p.1 #1Subjective Fujifilm X100vi review for street photographers
Before getting the X100vi I read a bunch of reviews, after all it's not new. And yet, it still surprised me, so I decided to document my experience and share it with whoever's in my shoes, i.e. evaluating it for street/documentary type of photography.
This is a highly opinionated camera with serious limitations aside from having the fixed lens, and therefore it's not a good fit for everyone.
Let’s start with the good. Yes, the SOOC JPEGs are phenomenal — especially if you spend some time experimenting and tweaking the settings for the JPEG engine. I took the camera on a two-week trip to Europe and was able to get great results without having to re-process the RAW files. The colors, tonal curve, and film simulations are all as excellent as people say. The film grain simulation is also very well done (I shoot a lot of film as well).
The form factor is unbeatable: it’s somewhat pocketable and light enough to dangle on your wrist strap all day. The fixed 35mm lens takes full advantage of being integrated into the camera body — it’s sharp, compact, and fast for its size. And the optical finder works, it's practical and well implemented.
I was quite worried about the 40mp sensor; so many pixels in a smaller APS-C area seemed excessive. I was expecting more noise and generally lower "pixel-level" image quality ruining my pixel-peeping habits. I did not do any instrumented tests, but in real life RAWs at ISO 125-3200 delivered everything I needed out of them. I'd say my final results were identical to 26MP files from my X-T3, but offer more resolution.
I give it 4 stars out of 5. Why not 5 then? TL;DR: This is a slow camera to shoot with. Even in single-shot, AF-S mode, it's not fast. If you have at least 3 second budget to prepare for every shot, this may not be a limitation you care about. In my case, I like walking around with a camera close at hand, and if I see something interesting developing, I often only have 1–3 seconds to react. The X100VI is just too unpredictable to work reliably in those situations. Sometimes I get the shot; sometimes I don’t.
Here’s what makes it slow:
First, the autofocus. It’s not bad, actually. But it was unpredictable. Under the same lighting conditions, often just a couple of minutes apart, it would take a variable and unpredictable amount of time to lock focus. Most of the time it’s near-instant; but once in a whilevit takes a whopping second to focus on a seemingly identical well-lit scene.
Another issue is how the powered-on camera reacts to light changes. If you rapidly move from a shadow or dark area into bright light, or simply pull it out of a bag into sunlight, the X100vi takes 3–5 seconds to slowly “come to life.” The LCD and EVF go completely white for a while, and frame lines disappear in the optical finder, before gradually adjusting and becoming usable again. This is incredibly frustrating when you’re moving through contrasty scenes.
Also, if you tweak the JPEG engine settings, especially Clarity, the camera takes a full second to process each image after you press the shutter. This makes it impossible to fire off two or three shots in quick succession. You can change the settings to minimize or avoid this lag, you can even make it instant by turning off JPEG entirely. But doing so kind of defeats one of the main advantages of the camera in the first place.
The autofocus box is controlled by the joystick on the back, but the stick protrudes too much, so it constantly brushes against your clothes, camera bag, or anything else. As a result, when you raise the camera to an eye level, the AF box is usually somewhere off in the corner of the frame, requiring extra time to reposition. To avoid this, you can turn it off between shots, which makes it slower in operation.
Finally, there are some ergonomic paper cuts: While the ON/OFF switch is a fairly standard design similar to Nikon and Sony cameras, it’s not implemented as well — it takes noticeable effort to flip the switch and it’s not as grippy as in other cameras. The same goes for the LCD screen. There’s only one small designated area where your finger has enough traction to lift the screen, whereas on my other cameras the screen flips with no effort: grab anywhere.
Each of these issues individually isn’t a big deal and you can adjust to, but together they compound into an overall fairly sluggish picture-taking experience. I often couldn't keep pace with what was in front of me. Unfortunately, this camera is not a great street/documentary machine, even though its form factor seems ideal for that purpose. I just sold mine. But for a more slower and deliberate shooting style it's hard to beat its unique combination of size, optics, and IQ.
P.S. I would also add that one month is not enough to **truly** learn a camera. Perhaps there are hacks and settings to address some of the speed-impeding shortcomings I discovered. Please share them below, possibly triggering deep regrets on my part If that happens I don't mind re-buying it.
p.1 #3Subjective Fujifilm X100vi review for street photographers
Nice photos.
I have quite similar experience from 5 years with X100V. Before V I had F - frankly it was not much different. But hey, it is all about incremental evolution
Despite some usability shortcoming and mediocre AF performance, the camera is very nice to travel with. It is really surprising that Fuji has been able to dominate the X100-niche alone for more than 15 years!
p.1 #4Subjective Fujifilm X100vi review for street photographers
i just picked up mine yesterday, and have extencivly set up the camera like my sony a7iv that i use for pro work. 1 google serach and the slow 1 second lag was solved, all that is needed is just set clarity to "0" and now the camera is instant. its raining so no image taking today outside, but the form factor is great and the optical vf is to die for. so far its quite fast and video seems very good as well. its a total nightmare to set up, i thought sony was complicated ,this is way worst to get the camera set, but once its set its works smoothly.
p.1 #6Subjective Fujifilm X100vi review for street photographers
As A74me said - this is just Clarity - you can't turn off JPEG but you can set Clarity to zero.
Nice review.
May 18, 2026 at 01:20 AM
RoamingScott
Activity
[X]
Details
p.1 #7Subjective Fujifilm X100vi review for street photographers
Oh Clarity, the bane of every novice Fuji shooter for the better part of 20 years
p.1 #8Subjective Fujifilm X100vi review for street photographers
I would send Fujifilm real money if they put a warning on the Clarity setting across all their models. Imagine the time it would save new users – and longtime users helping new users
p.1 #9Subjective Fujifilm X100vi review for street photographers
highdesertmesa wrote: RoamingScott wroteOh Clarity, the bane of every novice Fuji shooter for the better part of 20 years I would send Fujifilm real money if they put a warning on the Clarity setting across all their models. Imagine the time it would save new users – and longtime users helping new users
It is part of the "in-camera processing" hype that Fuji cultivates with their film simulations. A camera should create an image that is as close to reality as possible and leave editing for later.
p.1 #10Subjective Fujifilm X100vi review for street photographers
Whom would that be for? Everyone has access to Google. I have looked up the clarity effect within an hour of receiving the camera in the mail. It is not exactly a mystery.
It will not help those who want +1 clarity and great OOC JPEGs.
p.1 #11Subjective Fujifilm X100vi review for street photographers
old-gregg wrote: highdesertmesa wroteI would send Fujifilm real money if they put a warning on the Clarity setting across all their models. Imagine the time it would save new users – and longtime users helping new users Whom would that be for? Everyone has access to Google. I have looked up the clarity effect within an hour of receiving the camera in the mail. It is not exactly a mystery.
Clarity setting doesn't make great OOC JPEGs, taking a great photo does.
p.1 #13Subjective Fujifilm X100vi review for street photographers
old-gregg wrote: highdesertmesa wroteClarity setting doesn't make great OOC JPEGs, taking a great photo does.It is not up to you to suggest, or even have an opinion of, what I need for great OOC JPEGs.
WTF, dude. Relax. If you need Clarity to make great photos, good for you.
May 18, 2026 at 12:44 PM
RoamingScott
Activity
[X]
Details
p.1 #14Subjective Fujifilm X100vi review for street photographers
Now the Fuji forum gets to meet what we on the Nikon forum have had to endure for the last 6 months.
p.1 #15Subjective Fujifilm X100vi review for street photographers
I wonder if using FUJIFILM X RAW STUDIO can help:
"By connecting a computer installed with FUJIFILM X RAW STUDIO and camera via USB cable, the processor in the camera will be used to process RAW files. Processing time is not affected by any limitations of your computer, and there is no difficulty in batch processing large number of images. Since it offers an optimized environment for the camera, you can get exactly the same image quality as that of the camera including tone, color reproduction, and Film Simulations."
What I mean is shooting raw, and later processing to jpeg (or tif) in-camera, with full access to all in-camera jpeg settings.
p.1 #17Subjective Fujifilm X100vi review for street photographers
highdesertmesa wrote: old-gregg wrotehighdesertmesa wroteI would send Fujifilm real money if they put a warning on the Clarity setting across all their models. Imagine the time it would save new users – and longtime users helping new users Whom would that be for? Everyone has access to Google. I have looked up the clarity effect within an hour of receiving the camera in the mail. It is not exactly a mystery.
It will not help those who want +1 clarity and great OOC JPEGs.Clarity setting doesn't make great OOC JPEGs, taking a great photo does.
Not sure if this was intended to be sarcastic, but the clarity setting is just a way to emulate in-camera what a mist filter would do on a lens.
p.1 #18Subjective Fujifilm X100vi review for street photographers
@ruthenium For context: Yep, shooting RAW solves all problems. I've owned several bodies of this line, starting with the original X100, and always used RAW. But I am primarily a film photographer, and this time I specifically wanted a camera best-suited for trying a JPEG-first workflow, somewhat analogous to shooting slide film.
I like introducing atrificial constraints to my work, like having just one fixed-lens FOV, or committing to just one film simulation for a given period of time. Not relying on RAW makes me pay even more attention to light and exposure. That's the background for me getting the camera. I have my Sonys and Nikons for RAW shooting.
Bumping clarity a bit, flattening highlights, reducing sharpening to zero, and adding grain gives me the look very close to what I get from Delta 100. And the X100VI does all of this in-camera perfectly, but unfortunately penalizes you with the delay.
p.1 #19Subjective Fujifilm X100vi review for street photographers
mdude85 wrote: highdesertmesa wroteold-gregg wrotehighdesertmesa wroteI would send Fujifilm real money if they put a warning on the Clarity setting across all their models. Imagine the time it would save new users – and longtime users helping new users Whom would that be for? Everyone has access to Google. I have looked up the clarity effect within an hour of receiving the camera in the mail. It is not exactly a mystery.
It will not help those who want +1 clarity and great OOC JPEGs.Clarity setting doesn't make great OOC JPEGs, taking a great photo does.Not sure if this was intended to be sarcastic, but the clarity setting is just a way to emulate in-camera what a mist filter would do on a lens.
Yes, it was sarcasm.
Negative clarity is similar to a mist filter, but adding clarity does the exact opposite. It’s a bit of a cliche effect, so not sure why anyone would want to use it in camera when it causes such a long delay between shots. To each their own of course.
p.1 #20Subjective Fujifilm X100vi review for street photographers
old-gregg wrote:
@ruthenium@ For context: Yep, shooting RAW solves all problems. I've owned several bodies of this line, starting with the original X100, and always used RAW. But I am primarily a film photographer, and this time I specifically wanted a camera best-suited for trying a JPEG-first workflow, somewhat analogous to shooting slide film.
Bumping clarity a bit, flattening highlights, reducing sharpening to zero, and adding grain gives me the look very close to what I get from Delta 100. And the X100VI does all of this in-camera perfectly, but unfortunately penalizes you with the delay....Show more →
Thank you! I didn't mean to question your approach. Your explanations are fully in line with my understanding of what you want from the camera. My point is only that the (same) OOC JPG can be obtained in two ways: either at the time of capture, or any time after the capture (by using Fujifilm X raw studio). In other words, there is no real need in shooting raw + jpg. My only Fuji camera is the GFX100S II, and I first started shooting raw + jpg, then changed this to raw only. Any time I need a OOC JPG with any of the effects and jpg settings that are available in camera, I can obtain this by connecting the camera to my Mac and using X raw studio. This is a very simple, easy to use piece of software that is intended to make the camera generate a jpg from raw "on demand." There is even an option of exporting images as tif files.
I have never used the X100VI; thus, I only presume that Fujifilm X raw studio should work with this camera the same as it works with the GFX - give it a try, maybe you would like it.
