Sony A7C with Voigtlander 50mm 1.2 handling?
klasGelinder
p.1 #1Sony A7C with Voigtlander 50mm 1.2 handling?
I am getting an everyday carry camera. I have a GFX kit for landscapes, which is my main interest. I want something I can carry with me in most situations. Does not need to be pocketable but on the smal side.
So, my brain said the best would be a Fujifilm X-E4 (or maybe v5) with the Voigtlander 27mm f/2 lens. My heart immediately protested and said I should buy an A7C II and a Voigtlander 50mm f/1.2 instead. I have no preference of 40 vs 50 mm focal length, I can make both work and I always wanted to try the 50mm 1.2.
Have anyone used an A7C with the 50 1.2? Especially the lighter SE version? Whats your thoughts on the handling? Is it front heavy? Would it droop annoyingly if carried with a neck strap on the chest for example? I haven't seen many pictures or videos of the combo so I find it hard to judge.
Jan 28, 2026 at 03:14 PM
hesb
Details
p.1 #2Sony A7C with Voigtlander 50mm 1.2 handling?
I know very well the old 50mm 1.2, and it is a gorgeous lens. But since I moved to a a7rIV I can now focus without magnification, due to the quality of the EVF, which is so confortable.
I know that others manage mf with poor evf quality, but now I would not go back.
My question is: if you use the evf, maybe this camera is not the best for using this lens?
Jan 28, 2026 at 03:26 PM
Jonas B
Details
p.1 #3Sony A7C with Voigtlander 50mm 1.2 handling?
I know the 50/1.2 SE quite well. It's a good lens (personal preferences). It has been some time since I used it with the A7CR. Now I have changed camera and run an A1 as I like a fast sensor read-out. My old tired eyes make me still use the enlargement button when focusing manually, just as i did with the A7CR. It works well unless in extreme hurry.
The A7Cii and A7CR are not the best cameras for manual focusing but they are obviously usable.
EDIT:
I don't use neck straps and can't really say what it would look like. Nose down a bit of course but unfortunately I can't say how bad it would be. (I'm a camera "in the bag" or "in the hand" type of shooter).
Jan 28, 2026 at 03:38 PM
Stargenx
Details
p.1 #4Sony A7C with Voigtlander 50mm 1.2 handling?
Yes, it would likely droop if carried "tourist-style" on a neck strap with the rear screen flat against the chest. I tend to carry with the camera sling style if I am using a strap.
Jan 28, 2026 at 03:45 PM
klasGelinder
Details
p.1 #5Sony A7C with Voigtlander 50mm 1.2 handling?
Something to think about, thanks!
Jan 28, 2026 at 03:51 PM
grahamgibson
Details
p.1 #6Sony A7C with Voigtlander 50mm 1.2 handling?
The handling size is nice, though the lens is on the heavier side. But I agree that manual focus would be difficult with the tiny EVF on the C bodies. I use the newer Techart AF adapter with the VM version of the 40/1.2 but had the 50/1.2 last year. They're very very similar, I just like 40mm better.
If you have a GFX system, consider giving the VM 50/1.2 a try--I've seen some samples that look like it covers the sensor decently and you could have some fun with it on both! This combo is very enticing to me, since I like 40mm equivalent, but I am satisfied with a full frame sensor for now
Jan 28, 2026 at 04:18 PM
eriet30
Details
p.1 #7Sony A7C with Voigtlander 50mm 1.2 handling?
I have the Cii with this lens and can say the EVF with focus peaking is crap IMHO. I put that lens on my 7r4 or A1 it is a great lens but I cannot nail focus with the Cii
Jan 28, 2026 at 04:30 PM
gocolts
Details
p.1 #8Sony A7C with Voigtlander 50mm 1.2 handling?
I haven't used the 50, but have an A7cR & CV 40 1.2 SE that to me is a great match handling-wise. I used it in Maui for landscapes and some low-light stuff. Focus peaking wasn't a big concern for me as I was at infinity more times than not. I also have an A1 and would say that if peaking is a big priority, sure the EVF is better on that. For me it was still usable for peaking on the A7cR, but sure the opportunity to miss critical focus goes up when the EVF isn't as good.
Jan 28, 2026 at 04:54 PM
Juha Kannisto
Details
p.1 #9Sony A7C with Voigtlander 50mm 1.2 handling?
I've been using A7CII as my main camera since it was released and A7C before that. Previously A9, A7II, A7R (I still keep all those older bodies as well). I shoot with manual focus lenses around 95% of the time and I don't find it to be that problematic with the small EVFs on A7CII and A7C, and for me the smaller "rangefinder style" body is much more enjoyable as a daily camera and especially with small lenses than the slightly bigger A7 / A9 series bodies (that keep getting a bit bigger with each iteration). A7CII is definitely better than A7C for manual focusing since the EVF magnification got upgraded to 0.70 (A7CII) from 0.59 (A7C, definitely feels more cramped). I think manual focus shooting experience on Fuji X cameras that have smaller EVFs (like my X-S10, X-E4, X-E5) is also pretty similar to the A7C / A7CII experience and I also use X-S10 with manual CV lenses (X native), but I've been preferring A7CII overall so my X-S10 use has been fairly limited in the last year or so.
If one is very accustomed to shooting with the highest resolution and magnification EVFs, it might seem like a big step down to go with A7CII or A7C but I think it's depends a lot on personal preferences. I have a lot of tiny lenses too (MS-Optics etc.) and pairing those with a bigger body would seem less ideal when I prefer the whole setup to be as compact as possible.
I don't usually shoot moving or fast moving subjects in this style of shooting though and there's no big hurry to achieve focus in shortest possible time. I usually rely on peaking only when shooting something in close to mid-range with wide apertures, and mostly when I shoot cityscapes / landscapes stopped down I use magnification since it becomes harder to judge idea focus by peaking alone. When I shoot events with fast movements (like Japanese traditional dance performances in summer events), I usually go with my A9 and some AF primes. I have done that a couple of times with my A7CII and MF lenses too just for fun though (definitely more challenging).
I do have the 50/1.2 SE as well and I think it balances reasonably well with the A7C series, although 40/1.2 SE and 35/1.4 Nokton classic (E version) are even better matches. With the f1.2 CV lenses, I definitely prefer the slightly smaller and lighter SE versions (all now discontinued, but I bought them while they were new and have kept them) over the original 50/1.2 and 40/1.2 that still remain in production. I traded away my original 50/1.2 and 40/1.2 after getting the SE versions.
Jan 28, 2026 at 07:24 PM
Yogifi
Details
p.1 #10Sony A7C with Voigtlander 50mm 1.2 handling?
I have the 50/1.2 SE and the A7cii. I have no issue with focus using the evf, but I zoom-in twice.
I don't use neck straps either. And I think it's a decent size. Within my limit for compact, absolutely fine in a small bag.
Little thick but fine for me.
A really lovely lens too. 40 SE is noticeably smaller than the 50. I haven't shot my 40 much (yet) but I liked the 50 so much I wanted something similar in a slightly wider focal length as an option.
I can take a few photos for you, just dm me if I forget.
Jan 28, 2026 at 08:24 PM
klasGelinder
Details
p.1 #11Sony A7C with Voigtlander 50mm 1.2 handling?
Thanks everyone for the feedback.
I haven't had an everyday camera for a few years now, life got in the way, the last one I had was a Leica M-A with a 50/2 summicron, I had a Fuji X100F also in the past, both those I used with a short neck strap so it rode a bit higher on the chest. Not a stealthy look, but very fast and leave both hands free.
For travel a few years ago I also used a Sony A7R III with Loxia lenses (I miss the 35!). This setup I didn't carry on a neck strap, but rather in a small sling bag. Taking it in and out. This worked fine too so I can use this if I get a A7C body with the 50.
I feel this is what we at work would call scope creep, but I will check the other Sony DSLR bodies, see if any of the smaller ones can be used but I think I am getting further away from the goal here. Maybe I need to drop the 50mm and get the 40 SE instead, hope for the best with the A7C II EVF or go back to the Fuji idea.
Jan 29, 2026 at 12:32 AM
Yogifi
Details
p.1 #12Sony A7C with Voigtlander 50mm 1.2 handling?
A7cii evf isn't a treat to use, but it works.
The camera isn't the size that you just toss it aound all over the place like a fuji xe/x100. But it's small enough to take out and about, not too awkward. For me I don't particularly like to carry it on my neck. I'm okay doing that with the x100 but that's about it.
I've included it (and a bo-lle o' wa-er) for scale here. Note I use the bottom plate of an L-bracket with the a7cii for basically every lens other than smallest like the tta40/2 but I can live without it too.
next to the 40 (not a huge difference but I notice it).
On the Nokton itself, I really like it, the colours are a little less modern: a hint more pastel and vintage but with good contrast. Like there's a notable difference between it and say a recent Sigma lens. I like it a lot with people and good light.
A Simera 50/1.4 has a more modern look - still not the same as a Sigma but it's more modern than the nokton colours and style, more bubbly, fresh and lively but less depth. Penelope Cruz / Sydney Sweeney.
[The Sigma 50/2 is very nice btw, I don't mean to dump on Sigma.
If you want very sharp 50mm that can punch into 75mm in crop mode, apo-lanthar manual focus, or cheap as chips viltrox air.]
The Simera also flares a bunch more, is much smaller and lighter, and I don't think it's quite as well made or as good as a lens but it's not bad at all and I'm glad to have it for a different look - and I can imagine some preferring that look. Note I have the M mount version and I think the E mount is basically the same - I don't know how it performs across the frame etc, I literally only used it with people and larger apertures so far. The Nokton renders sharpely across stopped down, soft and glowy (not great) up close and wide open. I often use it around f1.6. Longer distance f1.2 works well too, the glow goes away when it's further focus. Very close distance stop it down to lose the glow.
I would take a careful look at samples to see which look you prefer if you were hunting for a 50mm manual focus lens to use with people too.
The TTA 40/2 comes with autofocus, is very small (could get away with it on your neck/shoulder - very nimble with it), is closer to 37mm focal length, isn't well made but it renders quite nicely and very cheap but max f2 aperture. I would just grab this anyway, can be had on ebay brand new for like $150 or so, or just a little more direct from them, last I checked anyway.
I think for "most situations" something a little wider than 50 would be more comfortable for me personally. I always thought 35 was good for that - little easier with scenes and if fast enough then very useable for people too. I went with the Distagon ZM for that focal length and faster (though it's not exactly an "everyday" rendering style - it's quite snazzy). I like it but there's some drawbacks. Practically it's a bit longer with the adaptor, about the same weight as the nokton 50 (without the adaptor), corner smearing without a PCX filter at wider apertures. Another recommended one is the 35mm f1.7 Ultron. Bit of an issue with both of the last two in that if you don't want to remove a shim (which is very simple on the distagon - no experience with the ultron) then you need to find an adaptor that's out of spec to focus at infinity with the pcx, and I haven't had any luck with that. Otherwise f8 for sharp corners. I've decided on using the PCX only with longer range shots (it's basically a filter) and allows me to use around f4-5.6 (midzone dip noticeable on zooming when wider) instead of f5.6-8 for the scenes where I want better across frame sharpness without stopping down as much. Not an ideal situaton and the tta40/2 would make things a lot simpler, lighter, carefree etc. 40 Nokton f1.2 also but it's like 5mm tighter (37vs42 iirc). I don't have the 35mm f1.2 SE, I think it's a hair bigger than the 50. Sigma 35/2 is wider than 35. With the other slightly tighter options that I'm familiar with: Sigma 45 is nice but f2.8. Samyang 45/1.8 has very nice output too but a bit shoddy aesthetically.
If the rx1riii had tilt screen and ibis while retaining the size I'd suggest looking into that for everyday use despite f2, and imo it ought to for the price, but the a7cii and tta40mmf2/samyang 45f1.8 is a very good alternative, or the 40/1.2 nokton for more fun if you enjoy mf and more leeway with the aperture. Or leica m11 + 35 fle for a lot more money and still no ibis. x100 not so great with people imo. Fuji xe + 35/1.4 is nice but not the same as full frame.
Jan 29, 2026 at 06:23 AM
klasGelinder
Details
p.1 #13Sony A7C with Voigtlander 50mm 1.2 handling?
...Show more →
Thanks! Doesn't look to bad! I have read a lot about the 50 1.2, like from https://gear.vogelius.se for example. He likes it very much and always produce great samples, it's been on my list to try but I haven't gotten a chance yet. It's not the end of the world however and I could also use a 35mm AF lens as this is not really meant for my most important photography. But it has to be something I like using and if the EVF is annoying to focus with or it's too unbalanced etc a smaller AF lens might be better. I might go for the RX1R III to save some money in that case.
Jan 29, 2026 at 10:06 AM
Yogifi
Details
p.1 #14Sony A7C with Voigtlander 50mm 1.2 handling?
I like the https://gear.vogelius.se site a lot and read basically everything he puts out. I'm not sure if he's post processing in the samples in the review but I suspect there is some and that he's very talented. I really like the render of the lens.
It's not fun focussing through the EVF, but it does work. I've heard the Nikon zf is funner with the eye focus assists, but that the camera is a little bigger. I've never used one but might be worth heading into a shop and giving it a feel. Extra size might help with the nokton 50 a bit as well. But yeah, bigger camera doesn't sound like the thing you want.
I like the balance with the l-bracket, without it's okay too but it helps for me. I think the apo-lanthar balances a little better but I'm not unhappy with the nokton.
The 40/1.2 SE is still wide but shorter, it's a little nicer without the l-bracket for me actually (just checked now for you). It's a very good balance.
I've heard there are some rendering differences vs the 50 (some onion rings on bokeh balls for one) but can't comment too much as I've still yet to use it much - but balance wise, feels very good, no l-bracket and a bit less tight fl for everyday. Ever so slightly front-heavy without bracket, like marginal, not worth the small extra weight/size from the bracket.
50 is okay without the L-bracket but I definitely prefer with. I have the SmallRig one and the vertical part detaches.
Jan 29, 2026 at 10:25 AM
Switch to mobile view
