p.1 #1First time flash user. Seeking advice on Godox v480/X3 nano vs IT32/X5
I got my first ever digital camera (Canon R50 with a 50mm 1.8 prime) just a few weeks ago. My main goals are family photos with a toddler in the house. I don't do any post-processing and only keep SOOC shots.
Most of my shots are indoors and the lighting is not sufficient, especially nighttime under white LEDs. Even with a 1.8 prime, I still get a lot of noise. From my little research, I understood that an external flash is the simplest solution. I prioritize size and portability but not at the sacrifice of power.
The IT32 ticks a lot of boxes for me but I'm unsure if its power is enough for indoor photos if I plan to bounce the flash off of my white-ish walls/ceiling instead of straight onto the subject (which I learned gives a harsher look). Our ceilings aren't high. Even if its full power setting would get me good exposure at ISO 100, this flash will not be able to recycle fast enough. Toddlers move around a lot and I need to take shots in quick succession. I'm also unsure about how much a "fixed focal length" (28mm on the IT32) matters when I'm using a lens of a different focal length (80mm with my lens, due to crop). Especially in cases where I bounce the flash or use it off camera.
On the other hand, the v480 seems to have more than enough power for all my needs and it can zoom to match my focal length. But it's much bigger, heavier and costs extra because it also needs the X3 trigger for off-camera use.
There's also news that the X5 trigger is getting a native R50 version, in which case I won't need to buy the additional AD-E1 adapter for my hot shoe (R50 has a non-traditional hot shoe) to work with the flashes. That would decrease both bulk and cost which makes my decision harder.
Would the IT32's power be enough for my needs? I'd appreciate any insights you can offer!
p.1 #2First time flash user. Seeking advice on Godox v480/X3 nano vs IT32/X5
I've got all manner of Godox/Flashpoint strobes and speed lights. AD600's I've used at hundreds of weddings, AD200, Zoom Li-ons and minis - with different versions of triggers along the way. I have just picked up the iT32 with X5's in Sony, Olympus and now a preordered Leica. I am either obsessed or impressed and the iT32 is not getting the kudos I think it deserves especially for newer photographers just getting into on and off camera flash. I find the design to be brilliant and I think using this indoors and bounced will be great for you assuming you don't live in a palace. So far I only use it while shooting more casual photos of my family, but I could easily see this being a go to speed light at weddings especially earlier in the day before the larger lights are needed. For the price it's a major value and will last a long time while you grow and works with all of the system if you ever want to add more.
p.1 #3First time flash user. Seeking advice on Godox v480/X3 nano vs IT32/X5
For indoor photography, the iT32 is an ideal starter flash, boasting one massive advantage over other Godox models: the ability to switch between on-camera and off-camera setups on the fly. I suspect that it is still a weak speedlight (much like the iT30 I have), about 3-stop less than the AD200. For certain applications, the V480 is only about 0.2-stop weaker than the AD200.
With practice, you’ll learn blending artificial light with ambient sources so effectively that the results won't look harsh, even with a hard light source. In rooms with white ceilings, you can bounce the flash to create a much softer, more 'wrap-around' quality of light. To show you what’s possible, here is a shot I took of my family at night, where I balanced the direct flash with the streetlights.
And this daylight shot was with an off-camera, bare speedlight:
p.1 #4First time flash user. Seeking advice on Godox v480/X3 nano vs IT32/X5
mbjackson1979 wrote:
I've got all manner of Godox/Flashpoint strobes and speed lights. AD600's I've used at hundreds of weddings, AD200, Zoom Li-ons and minis - with different versions of triggers along the way. I have just picked up the iT32 with X5's in Sony, Olympus and now a preordered Leica. I am either obsessed or impressed and the iT32 is not getting the kudos I think it deserves especially for newer photographers just getting into on and off camera flash. I find the design to be brilliant and I think using this indoors and bounced will be great for you assuming you don't live in a palace. So far I only use it while shooting more casual photos of my family, but I could easily see this being a go to speed light at weddings especially earlier in the day before the larger lights are needed. For the price it's a major value and will last a long time while you grow and works with all of the system if you ever want to add more....Show more →
After my post, I ended up buying both the flashes. So I'm going to test them out and see what better fits my needs and sell/return the other. I will say the IT32 looks smaller than it appears in videos! Very impressive. And from what I've seen online, I do think a lot of people are raving about it! It's pretty new so I'm sure it'll grow even more in popularity. Especially among R50 users since they're dropping an X5 version native to the R50's hot shoe.
p.1 #5First time flash user. Seeking advice on Godox v480/X3 nano vs IT32/X5
Wow, thank you for sharing those examples! I’ve since watched a few helpful videos on YouTube that explain how to work with both direct and bounced flash, but it always helps to see real-world results to understand what’s actually achievable, especially with relatively weaker flashes. And these shots are pretty good! I really appreciate you sharing them. Makes me excited to test the flashes out (ended up buying both) once the hot shoe adapter arrives!
On a side note, you build custom Gundams? I see some incredible stuff on your page. Never knew this was a thing but that is so sick!
p.1 #6First time flash user. Seeking advice on Godox v480/X3 nano vs IT32/X5
satwikphoto wrote: hiepphotog wroteFor indoor photography, the iT32 is an ideal starter flash, boasting one massive advantage over other Godox models: the ability to switch between on-camera and off-camera setups on the fly.
With practice, you’ll learn blending artificial light with ambient sources so effectively that the results won't look harsh, even with a hard light source. In rooms with white ceilings, you can bounce the flash to create a much softer, more 'wrap-around' quality of light. To show you what’s possible, here is a shot I took of my family at night, where I balanced the direct flash with the streetlights.Wow, thank you for sharing those examples! I’ve since watched a few helpful videos on YouTube that explain how to work with both direct and bounced flash, but it always helps to see real-world results to understand what’s actually achievable, especially with relatively weaker flashes. And these shots are pretty good! I really appreciate you sharing them. Makes me excited to test the flashes out (ended up buying both) once the hot shoe adapter arrives!
On a side note, you build custom Gundams? I see some incredible stuff on your page. Never knew this was a thing but that is so sick!...Show more →
Somehow I missed your post. I hope you found the flash you like.
And thank you! I do have a painting studio working on various things, including Warhammer 40k and Gundams.
p.1 #7First time flash user. Seeking advice on Godox v480/X3 nano vs IT32/X5
Your next big step in photography is learning photography lighting. Each time that you get a new light and modifier, take the time to experiment, at first just aiming it at, preferably, a gray backdrop or wall. See how large the light spot or shape is at different distances, and different power levels. Also try adjusting it to bounce (reflect off the ceiling and walls, or other large relatively flat surfaces. Reflecting the light from one flash can give you a second source of light, slightly less bright, but also softer edged (less defined). Notice the reflected power level and shape after it bounces off of different surfaces angles, and distances, and the angles needed for the light to bounce off of the surface and onto your subject. Do this each time that you get a new photography light source. Doing this will give you a good feel for how to use that light or modifier to get the light needed for your desired photos. Spend some time reading through www.strobist1 and 2 and then trying some of the examples in them. Strobist is a little outdated now, but it's FREE and you will learn a lot of the basics from it. Don't hesitate to try all this shooting volunteers as you will learn even more about working with animals and people while learning more about your photography and photography lighting. Stay with one light source at first, and learn how to position it to get the image that you want. Shadows, or faint shadows produce depth in a well lit subject for a good portrait of them. So, too much light that eliminates all or most shadows in a portrait does not produce an interesting result. But there are other kinds of photography, like jewelry photography, where minimizing shadows may produce a better shot. Watch what the pros do for each kind of lighting. Look at magazine photos and try to figure out where the photographer's lights were located and what kind of light was used. Study their work and then try to see if you can reproduce your own version of it. Not an exact copy, but a shot of someone or something with similar lighting and shadows, maybe someone that you know and is willing to pose for you for several hours while you experiment with your camera, lighting, their positions, etc.
Many of us "Pros" keep a skeleton in our closet. Not really a skeleton, but a mannequin like used in the stores. When no one else will pose for you, and you want to try a lighting idea, or just to have a human figure there that won't move for hours while you try different lighting, sometimes can be very helpful for your learning experience.
Linda, my present mannequin, has been here in my home studio for about 7 years now. She is fully dressed with clothing that I purchased mostly at the local thrift shops, and she has several wigs, so "sisters", when I get tired of looking at the same plastic , a change of hair can sometimes help. "She" could have been a "he", but I decided that having a female here would be a little more interesting to have here in my home studio. She isn't a sex dummy, just a female form with the right shape for a pretty young adult woman, but no sex features, and she was the cheapest mannequin that Amazon was selling at the time. She will hold a pose for as long as I need her to, but doesn't have all of the joints required to bend much, so she just mostly stands there. A little head, arm, or waist movement is about all that is possible. But for adjusting the lights and then trying a few "Test Shots" every now and then, she has been handy to have around. Of course, a living human could do more poses, but when you can't get one to pose for you, this can be workable. At my age, most living women want nothing to do with me anymore, nor I with most of them.
Experimenting like this will make you a better photographer rather quickly, but I have a warning - Photography lighting and the lights and modifiers used is a rapidly changing ar in themselves. What you learn today will help you learn new things tomorrow to make you an even better photographer than you might be today, but the lighting keeps changing, so you need to experiment and learn more about these "new lights".
The warning comes when you realize that there seems to be no end to what you can learn about photography and lighting. I've been taking photos and experimenting with lighting for photography and video since the early 1950's, and I'm still learning. But this is great, because when I learn something, I can quickly become board, if there isn't something new to learn. I am still learning photography and lighting and haven't lost my appetite to learn even more. It has been a wonderful experience that has kept me interested and hungry for more for my entire adult life. Learn by doing, by reading, and by talking to others who seem to be able to answer your questions. Come back here with your questions when those around you don't seem to have the good answers. Most of us who have been doing photography like to help those with reasonably intelligent questions. Do your home work, but ask when you can't find the answer. Someone here will be happy to help if you ask intelligent questions and have not found the answer yourself.
I check in here often, but there are also PMs (private messaging) that becomes available to you after you have made a few posts to prove that you aren't a robot.
p.1 #8First time flash user. Seeking advice on Godox v480/X3 nano vs IT32/X5
No matter which flash/strobe you choose, this would be a quick introduction to flash and how to use it. I recommend it to all new flash users. It's well written and doesn't take long to get through. https://strobist.blogspot.com/2006/03/lighting-101-start-here.html
