mega crops (14 images) .......
Imagemaster
p.1 #1mega crops (14 images) .......
...... can work when the end result is for a small online newsletter, even when they are from Micro Four Thirds format.
How large could you print them? Not relevant to this post and a thread on that subject would have endless answers.
Cross-posted to Post-processing & Printing Forum.
1 - eaxmple page of newsletter
2 - full image of Brant Geese
  Canon EOS-1D Mark IV    100.0-400.0 mm f/4.5-5.6 lens    400mm    f/8.0    1/3200s    1600 ISO    +1.0 EV
3 - crop of above
4 - full image of muskrat
  OM-1MarkII    OLYMPUS M.300mm F4.0 lens    300mm    f/4.0    1/90s    2500 ISO    +0.5 EV
5 - crop of above
6 - bee pollinating St. John's Wort
  OM-1MarkII    OLYMPUS M.40-150mm F2.8 lens    150mm    f/5.6    1/2000s    800 ISO    0.0 EV
7 - Common Merganser with her hands (or back) full of chicks
  OM-1MarkII    OLYMPUS M.300mm F4.0 lens    300mm    f/4.0    1/1000s    320 ISO    -0.5 EV
8 - Pileated Woodpecker
  OM-1MarkII    OM 150-400mm F4.5 lens    400mm    f/4.5    1/500s    640 ISO    0.0 EV
9 - River Otter pup
  OM-1MarkII    OLYMPUS M.300mm F4.0 lens    300mm    f/4.0    1/1000s    4000 ISO    -0.5 EV
10 - Cooper's Hawk?
  OM-1MarkII    OLYMPUS M.300mm F4.0 lens    300mm    f/4.0    1/1500s    320 ISO    +1.5 EV
11 - male Anna's Hummingbird with autumn colours in background
  OM-1MarkII    OM 150-400mm F4.5 lens    400mm    f/4.5    1/500s    1600 ISO    +0.5 EV
12 - River Otter pups frolicking
  OM-1MarkII    OM 150-400mm F4.5 lens    200mm    f/4.5    1/1000s    4000 ISO    +0.5 EV
Dec 20, 2025 at 09:24 PM
Imagemaster
Details
p.1 #2mega crops (14 images) .......
13 - butterfly on water lily
  OM-1MarkII    OLYMPUS M.40-150mm F2.8 lens    150mm    f/2.8    1/2000s    1600 ISO    -0.5 EV
14 - female Belted Kingfisher
  OM-1MarkII    OM 150-400mm F4.5 lens    400mm    f/4.5    1/3000s    640 ISO    -1.5 EV
Dec 20, 2025 at 09:25 PM
350lcpete
Details
p.1 #3mega crops (14 images) .......
Really nice images, I am experimenting with upscaling some crops of wildlife images, don’t normally need to crop but it’s interesting to experiment
Have got decent results with a program called Upscayl
Not trying huge upscaling just crops from an R5 image and then upscaling by a factor of 2 have found that the original image has to be good quality and the upscaling process adds sharpening so I have to reduce the sharpening in the original Raw conversion
They still look decent when viewed on a large 4K TV screen
Dec 21, 2025 at 04:41 AM
Imagemaster
Details
p.1 #4mega crops (14 images) .......
Upscaling probably results in as much loss of detail as cropping.
Dec 25, 2025 at 09:40 AM
cs3is
Details
p.1 #5mega crops (14 images) .......
+1
Dec 25, 2025 at 10:44 AM
gdanmitchell
Details
p.1 #6mega crops (14 images) .......
Upscaling does not lose appreciable detail — it must reveals the limits to the original detail of the image by magnifying it. (If you take a non-upscaled print and an upscaled print and position them so that they occupy equal angles of your visual field, you won’t see any difference in the amount of detail.)
Dec 25, 2025 at 10:51 AM
Imagemaster
Details
p.1 #7mega crops (14 images) .......
Great, no need to have telephoto lenses or high MP cameras, I can just upscale.
How many times with no "appreciable" detail loss, 2x, 5x, 10x?
Dec 25, 2025 at 12:58 PM
350lcpete
Details
p.1 #8mega crops (14 images) .......
Not saying that upscaling is the same as getting the shot right in the first place, or would make decent equipment unnecessary, was just interested in what you could do
I shoot full frame on decent lenses and always try not to crop
Found that if the original image was good quality I was able to view a cropped and upscaled image on a large screen and it still looked decent
Dec 27, 2025 at 04:46 AM
gdanmitchell
Details
p.1 #9mega crops (14 images) .......
You missed my point, assuming that it is my post you are replying to.
Hint: cropping isn’t the same thing as upscaling.
Dec 27, 2025 at 09:23 AM
RustyBug
Details
p.1 #10mega crops (14 images) .......
What's the difference between upscaling an "uncropped" image to achieve a given size vs. upscaling a "cropped" image to achieve a given size.
If I want xxx PPI > DPI for a size of YY x ZZ ... and I don't have the pixels to achieve that, I have basic choices to either use the pixels I have and accept a lower PPI (diff limits of applicability), or take the pixels I have and upscale them ... which means use a math algorithm to fill in the "stretched" blanks, so the continuity seems intact (i.e. not pixelated). That, or accept a smaller print size to achieve the desired PPI > DPI.
Either way ... the matter of working with limited resolution and artificially increasing the file dimension seems to be the same process whether you're going original to uber-large, or going cropped to normal. Magnification + fill in the gaps remains the same process for both, as it pertains to PPI > DPI for size / viewing distance relationships. So, yeah, they are kinda the same thing ... as you complete the process.
At the very least, the are very close cousins, even if you choose to not perceive them as identical twins. Just depends if you are adding in (or not) the upscale process to get to your final size (from cropped or uncropped). In either case, you cannot create more detail. You can just fill in the gaps. The optical projection is responsible for the detail. The pixels are just how small are you slicing / dicing the pepperoni.
+1 Probably ... since it is really the same thing.
Although, I'd mention that the actual contained detail really isn't changed (i.e. loss) ... it's only stretched over a different area (still, similar process / effect for both), etc. for a different rate of transition, which can appear as a perceived reduction in acutance. Again, magnification plays the same role in both (and, yes intertwined with viewing distance, etc.).
Dec 27, 2025 at 11:23 AM
Imagemaster
Details
p.1 #11mega crops (14 images) .......
Hint: Quote where I said they were the same thing.
Dec 27, 2025 at 04:08 PM
gdanmitchell
Details
p.1 #12mega crops (14 images) .......
Hint: Your response indicates it.
Does it make you feel all tingly and alive inside to play this game? ;-)
Dec 27, 2025 at 05:03 PM
Imagemaster
Details
p.1 #13mega crops (14 images) .......
That is because you always interpret other members' responses to suit yourself.
It obviously makes you feel that way since here you are playing another inning.
Dec 27, 2025 at 06:49 PM
RustyBug
Details
p.1 #14mega crops (14 images) .......
Dan, your antagonism toward fellow members is not becoming to the gold standard of FM (imo). Please take inventory of how well you are representing FM with your antagonsim of fellow members.
If you want to discuss the technical merits of the topic, and present a different perspective that opposes others ... sure, share your .02 on the matter. But, the antagonistic rhetoric isn't helpful (imo), and is sophomoric at best, and well beneath the level of regard that once accompanied your name. As the seasoned veteran of FM as you are, I'd hope you'd be more considerate to your fellow members than you have been of late.
Think about it ... just wondering if you can find the high(er) road, going forward.
HTH
Fred, feel free to delete / edit my post, as you deem appropriate.
Dec 27, 2025 at 08:29 PM
pixelpeeping
Details
p.1 #15mega crops (14 images) .......
Nice! A little crunchy on some fat hem but hey, you're out there making it happen. Enjoy the process!
Mar 05, 2026 at 08:29 AM
Imagemaster
Details
p.1 #16mega crops (14 images) .......
pixelpeeping wrote:
Nice! A little crunchy on some fat hem ....
mega crops .......
Mar 10, 2026 at 09:51 PM
FM ForumsNature & WildlifeJoin Upload & Sell
Switch to mobile view
