DIY Z8 rubber grip replacement?
Masque
p.1 #1DIY Z8 rubber grip replacement?
Alas, my Z8’s rubber grip has done the thing they do: expanded.
I ordered the replacement part from Nikon’s parts site before looking at the replacement procedure — this thing is screwed in! And to get to those two screws, I need to go through the battery compartment from the back. This means taking off the viewfinder, top case, back case, back display, and a main logic board or two.
I’m no stranger to tiny-screwdriver work, but it looks a bit finicky. Still, I’d rather not be without this body for the time it’d take Nikon to complete the service.
Anyone here done this themselves? Tips/tricks would be appreciated.
May 12, 2026 at 12:38 AM
Jman13
Details
p.1 #2DIY Z8 rubber grip replacement?
I have not done the grip replacement in a Z8, so I can’t help you there. I have done a D750, which was a piece of cake.
What I want to know is why Nikon is still using this rubber formula that expands. Like many, I had to replace the corner piece on the Z6 III when it expanded, after less than a year. I’ve replaced a few port doors because they expanded. No other camera brand has this issue. I have Canon DSLRs that are 20 years old and have pristine grips.
May 12, 2026 at 05:10 AM
Masque
Details
p.1 #3DIY Z8 rubber grip replacement?
Was the grip also screwed in from the battery compartment there? I'm interested to hear more.
I haven't had this experience with any prior Nikons; my D70's rubber eventually detached, but that was more an adhesive failure than anything else. I know it CAN happen, and it seems I won a bad lottery this time.
Honestly, with the grip larger and sticking out a bit, it's surprisingly comfortable. Just doesn't look great and sometimes gets caught on things. Meh.
May 12, 2026 at 07:11 AM
sungphoto
Details
p.1 #4DIY Z8 rubber grip replacement?
...Show more →
Yeah, looking at the teardowns of the Z8, I'd be concerned about all the fragile electronics mini connectors. If you're near Seattle, Glazers might be able to turn it around quicker than sending it into Nikon.
I've done a grip replacement on a Sony mirrorless body, and that required removing the back plate, disconnecting the LCD ribbon connector and a few other things. The process was a bit nerve wracking.
May 12, 2026 at 08:51 AM
Jman13
Details
p.1 #5DIY Z8 rubber grip replacement?
Masque wrote:
Jman13 wroteI have not done the grip replacement in a Z8, so I can’t help you there. I have done a D750, which was a piece of cake.
On that body it was just double sided tape, no disassembly required. I would not want to try disassembling the camera to do this.
May 12, 2026 at 09:10 AM
RoamingScott
[X]
Details
p.1 #6DIY Z8 rubber grip replacement?
Subscribe to NPS for a year, they’ll do it as part of included maintenance.
May 12, 2026 at 09:14 AM
jbear
Details
p.1 #7DIY Z8 rubber grip replacement?
I fixed a separating D5 grip with Pliobond and never had an issue again.
May 12, 2026 at 11:52 AM
Masque
Details
p.1 #8DIY Z8 rubber grip replacement?
Yep. The issue here isn't just separation, unfortunately. It's expansion. The grip no longer fits where it belongs.
Still quite comfortable, though.
May 21, 2026 at 07:44 AM
FM ForumsNikon ForumJoin Upload & Sell
Switch to mobile view
