Need help with monitor selection for professional family photography
weezintrumpete
p.1 #1Need help with monitor selection for professional family photography
I'm a professional photographer as of recently, and am shooting family, newborn, and maternity photos. I'm currently using a 30" Apple Cinema Display that I LOVE but it's not that accurate with it's colors anymore. I don't want to get rid of it, but I feel the need to so I can make sure I'm editing my photos correctly.
With all that said, I'm stuck about what monitor to get to replace it. I want at least 27" in size, and would prefer 30", but I don't see many (any) monitors in that size. A hard requirement is for it to be a matte screen. I prefer the look of those screens, like my 30" (so that rules the Apple Studio Display out, unfortunately).
Other than that, I'm not sure. I don't know how important it is to have aRGB coverage, given that my photos are mostly delivered digitally in sRGB, although some clients do choose to print. Most clients seem to have iPhones / Macs, so presumably they are looking at the photos in a P3 color space.
So, what would you recommend? I'd like to keep it under $1500, and ideally under $1000.
Thanks!
May 11, 2026 at 09:04 PM
LarryBeemer
Details
p.1 #2Need help with monitor selection for professional family photography
My experience is limited so keep that in mind.
I have been using a BenQ SW271 since 2019 and I have been very pleased with it. It is easily calibrated using a Datcolor SpyderX calibration tool and it's way of doing the calibration. Unfortunately I did not have much luck using the Palette Master calibration system native to the BenQ line, but they kinda gave up on updating it a few years ago.
Within the last 6 weeks I replaced the 27" monitor with the 32" BenQ SW321 (+/- $2k). The SpyderX coupled with the Palette Master calibration system dedicated to this monitor seems to work quite well with this monitor....so far. I am very happy to have upgraded to a 32" monitor.
As an aside...I use Qimage as my dedicated printing software. It does an outstanding job of making all the color profiles play well together and I get prints that match my monitor every time.
Again....just my experience. Good luck in your search.
LB
May 11, 2026 at 09:32 PM
Sashi
Details
p.1 #3Need help with monitor selection for professional family photography
Another vote for the BenQ SW series. Like LArry, I also have the SW271 and love it
May 12, 2026 at 07:55 AM
John Wheeler
Details
p.1 #4Need help with monitor selection for professional family photography
Having a monitor whose colors are not accurate by itself does not necessarily mean you must get a new monitor especially if you are staying with sRGB.
Here is what can go wrong over time with your monitor.
It uses older CCFL backlighting, not modern LED or mini-LED technology.
CCFL backlights age significantly over time:
brightness drops
white point drifts warmer/yellower
Edge uniformity worsens
gamut shrinks
Many aging 30" Cinema Displays develop a yellow tint or uneven edges.
A modern calibration can substantially improve:
white balance
grayscale neutrality
gamma tracking
shadow tone accuracy
You'll be surprised how much better it can look after profiling.
However, after calibrating, it still has any of the issues below:
obvious yellowing
pink/green tint shifts across the panel
dark corners
inability to hit neutral gray
low brightness even at max
poor shadow separation
flickering or instability
Then the backlight is the limiting factor, and a new monitor would for sure be the way to go.
Just something to consider since you indicated that "you love" that monitor.
John Wheeler
May 12, 2026 at 09:47 AM
weezintrumpete
Details
p.1 #5Need help with monitor selection for professional family photography
...Show more →
Thank you, that is really helpful. I would *really* like a monitor larger than 27", but the cost is hard to justify for me. So perhaps the SW271 or SW272U is it for me. Still a bit expensive, but they seem like some of the best around.
Question for you - is it a true matte display? Or is it glossy glass with some coating applied a la Studio Display nano texture? I'm hoping for a true matte display, like the 30" I have. It makes me think I'm looking at paper in some ways, and I like that.
May 12, 2026 at 10:00 AM
weezintrumpete
Details
p.1 #6Need help with monitor selection for professional family photography
brightness drops
gamut shrinks
white balance
gamma tracking
...Show more →
Thanks for that. I actually bought a calibration device thinking I might be able to calibrate my 30", but after many tries, I just can't get it to look anything like my Macbook Air. I know that the Macbook Air is also likely not calibrated, but ultimately, I'd rather go with something I know I can trust instead of constant fiddling and worrying. But yeah, I do love my 30" and am figuring out what else I can use it for...
May 12, 2026 at 10:01 AM
weezintrumpete
Details
p.1 #7Need help with monitor selection for professional family photography
Anyone here have experience with the Asus ProArt monitors? They seem to be way cheaper than the BenQ, but I assume there's a tradeoff. I'm just not sure whether the tradeoff might be worth it for me.
Here's an example: https://www.amazon.com/gp/product/B0B8YSL9RD?smid=ATVPDKIKX0DER&th=1
$600: 32", 4k, 98% P3, 99% Adobe RGB, Delta E < 2
May 12, 2026 at 02:59 PM
BigBabyMoses06
Details
p.1 #8Need help with monitor selection for professional family photography
Love my ProArts. Have 2 side by side. You absolutely need a color calibrator, however, for any monitor. I use the "cheap" Calibrite 123.
May 12, 2026 at 07:11 PM
weezintrumpete
Details
p.1 #9Need help with monitor selection for professional family photography
Good to hear! Which ProArts do you have?
May 12, 2026 at 08:55 PM
LarryBeemer
Details
p.1 #10Need help with monitor selection for professional family photography
I hesitate to answer your question because I'm not confident that I know what a "matte" screen is. The screen is not really "glossy" but it's not really "matte" either. Perhaps the BenQ site has an official description?
I'm sorry I can't be of more help.
LB
May 12, 2026 at 09:16 PM
BigBabyMoses06
Details
p.1 #11Need help with monitor selection for professional family photography
BigBabyMoses06 wroteLove my ProArts. Have 2 side by side. You absolutely need a color calibrator, however, for any monitor. I use the "cheap" Calibrite 123.
PA278CGV is my primary (144hz which is nice for gaming), and PA278QV is now my secondary.
May 12, 2026 at 09:29 PM
weezintrumpete
Details
p.1 #12Need help with monitor selection for professional family photography
LarryBeemer wrote:
weezintrumpete wroteThank you, that is really helpful. I would *really* like a monitor larger than 27", but the cost is hard to justify for me. So perhaps the SW271 or SW272U is it for me. Still a bit expensive, but they seem like some of the best around.
LB
No worries! It's a bit of an esoteric question. I just love how my 30" display looks, almost like I'm looking at paper. There's some texture to the display, kind of like grain. I love it. Hoping for some of that in a new display, and it seems like the SW272U gets at least part of the way there, claiming that they designed the screen to look a bit like paper.
Just ordered the SW272U and am excited to try it out!
May 12, 2026 at 09:54 PM
weezintrumpete
Details
p.1 #13Need help with monitor selection for professional family photography
Thanks! I noticed that those don't have Adobe RGB color space coverage. Is that a big deal to you? Do you print your photos?
BigBabyMoses06
Details
p.1 #14Need help with monitor selection for professional family photography
It isn't a big deal for me, and no I do not print my stuff yet, but I have sent some photos to printers and everyone has been happy with them so far. But, that doesn't really answer your question, sorry!
May 12, 2026 at 10:14 PM
Switch to mobile view
