Auto ISO question on A7iv for stills
snegron7
p.1 #1Auto ISO question on A7iv for stills
I set the Auto ISO to a minimum of 100 for the lowest, 12,800 for the highest. However, when I'm shooting outside in strong daylight, the lowest ISO defaults to ISO 800 instead of ISO 100 like I set it for. I find myself having to manually enter my desired ISO when shooting outdoors to override the minimum ISO 800 that the A7iv defaults to.
Again, I changed it both in my menu systen and in the quick menu system that shows up when you press the Fn button on the back of the camera.
Also, again, this is when I'm shooting stills. I understand that the native ISO for video (s log) is ISO 800, but I'm not shooting video at all with this camera.
How do I get it to stay at ISO 100-12,800 when shooting with Auto ISO and not default to ISO 800?
Dec 14, 2025 at 12:25 PM
huggies
Details
p.1 #2Auto ISO question on A7iv for stills
Dec 14, 2025 at 12:33 PM
snegron7
Details
p.1 #3Auto ISO question on A7iv for stills
huggies wrote:
https://helpguide.sony.net/ilc/2110/v1/en/contents/TP1000640843.html
Which value are you using for this setting?
What do you mean by "which value"?
Dec 14, 2025 at 12:35 PM
chez
Details
p.1 #4Auto ISO question on A7iv for stills
...Show more →
What’s you shutter and aperture?
Dec 14, 2025 at 12:48 PM
snegron7
Details
p.1 #5Auto ISO question on A7iv for stills
chez wrote:
snegron7 wroteI set the Auto ISO to a minimum of 100 for the lowest, 12,800 for the highest. However, when I'm shooting outside in strong daylight, the lowest ISO defaults to ISO 800 instead of ISO 100 like I set it for. I find myself having to manually enter my desired ISO when shooting outdoors to override the minimum ISO 800 that the A7iv defaults to.
Depends on the lighting. For example, today it was a bright, sunny day with mixed clouds. I shot at f8 and 1/400. It defaulted to ISO 800. However, I then manually set it to ISO 100 and was properly exposed at f/8, 1/125.
I know there are several stops difference with the shutter speed I provided, but when I'm shooting in Aperture Priority, it defaults to ISO 800 at whatever aperture I select (camera ups the shutter speed to compensate for ISO 800).
Dec 14, 2025 at 12:59 PM
Nifty Fifty
Details
p.1 #6Auto ISO question on A7iv for stills
I would try to remember what I changed and where, because the problem probably hasn't "always" existed.
Dec 14, 2025 at 01:05 PM
chez
Details
p.1 #7Auto ISO question on A7iv for stills
Maybe you have the minimum shutter set to 1/400.
Dec 14, 2025 at 01:24 PM
snegron7
Details
p.1 #8Auto ISO question on A7iv for stills
I reset it again and took a few test shots. Looks like it's now staying at the ISO I set for Auto ISO (100 to 12,800). I tried it in Aperture Priority mode, and it didn't default back to ISO 800.
Here's a link to a test shot I took with it compared to my Canon R6 (same settings on my end, but both cameras decided on different shutter speeds).
https://www.flickr.com/gp/195506119@N07/wUa9d87H3w
Focal point was the eye in the middle. Both cameras set to Aperture Priority, Auto ISO, F8.
Dec 14, 2025 at 01:29 PM
huggies
Details
p.1 #9Auto ISO question on A7iv for stills
Exactly.
Dec 14, 2025 at 01:47 PM
chez
Details
p.1 #10Auto ISO question on A7iv for stills
Didn’t answer my question. Did you check if a minimum shutter was set for your autoiso?
Dec 14, 2025 at 02:36 PM
snegron7
Details
p.1 #11Auto ISO question on A7iv for stills
chez wrote:
snegron7 wroteI reset it again and took a few test shots. Looks like it's now staying at the ISO I set for Auto ISO (100 to 12,800). I tried it in Aperture Priority mode, and it didn't default back to ISO 800.
ISO Minimum SS set to Auto.
Dec 14, 2025 at 02:40 PM
jeffbuzz
Details
p.1 #12Auto ISO question on A7iv for stills
What lens? ISO AUTO Min. SS is based on focal length.
If you have a 400mm lens and ISO AUTO Min. SS set to STD, camera will try to maintain 1/400.
SLOWER = 1/(f/4) = 1/100
SLOW = 1/(f/2) = 1/200
STD = 1/f = 1/400
FAST = 1/(f*2) = 1/800
FASTER 1/(f*4) = 1/1600
Dec 14, 2025 at 10:44 PM
snegron7
Details
p.1 #13Auto ISO question on A7iv for stills
STD = 1/f = 1/400
Only 3 lenses I currently use on my A7iv are:
- Tamron 20-40mm f2.8
- Tamron 17-28mm f2.8
- Tamron 28-200mm f2.8/5.6
It was doing this with all three lenses.
Dec 15, 2025 at 06:42 AM
j4nu
Details
p.1 #14Auto ISO question on A7iv for stills
So, what's the value of ISO AUTO Min. SS you used?
STD?
Dec 15, 2025 at 06:52 AM
snegron7
Details
p.1 #15Auto ISO question on A7iv for stills
STD?
"Standard"
Dec 15, 2025 at 11:12 AM
j4nu
Details
p.1 #16Auto ISO question on A7iv for stills
So, it's like it was said already: 1/FL rule for shutter speed.
The other thing that might affect the exposure is exposure compensation dial.
Dec 15, 2025 at 11:35 AM
snegron7
Details
p.1 #17Auto ISO question on A7iv for stills
So, basically in order for me to get the lowest ISO possible with my A7iv, I have to set it myself since Auto ISO is pretty much useless.
Ironically, I don't have this issue with my R6II. I set it to Auto ISO and it always selects the lowest ISO possible regardless of whether I'm shooting in Aperture Priority, Shutter, or Manual with no extra steps necessary.
Dec 15, 2025 at 11:46 AM
Cliff L.
Details
p.1 #18Auto ISO question on A7iv for stills
snegron7 wrote:
j4nu wroteSo, it's like it was said already: 1/FL rule for shutter speed.
Then why don't you just use your R6 II, if setting the Sony Auto ISO shutter speed to "SLOWER" is so difficult for you?
Dec 15, 2025 at 11:58 AM
j4nu
Details
p.1 #19Auto ISO question on A7iv for stills
It's far from useless, you just need to learn how it works. Maybe you're just used to Canon.
I use auto-iso when I can't get the shot with 100ISO. Most of the time I manually set the exact value (not STD, etc. but an actual value like 1/x s) and it works flawlessly. If I switch from static to more dynamic targets, I simply bump ISO AUTO Min. SS, as I have it on the control wheel. If I'm shooting a zoom and I'm worried I might shake the camera too much I switch to STD and similar.
So, for each his own ...
Dec 15, 2025 at 11:59 AM
Jonas B
Details
p.1 #20Auto ISO question on A7iv for stills
I don't have the answer to the problem here. What I can say for sure is that the AutoISO works, and has worked just fine with my Sony cameras of later models. I don't see any reason for the A7iv to behave differently.
This leads me to think you need to check all your settings again as there is something odd going on here. You can of course make a conclusion about "Auto ISO is pretty much useless" but that doesn't seem rational at all.
EDIT: I see j4nu was faster, sorry for nagging.
Dec 15, 2025 at 12:02 PM
Switch to mobile view
