p.1 #1Any way to trigger a Godox strobe with a Pocket Wizard compatible light meter?
Just wondering, as I am evaluating to buy a Sekonic light meter, if one with Pocket Wizard built in trigger can somehow trigger Godox strobes without a sync cable
p.1 #2Any way to trigger a Godox strobe with a Pocket Wizard compatible light meter?
You don't need a pocket wizard. Just use the godox trigger, turn the sekonic meter to the flash icon, set the shutter and iso on the meter, and fire the godox trigger.
p.1 #3Any way to trigger a Godox strobe with a Pocket Wizard compatible light meter?
And to continue -
When you take a photo, or manually trigger the flash, the Sekonic meter will measure the flash and display the result. I have two of the Sekonic L-308-U meters (one for the studio and one for the field kit). When set for flash, the meter will read the flash level and display the reading. Then you need to reset the meter for the next attempt (a simple button push). They work well for flash when used correctly, but can also be used for constant light, and most old meters only worked well with constant light. Some older models did work with flash, but needed a sync cable connecting the flash trigger to the light meter. If you have one of these older meters, look for the sync cable connector on it.
There is a newer and more expensive Sekonic light meter that is supposed to trigger the flash transmitter. I think it's via Bluetooth. This would need to work with a flash trigger that can receive the Bluetooth flash signal to trigger it. The advantage to this is that you can leave the flash trigger on the camera while using the light meter near each light and eliminate the need to carry both the flash trigger and the light meter when taking these measurements. I decided that I really don't need to replace my light meters for this new feature light meter, but if buying for the first time, this might be a good feature to have.
Keep in mind though, that not all flash triggers have BlueTooth capability. I know that the Godox X2Tc and the latest Godox X3 Pro c triggers do have BlueTooth, but I'm not certain that they have the ability to receive a BlueTooth flash command from the light meter to trigger the flash. It might be a nice feature to have, but these are new features and not known by me to work together yet. Well, at least I don't have any "hands on" experience with them.
The Godox X2Tc and X3 Pro transmitters do have the ability to receive the group selection and light level adjustments via Bluetooth, and this can work with a Godox App on your cell phone. You make group and level adjustments on the cell phone App, and it changes the settings on the flash trigger, which then changes the settings on the studio lights, and some speedlites. The App contains a feature to trigger the camera, but with my last App and cell phone upgrade, this camera trigger function still does not work. So I'm just not certain that these new flash triggers can receive a "flash command" from this new model light meter yet either, but they are selling light meters that are supposed to contain this feature, although at a price significantly higher than the price of the Sekonic L-308 light meters, which today sell for about $260 USA price. I don't need anything better, at least not for the significantly higher price of these newer Sekonic light meters. A light meter is very nice to have, and it helps those new to photography to learn with it, but with today's digital cameras, you can get by most of the time without a light meter. The one that I have in my studio gets used mostly for "product", "still life", and "Teaching" photo shoots, but if not teaching, it's rarely used for my "Portrait" shoots. Last year I don't think I used the light meter in my field kit at all.
p.1 #4Any way to trigger a Godox strobe with a Pocket Wizard compatible light meter?
Ciao Charley,
thank you for your detailed reply, I am evaluating the idea to buy a light meter to experiment both strobes and for when I shoot film, found a 478D on the used market but didn't manage to get it, I use Godox as strobe and wanted to figure if there is a way to trigger it through the meter, I found out there are dedicated meters for different strobe brands, they have built in radio triggers but the cost is excessive especially considering I just want to test.
The easiest will be to trigger with the X3 or Pro2 I own and figure it out, one of the things I like about photography is to experiment, as a teen I got a HAM radio license and it was the same, the fun was into experimenting.
p.1 #5Any way to trigger a Godox strobe with a Pocket Wizard compatible light meter?
CharleyL wrote: sungphoto wroteYou don't need a pocket wizard. Just use the godox trigger, turn the sekonic meter to the flash icon, set the shutter and iso on the meter, and fire the godox trigger.And to continue -
I’ve had my Sekonic L-358 for about 12-13 years now, and it is a great tool. Great way to make sure ratios are dialed in as a final check, rather than relying solely on the how the values look in Capture One.
p.1 #6Any way to trigger a Godox strobe with a Pocket Wizard compatible light meter?
"Just wondering, as I am evaluating to buy a Sekonic light meter, if one with Pocket Wizard built in trigger can somehow trigger Godox strobes without a sync cable"
"Grazie"
The better light meters like the Sekonic L308 that I have, when they are set to measure for flash, sense the flash itself and measure it when it is seen by the meter. You can then reset the meter to ready it for sensing the next flash, by pushing a reset button. No other sensor or Pocket Wizard type device is required to trigger it. It works completely on it's own to detect each flash and measure it, but holds the level of the measurement until you reset it, which makes it then measure the next flash that it sees. This flash measurement setting is an added feature over the light meters made some years back. These, as well as the older light meters, even those available in the 1940's could measure light levels accurately, but they had no way to detect a flash of light when we began using flashbulbs and strobe flashes.
Light meters made 15 years or so ago (I'm guessing on this age) didn't have an internal way to trigger themselves when they saw the flash, but could be triggered with a sync cable connected between them and the camera or a flash transmitter. When the sync signal arrived, they measured the light and locked the reading until you reset it. You can still use these for flash, but you need the sync cable connection to the camera or flash transmitter for it to know when to take the light level measurement, then hold the reading until manually reset.
Still older light meters had no ability to measure a flash because there was no way to sense when the camera and flash were triggering. These were made for film shooting when constant lighting for photography was more commonly used, even in the studios.
There are other brands of light meters out there that work like the Sekonic L-308, but in my opinion, the L-308 or one of the better Sekonic units are the most accurate and reliable that I've seen and used. That's why I have two of them.
