if the background tree should be straight or a natural lean. It seems to me you have the lines that should be vertical or flat, like the walls and roofline, pretty perfect. Great shot of a cool, historical, house.
May 26, 2026 at 12:17 PM
gyoung143
Details
p.1 #9Architecture with the GFX100s II and GF20-35
Roy
You did, it'sa great shot. I should have made it clear I was speaking generally in response to the other posts.
Gerry
May 26, 2026 at 02:47 PM
fotodik
Details
p.1 #10Architecture with the GFX100s II and GF20-35
I thought I'd show a few more shots. I greatly appreciate all comments.
  GFX100S    GF30mmF5.6 T/S lens    30mm    f/16.0    1/2s    800 ISO    0.0 EV
  GFX100S    GF20-35mmF4 R WR lens    20mm    f/16.0    1/3s    800 ISO    0.0 EV
May 26, 2026 at 03:17 PM
q-w-z
Details
p.1 #11Architecture with the GFX100s II and GF20-35
Really like the 1st shot, with a pile of stones.
May 27, 2026 at 12:30 AM
kenbennett
Details
p.1 #12Architecture with the GFX100s II and GF20-35
Love the lighting and the house. You might want to remove the giant dust spot on your sensor showing in the last two images
May 27, 2026 at 12:43 PM
Peire
Details
p.1 #13Architecture with the GFX100s II and GF20-35
20-35/4 is my favourite lens for architecture.
  GFX100S    GF20-35mmF4 R WR lens    20mm    f/8.0    1/8s    800 ISO    0.0 EV
  GFX100S    GF20-35mmF4 R WR lens    20mm    f/4.0    1/15s    200 ISO    0.0 EV
  GFX100S    GF20-35mmF4 R WR lens    20mm    f/4.0    1/15s    400 ISO    0.0 EV
  GFX100S    GF20-35mmF4 R WR lens    20mm    f/4.0    1/13s    800 ISO    0.0 EV
  GFX100S    GF20-35mmF4 R WR lens    20mm    f/8.0    1/40s    100 ISO    0.0 EV
May 28, 2026 at 03:18 AM
mabra
Details
p.1 #14Architecture with the GFX100s II and GF20-35
Thanks, Peire, for sharing the photos. While the interior shots work perfectly, the exterior shot looks artificially distorted. Even though straight lines are certainly sensible and desirable in many shots, I would argue that it always comes down to the individual image. In some shots—like your exterior one—it strikes me as a case of too much of a good thing, and I might personally opt to forgo such heavy post-processing correction.
May 28, 2026 at 03:44 AM
Peire
Details
p.1 #15Architecture with the GFX100s II and GF20-35
mabra wrote:
Peire wrote20-35/4 is my favourite lens for architecture.
Well,in this case distortion was not corrected at all,so no heavy or any post-processing of this kind was applied.Anyways there is no other better genuine Fuji GF lens for this purpose as far as I see it.
May 28, 2026 at 06:07 AM
olegkin
Details
p.1 #16Architecture with the GFX100s II and GF20-35
With the GFX, I often photograph street and architecture scenes in vertical orientation, then use only the upper portion of the image as a horizontal frame to simulate a shift-lens effect. Even after cropping, the file is still having tons of pixels. Does not look like this would be needed here though.
May 28, 2026 at 07:04 AM
mabra
Details
p.1 #17Architecture with the GFX100s II and GF20-35
Okay, I understand. But then again, depending on the subject and perspective, wide-angle lenses can sometimes distort so heavily that it looks unnatural—even if nothing was digitally manipulated afterwards. That seems to be the case with the last photo.
May 28, 2026 at 08:34 AM
gyoung143
Details
p.1 #18Architecture with the GFX100s II and GF20-35
mabra wrote:
Peire wroteWell,in this case distortion was not corrected at all,so no heavy or any post-processing of this kind was applied.Anyways there is no other better genuine Fuji GF lens for this purpose as far as I see it.
Some wide angles have OPTICAL distortion, especially zooms, usually corrected by software and you don't notice it, although sometimes it's not done well.
A really wide angle can give you a view that is not a natural perspective rendering, because you aren't seeing things like that, you see in 3d, the camera in 2d. That in itself is not 'distortion'. Some do it well, some don't ( circular objects rendered oval for instance) and then its distortion. I don't see any of that in the last picture, in fact in 'draws' extremely well for a zoom..
I spent a lot of my pro career using a Sinar and Super Angulons for architecture These photos look very good to me. On my aps-c Fujis I love the 14mm for its optical qualities, and the 9mm Laowa for 'super wide'
Gerry
May 28, 2026 at 02:32 PM
mabra
Details
p.1 #19Architecture with the GFX100s II and GF20-35
I spent a lot of my
...Show more →
Hello Gerry, I also think that the GF20-35 is an excellent lens that exhibits relatively little distortion. Nevertheless, distortion naturally occurs when you get very close to subjects—such as the building in this case. For this very reason, Bernd and Hilla Becher for example always photographed their industrial structures from a greater distance using longer focal lengths, precisely to capture the most neutral and undistorted image of the building possible. Conversely, if you approach the building at very close range using an ultra-wide-angle lens, distortion will inevitably occur, and you will never achieve a neutral representation—no matter how high-quality the lens you use may be.
May 29, 2026 at 06:40 AM
AZSteve
Details
p.1 #20Architecture with the GFX100s II and GF20-35
It would help to note that an image that has no rectilinear distortion can look unnatural. An image from a pinhole camera has no rectilinear distortion, but has what looks like radial stretching in the periphery of the image if the pinhole is close enough to the image plane. As the Kodak publications used to note, if you put your eye close enough to the print (screen here!) the stretching goes away and the image looks "right" or "natural."
In a photographic context, lots of us, including Peire and me, tend to reserve the word "distortion" for defects such as pincushion and barrel distortion. Architectural photographers back around the turn of the 19th to the 20th century used short focal length symmetrical lenses with little rectilinear distortion and accustomed many of us to the look of the images under discussion here. Others, like the Bechers, tried to avoid such.
May 29, 2026 at 10:48 AM
Switch to mobile view
