Convert scanned color negatives to positive pics?
jimmuller
p.1 #1Convert scanned color negatives to positive pics?
I recently revived my Nikkormat and shot a roll of Ultramax 400. I was hoping to convert the negatives to digital pics by scanning them with my Z5ii and converting to positive in software. I tried both Paintshop Pro X which I've had for years and GIMP on a Linux computer It didn't go well. Pics which should have been straightforward or at least with realistic color typically came out with a blue overcast. I could tweak a few to look okay but not real, and too soft.
Obviously I'm missing something, or there is no easy 1-button way to do it. Or perhaps the camera applied some sort of color correction or white balance shift and I need to re-scan them with all that stuff turned off. Or I need to use Darktable or similar which might have a functional tool.
Any suggestions?
Thanks!
Mar 30, 2026 at 06:55 PM
mskad2
Details
p.1 #2Convert scanned color negatives to positive pics?
I would definitively recommend darktable, but the learning curve is steep. There are two standalone open source programs that are worth a try: Filmvert (https://github.com/montoyatim01/Filmvert) and Film-Scan-Converter (https://github.com/kaimonmok/Film-Scan-Converter/).
If you are "scanning" with your camera, make sure to set the white balance based on the light that you are using, not the negative (sorry for stating the obvious). Also, try to capture a part of the negative that has not been exposed in order to help the converting program to correct for the film base color (the orange tint).
1. Camera Settings: Use manual mode (M), lowest native ISO, RAW (NEF) file format.
2. Set custom white balance based on the light source illuminating your negatives.
3. Use a dedicated macro lens (e.g., 100mm) for a flat field of focus and high resolution.
4. Use a high-CRI (Color Rendering Index) light panel (95+ CRI) to ensure accurate color reproduction.
5. If film holder is not attached to the lens, ensure the sensor is parallel to the film. Use a small mirror on the light pad to align the camera by centering the reflection of the lens.
6. Use a dedicated film holder or a sheet of Anti-Newton glass to keep the negative perfectly flat.
7. Expose for the darkest part of the negative (which is the lightest part of the final photo). Use a live view histogram to ensure the brightest highlights are not clipping, keeping the histogram generally in the center or slightly right.
Edited on Mar 30, 2026 at 09:15 PM · View previous versions
Mar 30, 2026 at 07:59 PM
madNbad
Details
p.1 #3Convert scanned color negatives to positive pics?
Negative Lab Pro is a plug in for Lightroom and was designed to deal with the orange cast of color negatives. It does involve the expense of a Lightroom subscription and the cost of the plug in but makes converting fast and easy.
Darktable is the low cost alternative. It has a fairly steep learning curve but offers a lot of manipulation once you become comfortable with using it.
Since you’re using Linux, it might be worth exploring Darktable. If you were using a lot of film on a regular basis, then NLP is the way to go.
Mar 30, 2026 at 08:15 PM
fjablo
Details
p.1 #4Convert scanned color negatives to positive pics?
Filmomat smartconvert is a good alternative to NLP. It’s not cheap but it’s standalone software so you don’t need the Adobe subscription.
Capture one has also released a film conversion tool, so in case you’re a C1 user, that would be the easiest route.
If you want to do it manually I suggest using Affinity (free software, alternative to photoshop) and following this guide:
https://www.alexburkephoto.com/blog/2019/10/16/manual-inversion-of-color-negative-film
Manual conversion is hard though. Especially if you don’t have a pure white point in the image.
Mar 30, 2026 at 11:50 PM
jimmuller
Details
p.1 #5Convert scanned color negatives to positive pics?
Thank you all for the great replies. Here I naively thought there would be a one- (or maybe two- or three-) click tool in software I already had. Silly me. Maybe there is. I got about halfway through the Alex Burke article before I remembered my eye-of-newt was well past its expiration date. Will have to read it again after translating some of his terminology and installing software.
Mar 31, 2026 at 04:14 AM
jimmuller
Details
p.1 #6Convert scanned color negatives to positive pics?
If you are "scanning" with your camera, make sure to set the white balance based on the light that you are using, not the negative (sorry for stating the obvious)....
Thanks. I had played with Darktable a few times already (tried the Windows version too but...it...ran...so...slowly), learned my way around but generally had no need for it with the pics from my digital camera. I wasn't sure what the purpose was for so much of it. I will see how those two programs work, maybe learn something from them.
As for scanning with my camera, obvious or not your comments are welcome. I have a nice scanning rig with WHITE!! light source and film holder, and a 1:1 90mm Tamron macro. I've already scanned more than 650 slides shot during my previous life and they always came out exactly as expected. But it didn't occur to me to set white balance to non-auto, may have to re-do them. Negatives have very, ah, non-typical color content.
Mar 31, 2026 at 04:28 AM
jimmuller
Details
p.1 #7Convert scanned color negatives to positive pics?
Well....., I downloaded Filmvert 1.1.2, ran it, or rather tried to run it. it complained about no signature (as expected) but I ran it anyway. My laptop froze, keyboard, touch pad, ctrl-alt-delete, and everything, or rather nuthin'. Complete paralysis. After hacking around I finally poked at the power button for 10sec to force power-down, waited five minutes for Windows to wake up, tried again. Same thing. So I figured maybe 1.1.1 would be better. Went to github, found the entry for it but no obvious way to download the 1.1.1 exe or zipfile. (And did I mention how much I despise github? It was written by people who took joy in making nothing intuitive, labels all made up, millions of options leading to obscurity.)
Mar 31, 2026 at 05:37 AM
retrofocus
Details
p.1 #8Convert scanned color negatives to positive pics?
Welcome to the pain of converting color negatives to realistic looking positive images! I consider it to this day as one of the most painful parts of film processing from my experience in over 10 years since I do film development (B&W, C-41, and E-6) myself. As others earlier mentioned, there is now better software available which does a good job converting color negatives more accurately. Vuescan does a pretty good job here, too - stay away from SilverFast 8 version which often came free with scanners. The latter can be very frustrating to use to get colors right from the negative scan plus often makes some yellowish borders which neither exist in the negative itself nor in the original negative scan.Not sure if newer versions solved these issues - I gave up on this one and use Vuescan since which is much more comfortable to operate.
One easy way I found to convert color negatives into positive images is by using Photoshop with black point, white point, and maybe grey point setting. It still takes a bit of color adjustment within the Hue/Saturation option afterwards, but results came out decent this way. I often referred to this method when I nearly gave up on getting the scan right with SilverFast.
Now very different question to get the exact color film negative "look". Some films are easier here to adjust and where you see the distinctive film look easily - Kodak Ektar is one example with purple shadows but vibrant red and yellow colors. Much more difficult because a lot more flatter in coloration are IMO the Porta films. Wasn't thrilled by them after color negative conversion - much cheaper Kodak Gold did a better job here for me. Fuji negative film colors tend to be more vibrant in the greens and blues. Each on their own to decide if the final image color is different enough from a post processed color based digital file. I often had to admit it isn't with few exemptions (Kodak Ektar based mostly which I like). Different story when looking at color slide films - Fuji Velvia 50 is much harder to process in a similar way with colors from a digital file.
Mar 31, 2026 at 05:59 AM
jimmuller
Details
p.1 #9Convert scanned color negatives to positive pics?
I got Darktable to work. First effort.
DSC_2651
James Muller, on Flickr
Mar 31, 2026 at 07:17 AM
AmbientMike
[X]
Details
p.1 #10Convert scanned color negatives to positive pics?
If its a blue cast have you adjusted basic color temperature?
Mar 31, 2026 at 08:27 AM
mskad2
Details
p.1 #11Convert scanned color negatives to positive pics?
Excellent. If you are willing to share your raw file, I would gladly give it a try and share the xml file (development parameters) if it comes out ok. Not that I pretend that I am an expert, but I did spent endless hours trying to figure out a proper workflow with darktable ;-)
Mar 31, 2026 at 11:03 AM
mattdev222
Details
p.1 #12Convert scanned color negatives to positive pics?
I'd also recommend giving Filmlab a shot. Negative Lab Pro never really clicked with me for some reason but Filmlab has treated me absolutely amazing.
Mar 31, 2026 at 11:10 AM
jimmuller
Details
p.1 #13Convert scanned color negatives to positive pics?
Noop, haven't adjust anything specifically. Probably got it wrong in the scan though the film was shot in daylight and the scanning light source is a cool, broad spectrum white that has scanned old slides just great. The scanning rig was designed for 35mm film but a colleague with a 3-d printer made a slide holder for it.
mskad2 wrote:
jimmuller wroteI got Darktable to work. First effort.
Excellent. If you are willing to share your raw file, I would gladly give it a try...
I would willingly share a raw file if I had any. I've been shooting jpg exclusively.
Filmlab. Will look it up, thanks.
Mar 31, 2026 at 01:32 PM
Geoff D F
Details
p.1 #14Convert scanned color negatives to positive pics?
I like Filmomat SmartConvert. You only need to buy once for a perpetual licence for all upgrades. It replicates the workflow of Fuji frontier scanners and is pretty simple to use.
Mar 31, 2026 at 02:08 PM
fjablo
Details
p.1 #15Convert scanned color negatives to positive pics?
Forget about ever getting good conversions then.
Converting a color negative image involves a pretty extreme white balance shift and stretch of the histogram. The 8bit color depth of the jpg just completely falls apart, you need a 14bit raw file for good results.
Mar 31, 2026 at 02:44 PM
jimmuller
Details
p.1 #16Convert scanned color negatives to positive pics?
fjablo wrote:
jimmuller wroteI would willingly share a raw file if I had any. I've been shooting jpg exclusively.
Then I shall have to switch to raw format when shooting film, won't I?
Thanks.
Mar 31, 2026 at 03:22 PM
OffTrail
Details
p.1 #17Convert scanned color negatives to positive pics?
Thanks.
The D850 has a built-in jpeg inversion feature if you're super committed.
But otherwise, yes, RAW is necessary.
Mar 31, 2026 at 03:34 PM
jimmuller
Details
p.1 #18Convert scanned color negatives to positive pics?
This is why I asked here. Learn something new everyday, especially if it's an essential thing for doing a task you want to do!
Mar 31, 2026 at 03:43 PM
madNbad
Details
p.1 #19Convert scanned color negatives to positive pics?
That's because we've already have made our share of mistakes.
Mar 31, 2026 at 04:12 PM
jimmuller
Details
p.1 #20Convert scanned color negatives to positive pics?
Yes, well, in photography we all try to find new things. I have spent much of my life discovering new mistakes to make.
I've found my way around negadoctor in Darktable. Sometimes it works okay but I'm not happy with everything. I intend to re-scan my film to produce raw images, then work with them. We'll see. Literally.
Apr 02, 2026 at 06:28 AM
FM ForumsFilm Is Not Dead ForumJoin Upload & Sell
