Nikon 24-70 2.8 Z vs Nikon 24-70 2.8 Z II Optically the same?
Kane Engelbert
p.1 #1Nikon 24-70 2.8 Z vs Nikon 24-70 2.8 Z II Optically the same?
I picked up version II when it was released and since Ive been curious if theres actually any difference whatsoever optically between these two lenses. My online search shows basically zero head to head comparisons in the optics catagory of these two fine lenses. This leads me to think they are essentially the same optically at all focal lengths. Im curious if anyone here has done an optics comparison, or may have information that sheds light on anything different optically between the two.
Dec 31, 2025 at 10:44 AM
v5planet
Details
p.1 #2Nikon 24-70 2.8 Z vs Nikon 24-70 2.8 Z II Optically the same?
To get pedantic, they are not optically identical because they have different optical formulas. The v2 in particular has fewer elements.
I haven’t seen any robust comparisons of the type you’re asking for but the internet consensus seems to say the v2 is marginally sharper across the board (at pixel peepin’ levels), and has better flare tolerance when shooting into the sun. The primary selling points over the original (which are not strong enough for me to upgrade) are the weight and zippity AF. [edit] oh yeah, and the internal zoom got better weather sealing. Though note Nikon wasn’t shy about marketing the v1 as weather sealed either.
Dec 31, 2025 at 11:22 AM
PixiPhotography
Details
p.1 #3Nikon 24-70 2.8 Z vs Nikon 24-70 2.8 Z II Optically the same?
I had a few the first gen 24-70, and its always been praised for being optically exceptional. I owned 4 of the new 24-70 II, and what I can say is that the Version 2 maintains sharpness better than the Version 1 throughout the focal length. Imo, it also has nicer bokeh. In terms of sharpness, to me, the Version 2 is just slightly sharper. It reminds me of a prime lens.
Dec 31, 2025 at 11:53 AM
RoadRnrA
Details
p.1 #4Nikon 24-70 2.8 Z vs Nikon 24-70 2.8 Z II Optically the same?
I’ve been curious about this too since picking up version II. From everything I’ve seen and shot, I can’t really find any meaningful optical difference between the two, sharpness, contrast and overall rendering all look basically identical throughout the range. The fact that there are almost no true head to head optical comparisons out there kind of reinforces the idea that there isn’t much to separate them in that regard.
Jan 01, 2026 at 10:30 AM
RoadRnrA
Details
p.1 #5Nikon 24-70 2.8 Z vs Nikon 24-70 2.8 Z II Optically the same?
Most of the info I’ve come across suggests the updates were more about AF behavior, coatings or handling rather than a redesigned optical formula. If there is any optical change, it’s subtle enough that it doesn’t show up in real world use. I’d definitely be interested if someone has done a controlled side by side, but so far I’m leaning toward them being essentially the same optically
Jan 01, 2026 at 10:38 AM
Thury
Details
p.1 #6Nikon 24-70 2.8 Z vs Nikon 24-70 2.8 Z II Optically the same?
I believe Nikon says that version II is more silent than the original. Is this true ?
Jan 01, 2026 at 11:23 AM
thezapp
Details
p.1 #7Nikon 24-70 2.8 Z vs Nikon 24-70 2.8 Z II Optically the same?
For me the version II was a no brainer since I just recently returned to Nikon. Many little things convinced me as well. Nikon also got rid of the lens display and improved everything little by little. The lens is a valid version II for the market, you may not want to get rid of the previous version, but the new one is the better lens and the sum of the improvements may be worth for some if not many to switch sooner or later - or wait for version iii. And yes, the AF is instant, the lens is light… good start to hold on for more version II zooms with similar features. Unlike movies where part II is often lacking behind, version iii of products improve even the small details.
Jan 26, 2026 at 11:59 PM
ekam
Details
p.1 #8Nikon 24-70 2.8 Z vs Nikon 24-70 2.8 Z II Optically the same?
Jan 27, 2026 at 06:55 AM
Cliff L.
Details
p.1 #9Nikon 24-70 2.8 Z vs Nikon 24-70 2.8 Z II Optically the same?
It's funny how so many people were acclaiming the original version as the greatest zoom lens ever created, and now people are dropping them like hot potatoes...
Jan 27, 2026 at 10:39 AM
RoamingScott
[X]
Details
p.1 #10Nikon 24-70 2.8 Z vs Nikon 24-70 2.8 Z II Optically the same?
If you have the OG, there's no reason to upgrade.
If you are getting into the system or lens for the first time, just pony up and get the II, as you get better and quieter AF and the new clickable control ring.
IQ will be indistinguishable.
Jan 27, 2026 at 10:42 AM
ekam
Details
p.1 #11Nikon 24-70 2.8 Z vs Nikon 24-70 2.8 Z II Optically the same?
It was the benchmark 24-70 2.8 until Mark II came.
Jan 27, 2026 at 10:46 AM
Cliff L.
Details
p.1 #12Nikon 24-70 2.8 Z vs Nikon 24-70 2.8 Z II Optically the same?
ekam wrote:
Cliff L. wroteIt's funny how so many people were acclaiming the original version as the greatest zoom lens ever created, and now people are dropping them like hot potatoes...
For Nikon, yes... and now you can't give them away.
Jan 27, 2026 at 11:42 AM
ekam
Details
p.1 #13Nikon 24-70 2.8 Z vs Nikon 24-70 2.8 Z II Optically the same?
It was the benchmark for any 24-70 2.8 from any manufacturer.
Jan 27, 2026 at 12:32 PM
Cliff L.
Details
p.1 #14Nikon 24-70 2.8 Z vs Nikon 24-70 2.8 Z II Optically the same?
I guess if you never try any other brands you won't be disappointed.
Jan 27, 2026 at 01:21 PM
bernardl
Details
p.1 #15Nikon 24-70 2.8 Z vs Nikon 24-70 2.8 Z II Optically the same?
The optical formula is completely different and contains a record low number of elements for such a top quality lens. Only 14 vs 20 in the new Sony mkII.
The camera labs review confirms that there are some optical differences, the mkII has a better bokeh (in particular background), is sharper in the extreme corners (but a bit less so in the APS-C area), has very low LoCA (it can be said to be apochromatic) and super low coma.
But the main differences are related to video, the new lens is parafocal, has a constant center of gravity and of course a significantly improved AF (quieter and faster). It is also a bit lighter obviously.
For me the video aspects were a good reason to upgrade.
Cheers,
Bernard
Edited on Jan 27, 2026 at 09:43 PM · View previous versions
Jan 27, 2026 at 06:42 PM
DWOfPaul
Details
p.1 #16Nikon 24-70 2.8 Z vs Nikon 24-70 2.8 Z II Optically the same?
Has anyone compared the vignetting between version 1 and version 2?
I do think the used market for higher end Z gear is in a bit of a weird state right now, as there are no used last gen pro bodies to go along with used pro lenses. I think once the Z9II and Z8II come out and people are selling their used Z9s and Z8s we will see a stronger market for used lenses like the 24-70mm f2.8s.
Jan 27, 2026 at 07:09 PM
Lance B
Details
p.1 #17Nikon 24-70 2.8 Z vs Nikon 24-70 2.8 Z II Optically the same?
I am not sure what you are trying to tell us.
I mean, the F mount 14-24 f2.8 was the benchmark until the Z14-24 f2.8 came along and people sold off their F mount version for the Z mount version. The 24-70 f2.8G was a benchmark lens in its day. However, in the Z mount, the Z24-70 f2.8S came along and it indeed was the benchmark in Z mount and people sold off their F mount version and bought the Z version. My car was the benchmark version in its brand until the new one comes along and people will update to the new car. As for the "greatest zoom ever created", I am not sure that it falls into that category either. It was arguably the benchmark zoom in the 24-70 f2.8 sphere, but in other zoom ranges it is not the "greatest zoom ever created". Things change and things get better, or do we want to go backwards? Is it wrong to want to have the latest and thus the best, especially if it fits your needs better?
Jan 27, 2026 at 09:50 PM
Ripolini
Details
p.1 #18Nikon 24-70 2.8 Z vs Nikon 24-70 2.8 Z II Optically the same?
Cliff probably meant that the new product (car, lens, camera) does not necessarily suit our needs better, since in most cases that item will allow us to do exactly the same things we did before, and very often not even better. The new item often gives us the illusion of satisfying our needs. Compulsive buying and marketing play a predominant role in this.
In the specific case of the 24-70/2.8 S II, it is true that a 77 mm filter, internal zoom/focus, and lower weight can be practical advantages. However, it is also true that the lens is longer, which is inconvenient: there is a greater risk of bumping into things with the camera hanging around your neck, and it takes up more space in your bag. Certainly, no one will take better photos with the new S II version than with the previous one. Simply because if we always needed the latest and greatest product to improve our images, or even just to have fun, it would mean that we would have to change job (if we are professionals) or hobby (if we are amateurs).
Consumerism has nothing to do with creativity. And photography should be, first and foremost, a creative activity.
Jan 28, 2026 at 02:25 AM
ilkka_nissila
Details
p.1 #19Nikon 24-70 2.8 Z vs Nikon 24-70 2.8 Z II Optically the same?
I do think that many people who get a new lens right after launch may not necessarily need it but have the money and like to buy new stuff and talk about it online.
In the case of the 24-70/2.8, however, from my perspective, this is the most important lens in the whole lineup and spending money on it is justified because it alone covers for 80% of my needs for paid work and a lot of the hobby activity as well. I don't have the new version, however, as I have the previous one which is really good and so I don't feel pressure to buy the new version.
I do think for many users the new version can be a significant improvement and save time and help avoid frustration. Why? If you can use it on a gimbal without rebalancing after focal length changes, and not stressing the motors, it makes the gimbal camera setup much more versatile and easier to use. With the gimbal that I have I basically have to use fixed focal length lenses because the 24-70 is a bit too heavy on my main camera and if I wanted to use the zoom while it is on the gimbal, a time-consuming rebalancing operation would have to be performed after each change in focal length. This would be a major pain and is avoided by using the new zoom because of its internal zoom design. A second scenario involves panoramic photography. In externally zooming lenses if you use a panoramic rail you have to adjust the camera's position on the rail each time you change the focal length. With an internally zooming lens this may or may not be the case; I'm hoping actually that it would reduce or eliminate this need to make adjustments, saving a great deal of time for those who do a lot of stitched panoramics. Finally, the 77 mm filter thread is used on several other lenses including the 70-200/2.8, as well as the 24, 45, and 85 mm PC-E Nikkors. Having a shared filter thread size is very helpful in managing equiment and keeping the bag contents concise. I imagine for a lot of users these factors come into play influencing the purchase decision. There are also other features such as the faster focusing motor. Anyway, despite these factors in favor of the new lens, I have not bought it and have no short-term plans to buy one, but I do feel it is not the dumbest product to spend money one.
Edit: I just realized my panoramic rail might not be long enough for the new lens. This would be an additional cost to cover if it turns out to be the case. But generally I would be very happy if I didn't have to deal with 82 mm filters. Having many different filter sizes makes me do everything possible to avoid using filters in the first place, and a 77 mm standard would work for me for the majority of situations where I'd want to use a filter.
...Show more →
Jan 28, 2026 at 03:13 AM
DWOfPaul
Details
p.1 #20Nikon 24-70 2.8 Z vs Nikon 24-70 2.8 Z II Optically the same?
Photogrpahy life published their review:
https://photographylife.com/reviews/nikon-z-24-70mm-f-2-8-s-ii/2
Overall, version II looks like a nice update. It's sharper in the center, sharper at 70mm, and has less vigntting dispate the smaller filter size. At f2.8 on the wide end, it's a bit softer in the corners than version I.
On one hand, Version II tempts me with the internal zoom and the ability to use 77mm filters. But Version I having the OLED display and used going for almost 1/2 the price of version 2, is also tempting. Optically, both lenses are very strong.
Feb 13, 2026 at 12:33 PM
FM ForumsNikon ForumJoin Upload & Sell
Switch to mobile view
