Olympus 75mm f1.8 Aperture Changing
dwalk
p.1 #1Olympus 75mm f1.8 Aperture Changing
Have noticed that this lens is constantly changing aperture as I move the camera. The camera body aperture value remains constant (in manual mode) but the aperture blades in the lens move to provide different apertures with rotation of th body and lens. There is thus the constant noise of the aperure blade movement. The photos are correctly exposed so it must revert to the setting on the body at the instant the photo is taken.
Has anyone else observed this feature?
Apr 11, 2026 at 07:28 AM
ruthenium
Details
p.1 #2Olympus 75mm f1.8 Aperture Changing
Other than M (manual), it is the aperture-priority mode (A) that should be used for keeping the aperture under photographer's control.
In the P and S modes, the aperture is controlled by the camera and it can change if the camera "thinks" this is needed.
Apr 11, 2026 at 09:32 AM
gmccroskery
Details
p.1 #3Olympus 75mm f1.8 Aperture Changing
Pretty much all lenses revert to the largest aperture between shots -- to maximize focus accuracy and speed. The aperture blades close down to the set aperture only when you fully depress the shutter button, or press the DOF Preview Button.
I'm not sure about the camera rotation issue.
Greg
Apr 11, 2026 at 05:26 PM
skamaraju
Details
p.1 #4Olympus 75mm f1.8 Aperture Changing
I think mine did too sometime back. This is related to anti flicker shooting ON, if I remember correctly.
Apr 11, 2026 at 07:00 PM
FM ForumsMicro Four Thirds ForumJoin Upload & Sell
Switch to mobile view
