Requesting minimal lighting setup suggestions
Younjulius
p.1 #1Requesting minimal lighting setup suggestions
I have Sony A7R5 and a Godox strobe which serve me well, But, when I take family photos in my living room, which isn’t well-lit and under open to below, the Godox alone isn’t getting me the results I want. Either not enough lights or resulting in typical flashlight photos with shadows on the wall behind.
Could someone suggest me a minimal lighting setup to take indoor family photos? The setup is for 4 people with 2 sitting on chairs and two standing behind.
Ideally, in the next Christmas time, when I use the setup, I want people to be well-lit but not over power Christmas tree lights.
Thank you for your suggestion.
Jan 30, 2026 at 11:12 PM
rico
Details
p.1 #2Requesting minimal lighting setup suggestions
Assuming you have a shooting space of a brighter neutral color, simply aim the strobe in the opposite direction of your subject. The idea is to turn the far wall and ceiling into a giant reflector. An example using the Nikon SB-5000 flash (~75 Ws) at full power, and getting an acceptable exposure of f/5.6 @ ISO 100:
Super clean color temp, although no directionality to speak of (what most people prefer apparently). To generate some directionality for interest, or shaping your subject, you will need to add a second light or apply advanced techniques with reflector panels or flags.
Same light, same living room, but less ambient bounce (less fill). I have an actual key light created by bouncing off of a white circular piece of cardboard from a frozen pizza! Poor man's beauty dish, although I own one of those, too.
Jan 30, 2026 at 11:36 PM
jeffbuzz
Details
p.1 #3Requesting minimal lighting setup suggestions
Wall shadows are due to the strobe overpowering ambient room light with a short shutter. You need to learn to balance ambient with flash. Use a slower shutter to capture ambient light and flash to fill shadows.
Jan 31, 2026 at 10:36 AM
tcphoto
Details
p.1 #4Requesting minimal lighting setup suggestions
I'm not a fan of using a dedicated flash in "Auto" mode, I'd suggest putting it in "manual" mode, turn the flash head around at a 45 degree angle or straight up and bounce it off the ceiling. You can compare different power level settings, adjusting shutter speed to capture ambient light and understand how the distance to subjects affects the image. Digital cameras are great at this application, you get instant feedback and adjustments can be made on the fly.
Jan 31, 2026 at 12:31 PM
Younjulius
Details
p.1 #5Requesting minimal lighting setup suggestions
I would like a reasonably priced lighting set suggestions as there are so many options out there.
Jan 31, 2026 at 04:11 PM
nasoj21
Details
p.1 #6Requesting minimal lighting setup suggestions
I am also a fan of using what you have and shooting in manual. I have a very dark living room and generally shoot on camera flash (Godox V1) for the holidays. I have the dome attachment on and bounce off the wall behind me shooting in manual, 1/20th-1/60th of a second at f4ish ISO 250-400 flash in auto and just change my exposure by adjusting iso.
Otherwise the solution isn't really more lights, but bigger modifiers which is why bouncing off the wall works so well. The problem with more or bigger is space during the holidays etc. hanging a sheet or shower curtain or buying a large diffusion panel and shooting through it can make a huge difference.
If you do insist on new lights, you can get so much light in used kits. I have been looking for some myself and there are a lot of Bowens/ Calumet Tavelites out there, then pick up a couple godox collapsible octtaboxes. Otherwise pick up a couple Godox AD200 pros and S2 softbox adapters.
Jan 31, 2026 at 06:41 PM
Younjulius
Details
p.1 #7Requesting minimal lighting setup suggestions
If I want people be lit correctly and Christmas light colors to be well visible, what would be the technique?
Feb 01, 2026 at 12:55 AM
CharleyL
Details
p.1 #8Requesting minimal lighting setup suggestions
" I have the dome attachment on and bounce off the wall behind me shooting in manual, 1/20th-1/60th of a second at f4ish ISO 250-400 flash in auto and just change my exposure by adjusting iso."
Bouncing off the back wall is good, ceiling to reflect toward your subjects is usually better, if the walls and ceiling are white. Avoid bouncing off a colored wall or ceiling, because the color mixes with the flash and will affect your shots.
I don't believe these settings. Auto mode is likely saving your shots. It doesn't pay attention to any of your settings, as your camera decides what to do almost entirely without you, when in "Auto Mode".
The way described below will let you manually control your camera to make maximum use of it's capability for this kind of shot. Learning how to use your camera in "Manual Mode" will make you a far better photographer. Once you learn more about how to use your camera, learning how light works to get the lighting right for your shots will be the next thing to learn, and it's harder and takes longer to learn than your camera I frequently use "Auto Mode" or "TTL" when taking a first shot in a shoot. Then I use the camera settings that it went to as my first settings when I switch to "Manual Mode" . I then adjust to get my shots perfect from there. Don't be afraid to take "Test Shots" as we all do to get things right before we start shooting. It's easy to erase them later with a digital camera. These two camera settings average the light levels in your shot and change the camera settings based on these averages. If taking several similar shots and anything changes (like an added light colored sweater is added), the next shot taken will be darker overall, because of this added light sweater. A professional photo shoot is never done in Auto or TTL mode for this reason. It can be fixed in Photo editing programs, but "getting it right" out of the camera saves time, money, and looks better.
Setting your camera shutter speed to the camera sync speed setting will get you a huge amount more light from what you have with this setup. The sync speed is the longest shutter speed that you can use without seeing a dark bar at an edge of your shot. The dark bar happens when the flash duration ends before the camera shutter closes. Shortening your shutter speed just enough so as not to see the dark bar, makes maximum use of the flash duration. You then adjust the flash brightness to achieve the exposure level that you want without using long exposures that can show movement in your shots. For my Canon cameras, a shutter speed of 1/200 or 1/250 of a second works best for me. You can use shorter shutter speeds (higher fraction denominator), but it's a waste of the light from the flash. There are times when this is necessary, but not very often.
Outdoors or in constant light, shutter speed is the usual way of adjusting film or digital exposure. When using flash in manual mode, you set your camera shutter speed so as to make maximum use of the flash duration, but the shutter needs to close just before the flash duration ends. You then adjust the brightness of the flash(s) for the desired exposure, and leave the camera adjustments alone. I think you will find that your speedlite has far more power than you are using.
A good ISO setting will be easier to achieve, and testing different settings of this will let you better see the Christmas Tree and Lights, even if they are in the more shadowed parts of the room. It's a camera sensitivity control that lets you see more into the darker areas of your shots, and raising it even higher works well, and can even let you take night shots under a street light with low or no flash. but avoid the maximum ISO settings of your camera, as these can introduce noise (colored confetti) in the black unlit areas of your shots.
F4 is a bit short on depth of focus for this shoot. F8 or maybe F12 will let you see their heads in focus well, with closer and farther away from their heads being slightly out of focus. Higher yet will let even more of the shot be in focus. But raising the F-Stop settings require increased light levels. Higher settings also raise the low level cut-off of the light that the camera sees. I usually work in the F-8 area in my studio, so I can leave the ceiling room lights ON, and the camera won't see the room lights. Only the light seen by the camera is the bright flash, and I am in full control of it's the photo's exposure without the camera seeing the room light.
The photo attached was taken this way. I intentionally lowered the light level to make everything behind the flowers in total darkness (according to the camera) but the room lights were on. Learn what the inverse/square law of light is (not the math, just how it works. Light diminishes rapidly at distance and spread. At 1' from the light source, it is 1/2 the light level. At 2" distance it is 1/2 again, so 1/4 of the light level. This continues for every foot of distance from light to subject and background, and why you need a whole lot of light at longer distances. I adjusted the flash for this photo so that everything behind the flowers (my gear stored back there) did not show in the photo.
I've been a photographer since 1952, went totally digital in 1998, and have a fully equipped photo/video studio in my home. I know what works and what does not. I'm only trying to help you. I help many photographers develop a better understanding of photography. Try what I have said. Let me know if you have questions, here or via PM (Personal Message).
Charley
Feb 01, 2026 at 03:15 PM
nasoj21
Details
p.1 #9Requesting minimal lighting setup suggestions
To clarify, you can't set your shutter speed, aperture and iso in auto. When using flash, I always shoot in manual on the camera but set my flash to auto and may adjust flash exposure compensation.
If you want the Christmas lights to show, then set you camera in manual so it exposes the lights how you want, then turn on the flash and let it expose your subject. It can be a bit challenging in a small room where the flash can bounce everywhere, but this is basically how you always light environmental portraits.
I have taught flash classes for years and I teach a "flash" exposure triangle. The corners being
Shutter speed = Ambient Light
ISO/Aperture = Both Ambient and Subject Brightness
Flash Power = Subject Brightness
Sync speed is the 'fastest' shutter speed your camera and flash can communicate at. It erases as much ambient light as possible. The only time you shoot at sync speed is when you want the background as dark as possible.
If you are trying to make a natural looking photos of the family, you typically don't want to cut out all the ambient light.
I gave manual settings that are approximate for my dark living room. I think they are a good starting point for any indoor photo with flash. If you want the lights brighter or darker, raise or lower your shutter speed. If you want your subjects brighter or darker then raise or lower your flash power, or in my case your flash exposer compensation.
The camera is smart enough to set the flash power aka the subject brightness appropriately, but if you don't trust it, then set the flash power manually, start at 1/4 power since you are bouncing the flash.
Also watch some tutorials on the inverse square law of light, not always possible to adjust your flash distance in a living room but helpful when you want to avoid the flash lighting up the whole room
Feb 02, 2026 at 01:06 AM
FM ForumsLighting & Studio TechniquesJoin Upload & Sell
