Which Fuji X Body from Nikon?
EB-1
p.1 #1Which Fuji X Body from Nikon?
I'm looking at an upgrade for the D7200 and IQ of D7500/D500. The older cameras are having some issues and also 2 repair cycles or replacements on some older DX lenses. Writing is on the wall for the older gear.
I'm pretty disgusted with Nikon abandoning the DX other than some lowish-grade bodies like the Z50 II and crummy Z cropper lenses, so looking at a Fuji X system. From what I read a while ago the X-H2 (40 MP) and X-H2S (26 MP) were the best, but is that still the case? Is anything new coming in 2026? How is the sensor noise level and AF compared to modern Canon and Nikon or Sony bodies if anyone has such experience. Images will be RAW, converted in DXO. No video is allowed.
The use case would be similar to (hopefully equal IQ and better performance) than the 24MP D7200 with 10-24, 16-80, 80-400, and sometimes a macro. I'm not interested in lower grade lenses with mushy corners at all apertures or a larger/heavier gear set. The 80- or 100-400/5.6 class is the largest for general purposes and good sensor resolution is need for reach.
Thanks,
Apr 19, 2026 at 11:05 AM
Nielk Mike
Details
p.1 #2Which Fuji X Body from Nikon?
The X-H line is a hybrid line for video and stills. So it seems the X-T and X-E line is more to your taste. With today's sensor tech, there will be no difference in IQ between your Nikon cameras and Fuji cameras. You shoot RAW, so color sciences (film Sims) will not be of much importance to you, anyway. Will there be camera updates in 2026? Possibly. But do not expect anything groundbreaking.
Apr 19, 2026 at 11:24 AM
EB-1
Details
p.1 #3Which Fuji X Body from Nikon?
Just from the images online the H look better to use. They have a normal top display and handgrip instead of that archaic retroactive 70s dials. Is there any disadvantage to the H for lenses like the 100-400? Ideally you would want to pick up that combo with one hand on the grip. I just assume the higher price is indicative of better everything unless the sensor or the ARM SoC is older and worse in some other ways. Fuji makes so many models it is confusing.
Is there any significant difference in noise between the 26/40 MP when normalized to the same size? I have plenty of CFe cards so starge not really a problem either way. I do have some concerns if the lenses can well resolve the 40MP or if they are hardly any better than 26MP.
Apr 19, 2026 at 11:51 AM
Nielk Mike
Details
p.1 #4Which Fuji X Body from Nikon?
...Show more →
Fuii is not really confusing: X-H: Hybrid, with X-H2s a bit of special case. X-T: Photography old school. X-E: Compact photography old school. The higher price of the X-H2s is due to the stacked sensor. X-H2, X-T5 and X-E5 are very much the same quality wise.
You won't see a difference between the 26MP and 40MP sensor. All Fuji lenses work the same on both, though the newer f1.4 and f1.2 resolve more and are sharper across at wider apertures. Hard to notice until you pixel peep or crop significantly.
Apr 19, 2026 at 12:32 PM
old-gregg
Details
p.1 #5Which Fuji X Body from Nikon?
@EB-1 I've been shooting with Fuji X cameras since they launched the line, usually having them as a portable system to complement my primary Canon EOS gear, and now Sony E. From the IQ perspective you will not be disappointed, in fact I would say something a bit controversial: the current 40mp X-sensor almost goes head to head against 24-33mp FF sensors when comparing the resulting JPEGs downsampled to the same pixel-size. I am aware of https://www.photonstophotos.net and respect his testing, but I'm saying that the difference is barely perceivable and only when pixel-peeping and under very specific lighting conditions.
The top photographic dog is not the H-series, but the X-T line. At least that's what the Fuji communitiy thinks, TBH primarily due to the difference in the LCD hinge design. The ergonomics is a subjetive thing, personally I am the opposite of you: the top LCD design and press+rotate operations is archaic crap from the 80s when the industry over-corrected towards electronics. The combination of dedicated dials, real aperture rings, and customizeable buttons with the i-menu backup - that's the proper ergos for 2026. The probem is that Sony is now doing this better than Fuji, although they pioneered the concept. Anyway, ergonomically the X-T5 is what is considered the top photo-focused body.
Their weak spot, for all of them (because they all use Fuji's processor), is autofocus. It's 5+ years behind the big 3. For non-moving or predictably moving subjects it works absolutely fine, but you won't have the AF experience comparable to a modern Sony, where you simply point a camera in the direction of the subject and it semi-magically focuses, even if it's a running kid. People who shoot "only-eyelashes-are-in-focus" type of portraits also complaing of AF accuracy with very fast lenses wide open (something I don't do much and can't comment on). But two additional problems I have with the X-line are: badly organized menus and that none of them have a great EVF. The top-dog X-T5 merely matches Nikon's mid-tier FF bodies with just 3.6M @60Hz.
Apr 19, 2026 at 01:01 PM
EB-1
Details
p.1 #6Which Fuji X Body from Nikon?
The lack of the 3rd control dial on top of X-H2 is not good compared to Canon and Sony, though Nikon is currently not implementing on many cameras yet either. It seems that both the X-T5 and X-H2 are 2022 bodies, so probably due for an update.
The shutter speed dial in full stops seems silly, reminding me of the Nikkormat EL, my first camera about 50 years ago. Is it necessary with the three control dials? I would only use a full stop about 1/3 of the time naturally. I hope that shutter/aperture could be mapped to the front/rear dials and the third dial would be EC in auto ISO or ISO in all manual. It really needs to be as right handed as possible with no taking eyes off the viewfinder. It makes sense to have aperture rings on cine or hybrid lenses, but with tele zooms you are supporting the weight of the body and need to be able to constantly zoom, so it's not a good place. This lens would have to be viable.
By bad AF do you mean it is worse than the original R5 and R6 or worse than the Z7, maybe closer to Z7 II? Is it worse than the D500 if you know that one? AF could be the dealbreaker rather the other factors. Has it improved with FW updates?
Edited on Apr 19, 2026 at 03:10 PM · View previous versions
Apr 19, 2026 at 02:45 PM
pw-pix
Details
p.1 #7Which Fuji X Body from Nikon?
I moved from Nikon (D3s and D800E) to Fuji.
My most used camera is the rangefinder style X-E3, it's been great.
The camera you'll probably feel most at home with is the X-H2, it's more akin to the Nikon style dslr and mirrorless bodies. It feels very good to hold, and is well suited to the larger lenses in Fuji's range.
The 40mp sensor is very good (I have an X-T5) and you should be pleased with the results coming from your older Nikon bodies.
The latest series of prime lenses are very good in the modern, clean and sharp way.
XF 18/1.4 R LM WR, XF 33/1.4 R LM WR - 28 and 50mm equiv. would be an excellent starting point.
Some of the older prime lenses are loved for their character and are usually a good buy secondhand.
XF 18/2 R, XF 35/1.4 R, XF 56/1.2 R - 28, 50, and 85mm equiv. would be typical examples.
Given the bodies you are coming from (and Nikon's famous lack of support in DX lenses), I think you'll like the lenses and bodies from Fuji.
Apr 19, 2026 at 03:03 PM
RoamingScott
[X]
Details
p.1 #8Which Fuji X Body from Nikon?
There’s no X system combo that approaches Expeed 7 cameras / Z lenses in terms of performance. You’ll find that AF-S is the most reliable focus mode.
The X-H2S is the only stacked sensor option in their ecosystem but you lose resolution by going in that direction. The X-H2 is the defacto DSLR style option but has a flippy screen. The X-T5 would be what I would get, personally. Many Fuji X lenses will be hamstrung by a combo of lame autofocus motors and a goofy AF algorithm.
Have fun 🫠
Apr 19, 2026 at 03:06 PM
gdanmitchell
Details
p.1 #9Which Fuji X Body from Nikon?
When comparing the XT5 and the XH2, there are some functional differences. The XH2 is more optimized for video, and its deeper buffer could be advantageous for some photographs who rely on long bursts. If those are critical to you, take a look at it.
The interface difference is a matter of preference, as I’ve learned here in some discussions with people whose opinions I respect but who feel differently about it than I do. The XH uses the PASM interface, which is more like typical DSLR and mirrorless cameras from other manufacturers. If you like that interface you may prefer the XH on that basis alone.
On the other hand, many who have been attracted to Fujifilm still cameras came to this gear in large part because we like the so-called “retro” controls — separate dedicated manual controls for things like aperture, shutter speed, EC, ISO. If that interests you, of the three models (XE5, XT, and XH2), the XT5 may appeal to you. (As it does to me.)
The chief plus of the XE5 that almost everyone agrees on is its small size — the smallest of the serious Fujifilm APS-C cameras. It also has the “retro” controls, though without quite as many of them. It appeals a lot to people looking for a travel camera or similar and to some street photographs. It also adds some unusual controls for choosing image style presets and for cropping that may or may not be attractive.
when it comes to pure image quality, the three cameras use the same 40MP sensor so they are arguably capable of producing images of identical quality.
Noise is actually quite well controlled on the 40MP sensor. I’ve used Fujifilm 16MP, 24MP, 26MP, and 40MP cameras, and they have managed to increase the number of photo sites while maintaining good noise performance.
Fujifilm lenses resolve sufficiently for the 40MP sensor, and not just the lenses on the old Fujifilm list of supposed “40MP ready” lenses. Virtually all of the Fujifilm lenses are excellent, and some are standouts. Some excellent lenses that I use include the 14mm f/2.8, 23mm f/1.4, 27mm f/2.8 pancake, 35mm f/1.4, 50mm f/2, 80mm f/2.8 macro, and 90mm f/2. Those last two are truly excellent, as is the 14mm and the 50mm f/2. I have three of their zoom lenses: 16-55mm f/2.8, 50-140mm
f/2.8, and the variable aperture 100-400. The 50-140mm is really top notch, in the same category as the 24-70mm high end lenses from Sony, Nikon, and Canon. The 16-55 is a fine performer too, though my copy of the original version can be a bit touchy. The 100-400 is sort of complicated to describe. Used on the tripod and carefully focused on landscape subjects it produces excellent detail. But when I use it to photograph birds I’m less successful than with my 100-400mm Canon FF lens.
There aren’t really any bad Fujifilm lenses in my experience. There are a few oddball lenses though. For example, the 60mm f/2.4 macro: It can be very sharp, but it is also slow focusing… and comes with a comically large hood.
You might want to look at spec sheets for the three cameras side by side to see how similar their performance is in many ways… and where the difference lie.
I’ve been using Fujifilm x-trans cameras alongside my Canon FF system for over a dozen years.
...Show more →
Apr 19, 2026 at 03:34 PM
WildFokus
Details
p.1 #10Which Fuji X Body from Nikon?
What exactly do you photograph?
I have an XT5, and it’s very similar to the H2. I think the XT5’s autofocus is actually pretty good for wildlife photography. Sure, it doesn’t have a 99% hit rate like the Sony A1, the Nikon Z8, or the Canon R5 II. I’d say it’s a bit behind the A7 IV, but slightly better than the Z6 II.
That should give you a general idea.
But none of that matters for landscape photography—you just take three shots and you’re done. For wildlife, I use 7 frames per second and always get what I want. In AFC mode, I get about 60–70% of my shots in focus with the XT5 when photographing animals. We all know that wildlife photography is a bit more demanding than landscape photography.
But with landscapes or street photography, it’s no problem—I think the hit rate there is 95%.
You should take some test shots with the XF100-400. Some of the lenses are a bit soft at the edges, but newer lenses apparently don’t have that problem anymore. Otherwise, I think the 33mm f/1.4 is very good, and I don’t find it lacking in any way.
All in all, I think Fuji is very well-made and a good choice as an all-rounder. But depending on what you’re photographing, there might be a more suitable system.
New camera generations are reportedly set to be unveiled in September. Perhaps you could be patient and wait for that?
I suspect the first concrete details will be available online very soon.
In the meantime, if possible, I would wait a little longer if I were you.
Apr 19, 2026 at 03:48 PM
Superscroll
Details
p.1 #11Which Fuji X Body from Nikon?
I don't think the z50ii is a lesser body than the Fujis. for sure fuji prime lineup is way better than what nikon offers BUT some of the best Fuji mount primes are Viltrox and they are also producing for the Z mount.
my only advice, and this is based on my experience with the 26mp Fuji sensor, is absolutely get DXO deep prime. IMO it brings those Fuji files to another level.
Apr 19, 2026 at 03:53 PM
tgrantster
Details
p.1 #12Which Fuji X Body from Nikon?
While I understand where you're coming from...my 2 cents is now may not be the best time to jump into Fuji. I currently shoot the X-T3, love the camera. The sensor readout speed is faster than the XT-5 due to the lower megapixels which allows me to shoot preshot at 20fps with the electronic shutter. A feature only now making its way into other mirrorless cameras. ...Fuji used to be way ahead of it's time. The lenses I have meet my needs really well. It's great for travel and can still do sports and wildlife good enough for me. But I bought it right after release and it's now over 7 years old and showing it's age...but I will keep it and the 35 f1.4 until they die. I don't really have a desire to jump to the X-T5 given the issues with Continuous autofocus it wouldn't be that great an upgrade and 40 megapixels isn't a big upgrade for me.
Rumors are they will be upgrading their flagship XT and XH lines towards the end of this year and beginning of next. I would wait and see where they go. I would need to see a very fast sensor that lets me shoot action without rolling shutter so I can use preshot. I'd need to see excellent continuous autofocus. If those things aren't there I'm not waiting around for another 4 years hoping. Sony/Nikon/Canon will be getting looked at...in that order. The fact that the XH-2s is in the same cost ballpark as the new Sony A75 ... that's just wild.
Apr 19, 2026 at 04:33 PM
OffTrail
Details
p.1 #13Which Fuji X Body from Nikon?
Anecdote: My Zf struggled to reliably focus on dogs running at the camera, a task that the D500 excels at. But in every other situation, the Zf's autofocus and subject detection systems are great. Is it's autofocus "worse" than the D500's? For most use cases, of course not. But for one specific action use case? Yeah. And its retro controls didn't help matters when more user input was required.
You haven't said what you shoot, but if it involves much action, your life will probably be easier by sticking with action-oriented bodies. Wait and see what the rumored R7II looks like. That's supposed to be in May or something.
Apr 19, 2026 at 04:57 PM
GravelBen
Details
p.1 #14Which Fuji X Body from Nikon?
As an owner of D7200, X-T3 and Z5ii...
I like the dial interface of the X-T3, image quality is on a par with the D7200 (if I had to discern between them I'd say the D7200 is marginally more detailed and the X-T3 marginally cleaner, but the difference is minimal). AF tracking for action the D7200 is far better, and also a much larger market of longer lenses especially second hand.
So I generally used the D7200 for motorsport and wildlife, and the smaller lighter X-T3 for landscapes and hiking etc. Since getting the Z5ii around 6 months ago I don't think I've used either of them though, planning to sell off the old gear but haven't got around to it yet.
The Z5ii AF blows the D7200 away, and is in a completely different league to the X-T3. I haven't used an X-T5 or X-H2 to compare, but reviews seem to say they are still well behind Nikon/Canon/Sony AF especially for action tracking.
I won't compare sensors as its full frame vs APSC so not a fair comparison.
But if you are wanting to stay with APSC for smaller lighter lenses, don't write off the Z50ii based on some notion of it being 'budget', it and the Nikon Z DX lenses perform very well. Admittedly Nikon aren't making a wide range of DX Z lenses, but Viltrox and Sigma make some nice DX primes for Z mount and obviously you can use FX Z lenses too.
The Z50ii has the same sensor as the D500, and the same processor, customisable controls and AF system (which most consider to be better than the D500 let alone the D7200) as the Z5ii (and very similar to the Z6iii, Z8 etc).
The main areas of compromise in the Z50ii IMO are small battery capacity, no IBIS and IIRC only a single card slot if you care about that.
Apr 19, 2026 at 05:50 PM
EB-1
Details
p.1 #15Which Fuji X Body from Nikon?
The main point here is that the 2022 Fujis are very late in the lifecycle. Since there is no imminent need I will take collective advice and not do anything major now. If an immediate need arises a Z50 II and the FTZ II will work well enough.
Apr 19, 2026 at 07:31 PM
Superscroll
Details
p.1 #16Which Fuji X Body from Nikon?
Indeed the z50ii is not a budget camera, it's just underpriced vs the (imo) pretty rough pricing on the Fuji bodies.
Apr 19, 2026 at 08:27 PM
old-gregg
Details
p.1 #17Which Fuji X Body from Nikon?
Again, I don't want to start an argument over something as subjective as ergonomics, but I hope you're asking the question in good faith. The way I use the dedicated shutter dial is when shooting action:
- Set the aperture to the desired setting
- Set the ISO to auto, but the max ISO is set using the dial
- Now the shutter dial is only used to set the minimum speed required for freezing the subject
You don't need 1/3 of stops for that. Exposure is controlled by the camera's automation using auto-ISO within the range you've defined using the dials. It's quick, intuitive, and all 3 of your settings can be instantly red when glancing at the camera even when it's powered off.
Edited on Apr 19, 2026 at 08:45 PM · View previous versions
Apr 19, 2026 at 08:43 PM
EB-1
Details
p.1 #18Which Fuji X Body from Nikon?
The Z50 II is like the D5000 series, not the D7000 series.
All of them are fairly inexpensive compared to normal cameras like the Z8, R5 II, a7rV for example.
EB-1
Details
p.1 #19Which Fuji X Body from Nikon?
old-gregg wrote:
EB-1 wroteThe shutter speed dial in full stops seems silly, reminding me of the Nikkormat EL, my first camera about 50 years ago. Is it necessary with the three control dials? I would only use a full stop about 1/3 of the time naturally.
- Set the aperture to the desired setting or Auto
- Set the ISO to A
You don't need 1/3 of stops for that. Exposure is controlled by the camera's automation using auto-ISO within the range you've defined using dials. It's quick, intuitive, and your settings are clearly visible even
...Show more →
I am serious. To me auto ISO means only the ISO changes and the aperture and shutter are fixed.
For example I might want 1/2500 or 1/3200 and f/6.3. I don't want only 1/2000 and 1/4000 on a top dial. If that dial can be totally ignored it doesn't hurt anything, I just have no use for it.
The third dial would be to have EC that affects the ISO. If there is no third dial (like the D7200 and many older tech cameras) I can live with it, but a third dial is nice.
Apr 19, 2026 at 08:53 PM
GravelBen
Details
p.1 #20Which Fuji X Body from Nikon?
For nominal position in the range perhaps, for performance and features its much more equivalent to the D7500 (but faster burst rate, better AF and video, worse battery life).
The D7500 did seem like a step down from the D7200 in some ways though, I guess to create a bigger gap to the D500.
Apr 19, 2026 at 09:03 PM
Switch to mobile view
