p.1 #1Speedlight wireless trigger and receiver advice please
I'm a natural light photographer that has decided my goal for the year is to learn how to confidently and competently use strobe. I already have a Canon R5 and 5D Mark IV as my main bodies, a Canon 580 EX speedlight, and a large 5-in-1 diffuser/reflector.
Before investing in dedicated off camera strobes, I figured it makes the most sense to use what I have and learn with it, then build out as desired. I know I want to shoot off camera. My thoughts are to start with the following equipment:
two light stands (one for the speedlight, one for the reflector)
a reflector holder
a s-bracket with bowens mount that will hold my speedlight, attach it to the light stand, and allow me to use a variety of modifiers
a wireless radio trigger and receiver for the flash
a light modifier of some sort
I have been looking at Godox/Flashpoint triggers/receivers because they seem to be widely recommended and not overly expensive, but I haven't been able to find a good comparison of the many different models they offer. I obviously need them to be compatible with my current gear, but would also like to maintain compatibility if I purchase dedicated studio strobes in the future. Other than that I don't even know what features to look for, other than that I would like them to be functional without line of sight. I do think I'd like move to a multi-light setup in the future, so being able to sync/trigger at least three units would be beneficial.
Can anyone break down the differences of the different Godox/Flashpoint trigger and receiver models for me or recommend what might work best for my current situation? Are there models that are incompatible with this setup that I need to avoid completely? TIA!
p.1 #2Speedlight wireless trigger and receiver advice please
A good learning tool for flash photography is the Strobist 101 blog. It quickly walks you through the basics using a speedlight. I’ll put the link below. Your three main choices are Godox (private labeled as Flashpoint), Westcott and Paul Buff. It’s best to have battery-powered strobes on location. Here are a couple differences.
Godox - Lowest cost, but mostly ala cart. Minimal support.
Flashpoint - a bit higher than Godox (same equipment), but support is available through Adorama
FJ Westcott - More expensive, but has dedicated location kits. Factory support
Paul Buff - Probably same price range as Westcott. Good equipment, factory support.
p.1 #3Speedlight wireless trigger and receiver advice please
You will do good with the choice of Godox and/or Flashpoint. There is another re-brand of Godox in Europe, but I don't remember the name. Godox and these re-brands all work well together, but there is no communication standard, so you are best to buy only one brand and stick to it for any additional lights and transmitters that you purchase. Godox does make some conversion receivers that let you add them to other brands of lights. These receive the X band signals from the Godox transmitters and translate the signals to match and operate these other off brand lights, or you can use sync cables between your camera and lights. Most lights have infra red receivers too, so if your camera is close to the first light, it's flash can fire these other lights that see the flash and then fire too.
I wasn't very happy with my older professional lights about 5 years ago, so started asking opinions of what to buy as replacements. Godox & Flashpoint was the answer from 4 out of 5 professional photographers that I knew. So I bought a Godox X2Tc transmitter (I'm a Canon Shooter Too) and two Godox TT600 speedlites. The X2Tc transmitter has a feed through hot shoe on top of it, so I could stack my old transmitter on it and use both my old lights and the TT600 at the same time. After just a couple of photo shoots it became obvious what to do. My old lights mis-fired several times, but the Godox TT600 never missed. So I set my direction to replacing all of my field kit lights and my studio lights with Godox or Flashpoint, which ever was on sale at the time. It severly crippled my photography budget for about a year, but I have now replaced everything with Godox or Flashpoint. I have 3 relatively new AD200 Pro II for my field kit, but I'm using them sometimes in the studio as well. For my studio I now have 4 MS300, 2 SK300, 2 SK400 II, and 1 DP1000 III, plus 8 GVM LED panels and 2 Genaray 100 watt constant LED lights, mostly for Video work, and 4 UV LED panels for Halloween shoots. I also picked up 2 500 watt tungsten focusing spot lights about a year ago, and have one pleated backdrop to use with them to simulate theater stage curtain stage shots. I also have three X Pro transmitters for my 3 Canon 77D and 90D DSLR cameras and 1 Fuji backup camera. I sold all of my old lights and transmitters to another photographer at a good price for him and it helped easy my budget crisis. He was convinced that he wanted them, so I parted with them quickly. I have not looked back. It was one of my best photography decisions. When I have a problem now, it has always been my mistake and not the lights. A bumped channel setting is the usual cause of failure and quickly fixed. Godox and Flashpoint offer a very wide selection of lights, modifiers, and other items at good prices, and they work well. At these prices, if anything fails and it isn't the modeling light or flash tube, I'll probably just replace the light or transmitter with new. Never have I had photo lighting that was this reliable before.
The Godox "X" communication band is the higher channels of the WIFI band and most other WIFI gear and appliances use the lower channels. Interference in these higher channels is almost non existent, in my experience, but it has happened a few times. When out in the field doing a shoot in a local park, my lights started firing without me. A quick look around found another photographer doing a shoot on the same channel. I moved a few channels higher and all was good again. Another time I was outside a manufacturing building and something in there was firing my lights occasionally. Again, I moved a few channels away and all was good again. I have never used the Identity codes that can be set to separate users on the same channels. I just felt that moving away by several channels would work best, and it did. The X Pro transmitters have a channel search function that scans and identifies channels that are in use, so you can then pick a better channel, but I have never needed to use it either, though I have scanned the channels a few times to see how it worked.
Whatever you end up buying, be certain that you buy a brand that offers other models of lights and power, so you don't lock yourself into a significant investment with no growing capability. I had Bowens mount modifiers in the past and like how easy they work, so every light that I have bought is Bowens mount, or with an adapter, like the S2 bracket to let me use any light with any modifier that I have. Maximum flexibility, great for my studio work.
p.1 #4Speedlight wireless trigger and receiver advice please
Thanks for the link to Strobist - its already on my list!
I edited my original post to clarify I'm mostly looking for a bit of a breakdown between the Godox/Flashpoint triggers and receivers, as there seem to be quite a few options and unfortunately the website does a terrible job of directly comparing features between the models. In my own research it seems like any Canon mount Godox X* trigger should work in at least manual mode on my 580 EX and likely any of the triggers would meet my needs. I just want to make sure I'm not overlooking anything with the 580 EX being an older speedlight and also considering future compatibility with any dedicated strobes I purchase.
Sandbags are a good idea. I plan on starting indoors (and have enough heavy objects at home to do so safely), but they will be on my "expansion" list kit if I go on location anywhere.
p.1 #5Speedlight wireless trigger and receiver advice please
CharleyL wrote:
You will do good with the choice of Godox and/or Flashpoint....
Thanks! I'm pretty set on sticking with Godox/Flashpoint, cost, quality, range and availability of products all seem good, and I've noticed they occasionally pop up secondhand in my area.
I guess I'm primarily trying to discern and major functionality differences between the X transmitters and if there would be any compatibility issues with my existing gear, although it seems like any Canon version X receiver would work with my older 580 EX speed light. The best comparison I could find was this: https://www.essentialphoto.co.uk/blogs/news/comparing-godox-x-series-triggers albeit it doesn't have all the most current models.
I suspect I'll often use manual mode (particularly for learning) but TTL would be nice to have, but aside from the X16 they all seem so similar.
p.1 #6Speedlight wireless trigger and receiver advice please
Kari - You might call Adorama and talk to one of their Flashpoint reps. They private label Godox as Flashpoint and support the products so they should be able to give you some direction. I don’t shoot Canon or Godox/Flashpoint and can only give you generic information.
Good luck with your adventures in flash/strobe. Learn and it will take your photography to another level. The trick to using flash is to make the image look like you didn’t use flash!
p.1 #7Speedlight wireless trigger and receiver advice please
ALL of the Godox/Flashpoint lights being sold new today already contain the "X" band receivers. Be careful if buying used to make certain that your transmitter will trigger it before buying used. Older Godox/Flashpoint lights may not have this receiver built-in. I have bought a few Godox lights used, and always test for good function from my transmitter before buying. If the seller balks at this, turn and walk away.
The center pin of the transmitter hot shoe is the trigger signal, and most brands and older cameras all have this pretty well standardized, so the camera can trigger the Godox transmitter and lights, even if the transmitter isn't fully compatible with the camera being used. The transmitter settings will still control the groups and their light levels. What you will loose is the TTL and other functions that require the camera and transmitter to work together on. Though the center pin trigger was pretty much standardized, the manufacturers seem to have gone their separate ways with the newer features added after the hot shoe became relatively common on cameras. Don't hesitate to try a transmitter that is not fully compatible with your camera, if you should need to. It should still trigger the lights and the transmitter should still be able to select the groups and light levels to adjust them from the camera location. You will need to use one of the Godox/Flashpoint "X" band receivers to convert the signals to the off brand flashes though.
p.1 #8Speedlight wireless trigger and receiver advice please
You can use Godox hot shoe flashes as wireless triggers too. Obviously that's bulkier than a simple trigger, but it is an option.
Basic trigger differences:
XPro II: Biggest screen. 16 groups. Shows 5 groups on screen. Easiest to view from above. Fewest button presses to change a setting. Only functions as a transmitter from camera. AA batteries.
X2T: Small screen. 5 groups but only shows 3 on display at the same time. More button pressing to change settings. Hot shoe works as a receiver to trigger OEM flashes wirelessly from another Godox transmitter. AA batteries.
X3Pro: Fancy touch screen. 16 groups. Built-in li-ion battery. Weird ergonomics with limited physical controls only on right side which is not where I want them. Can act as remote shutter trigger for camera.
I'm ignoring the older XPro, X1T and X3 since I don't think it's worth getting any of those to start rather than the newer models.
p.1 #9Speedlight wireless trigger and receiver advice please
The Adorama Videos on Youtube have several good photographers to watch, if you learn well by watching others. Daniel Norton, Gavin Hoey, Mark Wallace are the ones that I watch frequently. Gavin is in England somewhere, all three are mostly portrait photographers, but do occasionally get into other kinds of shoots.
If you want to learn "Still Life" and "Product" shooting, "Camera Club Live" is the one that I usually watch more than others. There are others, but this is the best. He shows the final shot, and then takes you step by step through the setup, explaining the entire process along the way, to the finished camera shots, and then through light Photoshop adjustments to the final picture. He is a great teacher, but don't think that you need any of his high dollar gear to get the same results. A 24-70 mm lens and a camera with Manual settings, some speedlights, etc. will get you there, without the need for the high dollar gear. You can do this on a card table with walking space around it, and the lighting technicues and how to use them applies to Portrait and other types of artificial light shots, just at a larger scale. Learn how light behaves, and how the inverse square law of light works (not the math, just how it behaves) , and you will learn lighting for photography in any size and condition very quickly.
I'm getting old (83) and with many health problems now. Getting out and walking miles for outdoor shoots ended for me many years ago. But I still go to local Parks for shoots, and now my work is mostly in my home studio, and the "Still Life", "Product", and "Portrait" type shooting, and Infomercial type videos are mostly what I do now, in a 19 X 26' home studio (former 2nd Master Bedroom Suite upstairs in my home). I started taking pictures in 1952, went totally digital in 1998, and finally 6 years ago built the studio that I have always wanted. From 1998 to 2003 I owned a photo retouch and restoration business, doing work for other pro photographers and walk-ins. Health problems forced me to sell that business.
p.1 #10Speedlight wireless trigger and receiver advice please
Godox and Canon brands are not interchangeable.
The Godox trigger won't fire your Canon flash (unless you buy a separate Godox receiver and attach it).
Both systems are proprietary.
Canon has the RT system, which is very nice, and a new trigger for that system: ST-E10
On a side note, most of the time when you're shooting multiple, off-camera flashes, you will most likely be shooting in manual flash to control each unit's individual output.
I used the Godox trigger with TT350 flashes when I shot with Fujifilm and it was excellent. I'd add a TT600 if I needed more output, but the whole setup was great.
If money is no object, the Profoto system is excellent. It gets terrific reviews and is easy to use.
Westcott makes a good system, too.
Lots of options, but remember you're buying into whole system, either way.
p.1 #11Speedlight wireless trigger and receiver advice please
If I were in your position, rather than trying to adapt your Canon speedlite, I would just purchase one of the lower end Godox speedlights like the TT685C (for Canon), and a Godox trigger. It would be cheaper and easier to use as an integrated unit than adding the receiver, especially if you sold your Canon flash and put the proceeds towards the godox flash. I'm not sure if the Canon speedlite will have functionality like HSS and TTL if you are pairing it with another manufacturer's receiver and trigger.
Otherwise your plan for a 5 in 1 reflector, two light stands with a decent foot print, an S-type bowens bracket sounds great. Once you feel like you need more power, the latest AD200 Pro is a great step up.
Angler makes a great bowens mount compatible softbox as well that is pretty affordable. But I think it's important to learn umbrellas first in your lighting journey before you jump into softboxes, because you can do a ton with just an inexpensive umbrella. I'd also pick up a couple 25 lb sandbags, because learning safety with lighting gear is critical. You can do some serious damage to someone with a light stand falling on them.
p.1 #12Speedlight wireless trigger and receiver advice please
The main difference between trigger models is size and to a certain extent ease of use. I have not used their reciever, but you would need to pick up a Godox XR1c which is a ttl reciver that Godox makes. You will need to walk over to your flash to make manual changes, but can make exposure comp changes from your trigger.
The Godox X2Tc is hard to use, but allows you to have an on camera flash on top of the trigger, but does not have ttl pass through if I remember correctly, so in your case you would need to double stack a recovery on top of your trigger if you wanted to go that direction.
The XPro II is easier to use, but a bit bigger. Has a bigger screen and easier to navigate, but a lot of people still struggle pairing and using them.
The X3 really small, Touchscreen, built in battery
The X3 pro has bigger screen, bigger built in battery Bluetooth to hook up to phone app and focus assist lamp for shooting dark environments.
I have not used the x3 or x3 pro and I don't know the point of the app. But the built in batteries are intriguing as is the focus assist lamp assuming it works with mirroless camers. Most manufacturers flashes didn't utilize the lamp once the flash was used for mirrorless cameras.
p.1 #13Speedlight wireless trigger and receiver advice please
FWIW, I have a couple of flashpoint AD200s from circa 2018, an AD400 and an AD600 and they all fire perfectly with the new triggers (I think both have come out in the last year).
p.1 #14Speedlight wireless trigger and receiver advice please
I have big fingers, so I have stayed with the X Pro i and II transmitters. I tried these smaller transmitters that are being offered now, and quickly decided that they don't work well for me. Touch screens give me all kinds of troubles too, but over the last 6 years, since ditching my old lighting system, the Godox/Flashpoint lights and controls have done everything that I have asked of them. When there has been a problem, it has always been my fault. I seem to bump the channel selection of a light during setup more often than anything. Lights don't work when on the next channel up or down from the one selected on the transmitter. I did use this to help with quick lighting change over for a shoot when I needed to have two lighting setups for the shoot though, Each setup of 3 groups of lights were set for different channels, but all were in place otherwise, so just changing the transmitter channel to the one used by the second lights completed the lighting setup for the second part of the shoot. This worked well, and I was ready before anyone in the shoot was (change of clothing).
The XT2 is capable of five groups with five buttons along the top of the unit to select them for adjustment. I still have one of these, but don't use it much now. I bought it, along with two TT600 speedlites when first considering switching to Godox, and I stacked my old transmitter on top of it, so I could continue to use my old lights along with the new TT600. It wasn't long, maybe 3 or three shoots, before I became totally sold on going to Godox. This change was expensive, because totally switching meant replacing the five lights in my field kit, and the 9 studio strobes in my photo studio that range from 300 w/s up to 1000 w/s. My photography budget was stretched to it's limit, but I completed the changeover in about a year. I did manage to sell all of my old lights to another photographer, who was convinced that they were the best for his need, so this helped my budget considerably. I haven't looked back. Making the switch was one of my better photography decisions.
In 2025 I bought three AD200 Pro II lights, along with their accessories to replace three of the TT600 lights in my field kit, but have been using them in my studio now too. I have been making snoots for two of them from matte board and White Gaffer tape. These are rectangular in shape, for the Fresnel head, to use in a still life shoot that I am presently setting up for in my studio. I made these to slide forward and back, giving me some control of the light spread, which I want to keep very narrow for this shoot.
The X Pro transmitters show the settings of five groups on the screen, but the five displayed can be scrolled up or down over the 16 possible groups that it can control. I have had a couple of shoots that involved more than five groups, so this capability has been very helpful. More than one light can be assigned to any group, but in use they will all adjust to the same settings of the group they are set to work in. Mixing light sizes in a group does not work well unless all are the same model/power and used very close together so as to function as one light. It's usually best to assign only one light to each group, so you have the ability to separately adjust the power of each from the transmitter. All will fire at the same time no matter what group they are in, but you can select and turn on/off each group from the transmitter as you work. All of the transmitters can switch the modeling lights on and off too, but most transmitters switch all on and all off with no ability to only control just one or two. It's an all groups on or off thing. The X Pro II does have better modeling light control, although it's still not what I would prefer, and I think it's the only one that offers this better control, although I have not used any of the latest generation of small profile transmitters, only tested them in the shops.
I do have X Pro transmitters(1 X Pro II) for each of my 3 Canon cameras and 1 Fuji camera. When set up for a shoot I can switch to a different camera, turn off the camera and transmitter that was being used, and then switch on the other camera and transmitter, even if it's the other brand, and continue the shoot. On powering up, the transmitters set themselves up to pick up the settings already on the lights, so changing the camera and transmitter is seamless, as far as the lighting and light controls are concerned. The camera settings do need to be manually set to the same as the other camera though.
A selection in the menu of the X Pro transmitters lets you choose to control only five groups, or all 16 and when set for 16, up and down arrows appear on the bottom of the screen over two buttons so you can scroll the displayed five groups up and down to see the rest and adjust them. There is a transmitter range selection in the menu as well, and I have always used the 300' range, but there is a short range of 30' available too, as some close transmitter and light distances have had problems communicating, but I have never experienced this in 6 years of use. It's always been set for 300' in my 5 transmitters.
