Lightroom Lens Corrections Question: Built-in Profile vs “Enable Profi...
MMP
p.1 #1Lightroom Lens Corrections Question: Built-in Profile vs “Enable Profile Corrections”
In Lightroom Classic, I’m noticing in the Lens Correction window that for most of my lenses it shows “Built-in Lens Profile applied” automatically, even before I check the “Enable Profile Corrections” box.
My questions are as follows:
1. What exactly is the difference between the built-in profile that’s already being applied vs. what happens when I manually click the Enable Profile Corrections box?
2. In what situations should I leave it off vs turn it on?
3. Are there cases where the manual profile adds corrections that the built-in one doesn’t?
Would appreciate if someone might be able to offer a more technical breakdown of how Lightroom is handling these two layers of correction and best practices for when to use each.
Apr 29, 2026 at 06:36 PM
pete478888
Details
p.1 #2Lightroom Lens Corrections Question: Built-in Profile vs “Enable Profile Corrections”
There is for instance a slight difference in the new lens LRc lens profile for the Viltrox 14mm 4.0 Air Nikon Z. It corrects some barrel distortion, I was not aware of.
Just try to turn it on and off, and check what result you like more.
Also check whether it does cut part of your image off. Unconstrained in C1 and PL. Scale in LRc.
It all depends on your lens and sample variation and quality of the specific lens profile.
DXO PL is heavily into lens profiles. They are excellent as long as your camera/lens combination is supported.
Apr 29, 2026 at 10:54 PM
Switch to mobile view
