A9ii versus A7V in 2026
rico
p.1 #1A9ii versus A7V in 2026
Sorry, it's one of those dumb questions, again. Which is the better body in your subjective opinion?
Background: I decided to retain my Z6 rather than upgrade, and my other main system is feeling desperately out-of-date, being based on the A7ii. The 9ii and iii are both available new at extremely handsome prices. However, the ii is now cheaper used than the newly released 7V. I have scoured the usual forums, and examined the specs in detail. Either will serve my needs perfectly well, so I just need the final push. Tipping my hand, the A9ii looks like a winner.
Mar 30, 2026 at 07:59 PM
patotts
Details
p.1 #2A9ii versus A7V in 2026
What are you photographing?
Do you do any video at all? Is the 4-way flip screen needed or not? Do you want pre-shooting or not? Focus bracketing? Do you rely on the back LCD?
Lots of questions. Personally I would much rather take the new a7V, it beats the a9II is most aspects apart from the stacked sensor (but then the a7V does 30 fps vs 20 fps on the a9ii).
Mar 31, 2026 at 02:05 AM
Alan Parker
Details
p.1 #3A9ii versus A7V in 2026
The A9II still has the old menus, which could be a dealbreaker for some. The A9III has the new menus.
Mar 31, 2026 at 02:23 AM
patotts
Details
p.1 #4A9ii versus A7V in 2026
Indeed, once you have the new menus you would never go back.
I don't have much personal experience with the a9II per se, but I did own other Sony cameras during that generation (2019/2020) and I find that the lastest gen + menu are operationally faster, which matters to my impatient self.
Lastly, buying a a9II today, first released in 2019, is still OK, but if you plan to own it for a long time, it will start feelling old sooner, vs going with an a7V. And the resale value of that camera in 2-3 years won't be great.
Mar 31, 2026 at 03:20 AM
rico
Details
p.1 #5A9ii versus A7V in 2026
The menu system. Yup, that's an issue.
Mar 31, 2026 at 03:44 AM
jojib
Details
p.1 #6A9ii versus A7V in 2026
What do you shoot? Personally the A7V is a slam-dunk. It's got the latest AF and the white balance system. Plus I can afford it. Love the skin tones produced by this camera.
Mar 31, 2026 at 06:11 AM
arbitrage
Details
p.1 #7A9ii versus A7V in 2026
The only advantage I could see for an A9II is the faster sensor and therefore some risk of distorting fast moving objects or getting some leaning lines in the background while panning with a subject with the A7V.
Every other metric I can think of the A7V wins.
I would put up with the occasional wing distortion and leaning line to get the 30FPS, precapture, Bird Eye AF, custom Zone AF, better AF and more MPs. Plus all the other little improvements like new menus, faster card formatting etc.
Mar 31, 2026 at 07:09 AM
BigBabyMoses06
Details
p.1 #8A9ii versus A7V in 2026
Why not used A1? Pretty close in price.
Mar 31, 2026 at 11:48 AM
aCuria
Details
p.1 #9A9ii versus A7V in 2026
Buffer size on the A9ii is larger I think, specs say 241 compressed raw frames at 20fps?
A7V will do 95 compressed raw frames before slowing down to to 8.5fps.
Mar 31, 2026 at 12:12 PM
arbitrage
Details
p.1 #10A9ii versus A7V in 2026
Yes, that is one other issue with the A7V that I forgot to bring up. Although the A9II only shoots 20FPS and at 20FPS I think the A7V has a much deeper buffer than 95 shots which is at 30FPS.
EDIT: I went looking for what the buffer is at 20FPS and found this article testing the buffer at different FPS settings.
https://www.alphashooters.com/cameras/sony-a7v/memory-cards/
They got 88 files at 30FPS to CFe-A and 121 at 20FPS. At 10FPS they are 300+.
So the A9II certainly does have a deeper buffer but the A7V at 20FPS can still shoot for 6s before hitting it.
Mar 31, 2026 at 12:54 PM
rico
Details
p.1 #11A9ii versus A7V in 2026
The A7V is attractive but, being a new release, is still full retail ($2.9K), while used A9ii specimens are $1.9K from Robert's. I admit that is a consideration.
Mar 31, 2026 at 02:09 PM
KarmaKramer
Details
p.1 #12A9ii versus A7V in 2026
I don’t think the menu would faze me at all…the A9II is awesome, I even love the shutter click. You certainly won’t miss any shots using it over the A7V.
Mar 31, 2026 at 02:51 PM
3catsinky
Details
p.1 #13A9ii versus A7V in 2026
you can score one off greentoe for $2600.
Mar 31, 2026 at 03:16 PM
chiron
Details
p.1 #14A9ii versus A7V in 2026
If you would like to save money for other purposes, you could even think about an A9. There are only slight differences between the A9 and the A9II. The one that might matter the most to you is that the A9II has a larger body, while the A9's body is more similar to the A7III, a bit smaller (which I personally prefer). The A9II does 10 FPS with mechanical shutter while the A9 does 5 fps with mechanical shutter--note that this difference only applies to the mechanical shutter and there is no difference with electronic shutter. The A9II has two card slots, the A9 only one. The other differences have mainly to do with transmitting files wirelessly and these were intended to appeal to working sports photographers on deadlines.
The AF systems are the same in both. You can pick up a good used A9 very for about $1300. Great camera, one of the best Sony has made.
Mar 31, 2026 at 03:35 PM
aCuria
Details
p.1 #15A9ii versus A7V in 2026
For general photography get the A7V... dynamic range is better and there is a wider range of subject detection.
If you shoot sports and need the faster readout speed + bigger buffer then get the A9ii.
Between the Z6 and A7ii sell one system imo. Two cameras means double the depreciation and double the lenses.
Use the brand that makes the lenses or has the features you need.
Mar 31, 2026 at 09:42 PM
patotts
Details
p.1 #16A9ii versus A7V in 2026
I kind of missed the Z6 note. Unless you have a slew of Sony glass already, perhaps upgrading the Z6 to the Z6 III would be a good options. Best value around. If not, I'd sell of the Nikon system and get the a7V + the lenses you need.
As pointed out above, unless you really need the fully stacked sensor and the extra deep buffer, I think the a7V is a better camera in 2026 in pretty much every other aspect. You will miss out on a lot of advancements if you go with the a9II at this point.
Apr 01, 2026 at 10:44 AM
Cliff L.
Details
p.1 #17A9ii versus A7V in 2026
Your choices are a bad menu system, or a different bad menu system… I wouldn’t consider that a deciding factor.
Apr 01, 2026 at 10:56 AM
rico
Details
p.1 #18A9ii versus A7V in 2026
The OG Z6 is a sweetheart, and serving perfectly well. It's the A7ii that feels obsolete and badly due for a refresh: bought it 11 years ago, and the batteries also (still going). I don't understand what Nikon is doing with their camera models although the recent glass is phenonmenal. I always run multiple systems and mounts, so depreciation is something I manage. For Sony FE, the STF is my jewel and I want to shoot in its native habitat. I will pick up the 70-200/4 G II for zoom convenience, and to gain that 1:2 macro range.
I may be resigned to whatever menu system Sony gives me but, at least, can retain the camera build. Speaking as an owner of a 1Ds, D3X, D4, A7ii, Z6 and Leica M4, I do like the heavy metal. Nikon has gone 100% plastic for the Z6iii and Z8 which I do not appreciate—call me petty!
Apr 01, 2026 at 01:48 PM
patotts
Details
p.1 #19A9ii versus A7V in 2026
Petty! ;-)
Apr 02, 2026 at 09:04 AM
Manu-K1
Details
p.1 #20A9ii versus A7V in 2026
I thought about the A9 II when looking for a companion to my A7R III. I finally went with a used A1, but it is more expensive than A7V and A9 II...
Since the A9 II is much cheaper, that is a really good proposition, but it is not as good as the A7V for most things. Sure, the A9 sensor is faster, and its buffer is a bit deeper, but it's still running on SD cards.
Apr 02, 2026 at 05:25 PM
Switch to mobile view
