I stopped shooting film decades ago, only recently got a full-frame digital camera and also a nice rig for scanning my old slides. Lately I've been contemplating putting my film camera back to work. But I'm not sure what direction to go next.
We recently found an undeveloped roll of Gold 200 and had a lab develop and scan it. The scans had good color but only marginal sharpness. I'm not sure if it was just low-quality scanning or because the film was 20+ years old. They sent me the roll of negatives so I tried scanning one of the images. For years I've been using Corel PaintShop Pro X which has a "Negative Image" conversion which I applied. The result was a recognizable image but with a strong green overlay. PSPro also has a "Faded Image" tool which I tried. That helped some. I played around with other color tweaks but could not duplicate what came from the lab. So I wonder if it was the film or incorrect PSPro negative conversion. I see that GIMP can do some negative conversion also, haven't tried it on those negatives.
If there is a reasonably lightweight image processing program I might try it. Don't want to spend much (or any) money besides the film and processing until I decide it's something I really want to do. I have Darktable but didn't see an obvious way forward with it.
Alternatively I could pick up shooting slides again. It's been decades since I pulled out the slide projector but at least it's a way to use the slides themselves, and I can always scan them for digital viewing anyway. With print film I can't do anything with them except scan and convert. Well, I could print them but that's not a direction I want to go, don't even have a color printer. Unless a printed image is put on display, viewing it is an activity done by at most only a few people at a time. Viewing slides is a social occasion, and digital images can be shared and viewed on many different devices.
So I think I know the answer but I'd still like to try processing negatives. Any recommendations?
Thanks.
I rebooted my film photography skills 10 years ago after I was handed a free Beseler 45MXT enlarger with enlarger lens, and I was curious to set up my own darkroom to make silver gelatin prints from film. I started this after having fully moved to digital photography in 2005. Here are some pros and cons to consider when doing film photography again:
+ It is kind of addictive: I tried all kind of negative sizes to make prints of including 35 mm, 6x6 and 6x7 cm, and 4x5" sizes. In the end I mostly use to this day 35 mm. Easier to handle and walk around with my Leica M camera than with any of my medium format cameras. The resolution from a 35 mm negative is more than enough to make great 11x14" size darkroom prints.
+ Capturing things only film reveals: this is IMO a big plus to use film - capturing halos/highlights in a way only film can provide, also seeing how light can bend around dark silhouettes is something digital does not capture as well.
+Quality: as a plus, some film - especially slide film as Velvia 50 - provides astonishing colors in specific shooting situations like sunrises/sunsets etc. This is hard to get from a modern digital camera the same way without need of a lot of post processing of the digital file. But overall, this is more the exemption than the standard - I find color negative film can be more easily copied with digital getting to a very similar look. The same is true for monochrome - I am using B&W film just to enjoy its process but not to get something "better" than what digital and especially monochrome digital cameras can do now (with exemption what I stated in the bullet point above). Original film grain is seen by many film photographers as a plus to have - I have never been a fan of it to be honest. I prefer low grain film at low ISO for this reason - but this is subjective.
- Cost: this has become a more significant issue in recent years especially since the pandemic when prices for some film gear and film itelf started skyrocketing. Biggest culprit for many - me included - is the staggering increases of film price. SLR cameras can still be obtained for around $150 in good condition, but rangefinder camera prices remain high for brands from Leica, Voigtlander, or Nikon.
- Film processing: I put it down as a negative even it has the positive side of learning and enjoying the process to develop and process the film yourself and not using an external lab. Avoiding an external lab keeps you in control of the whole process which is a plus, but it is also very time consuming to develop your own films (normally this is still the fastest step!), scanning (can be tedious for various reasons), and potentially printing either in the darkroom or from digitized film photos. I cannot see myself doing film potentially for a professional basis - digital clearly has the edge here regarding time needed for post processing. For a hobby basis - like in my case - it is fine since I can vest the time without external pressure to deliver.
- Travel: big con nowadays with stronger airport scanners present which can affect more sensitive film above ISO 400. Hand-checking film at the safety check is a possibility, but it can be tedious in a crowded check-in to ask TSA for checking each film separately. It was one big factor for me to upgrade to a monochrome based digital Leica M 246 camera to take this one with me instead of Leica M film camera for travel involving flights.
- Quality: as a con, the sharpness with 35 mm negative film is never as good as with a modern digital camera. Better sharpness is obtained with larger film size, but then the whole camera gear also gets bigger.
From your description above it sounds that your film journey might be more a short one to break from digital for once. You explored one of the most difficult parts of the film processing steps: scanning/digitization. Many hurdles here to get things right. It took me years to optimize my film scanning process and to get the white balance right close to the original film. This starts which kind of digitization method to use (digital camera with NagtiveLabPro for example or film scanners with scan software like Vuescan just to mention a few).
When already having a digital camera as you mentioned, you should vest in a decent post processing software program like Lightroom. Darktable is another good free choice but from own experience with it less intuitive to use.
retrofocus wrote:
From your description above it sounds that your film journey might be more a short one to break from digital for once...
Thank you for the great reply. It gave me a few more things to think about, for sure.
Partly I'm wishing I could play with my 50+ y.o. Nikkormat again. I found a great scanning platform which holds my camera w/90mm Tamron macro, provides a white light source, has a slide holder which a co-worker 3-d printed, and sits on a tripod. All easy to use. So a first effort means the cost of a new battery for the Nikkormat's meter, a roll of slide film, and its processing. But then I ask myself what next? Do I want to start experimenting with different films?
jimmuller wrote: retrofocus wrote...
From your description above it sounds that your film journey might be more a short one to break from digital for once...Thank you for the great reply. It gave me a few more things to think about, for sure.
Thanks again. I will read it several more times! ...Show more →
Well you've got a scanning setup, a camera, and you've located a lab. I would say that the next step is to expose some film and see if you like the process of using film itself before worrying about what's next.
Is anything in particular holding you back from just jumping in?
The answer is pretty much dependent on why you want to shoot. My film cameras only saw the inside of my safe until about six months ago. My personality type is not one to envy in that I become quite obsessive about getting the maximum out of what I do. Now, I think that you can get the maximum out of enjoying the shooting process via film vs digital. I would recommend shooting and sending everything to Citizen’s Photo in Portland. They do a great job with color negative and slide. I haven’t yet used them for B&W, but there results are superb, but then again I copy my own negatives, which I would recommend against.
Personally, I think that digital has much more to offer when compared to trying to copy film on the cheap. On the other hand, I would also recommend having Citizen’s provide the highest resolution TIFF..not Jpg files. This might result in a bit of a wait for the results, but you would get a much higher quality result than doing things at home. Now, if you want to do things at home and yet keep the quality high and you are only using 35mm I would suggest the Easy35 and using your digital camera with a macro lens to do the copies. I would not consider this doing things on the cheap, but rather doing thing on the smart/efficient.
Here is a link to my recent description of my setup and why I went this direction. My post was intended to counter those that suggest that low resolution cameras can get all information when copying film.
Good question. @bwcolor provides the answer:
... My post was intended to counter those that suggest that low resolution cameras can get all information when copying film.
I confess my reasons may be purely whimsical. I can't say what I would want to shoot with film, certainly aren't pushing my digital camera to its limits yet!
But as for using a low resolution camera, it's a Z5-II, 24 megapixel, image size roughly 6000x4000. I set up scanning rig for the 1000+ slides I started shooting 50 years ago. Ah, it seems to work just fine! I'll let you folks judge some examples. Taken with my Nikkormat in 1976.
Trinity Church, Boston, reflected in the windows of the Hancock Building
I have been doing photography since high school in the 1960’s. Moved to digital when it seemed to rival film. In the last year started using film again. Medium format on 3D printed cameras which means full manual operation (even film winding). Not to convienient to use a friends lab so I now have my film processed in town and scan on an old Epson V700.
The whole process is very slow and enjoyable compared to bang-bang-bang with digital. Instead of a few hundred exposures in a day I take 4.
And the results film gives me cannot be matched by digital, nor the pleasure doing photography in a slow thoughtful pace.
jimmuller wrote: OffTrail wroteWell you've got a scanning setup, a camera, and you've located a lab. I would say that the next step is to expose some film and see if you like the process of using film itself before worrying about what's next.
Is anything in particular holding you back from just jumping in?Good question. @bwcolor@ provides the answer:
bwcolor wroteThe answer is pretty much dependent on why you want to shoot.
... My post was intended to counter those that suggest that low resolution cameras can get all information when copying film.I confess my reasons may be purely whimsical. I can't say what I would want to shoot with film, certainly aren't pushing my digital camera to its limits yet!
Congratulations on your marriage and like marriage, you are the final word. If you like what you have then you have your answer. The point is to have fun, at least for those without clients to please.
Is your Tamron macro lens AF? When I started scanning w a digicam, I used a manual focus lens and rarely was satosfied w the image sharpness. I then switched to an AF Nikon macro lens - the 60G - and my scans were so much sharper. Also it focused in a fraction of a second!
I know you already have your set up, but a Nikon 60g or the new Z 50mm macro lens with the ES2 film holder makes it effortless.
When already having a digital camera as you mentioned, you should vest in a decent post processing software program like Lightroom. Darktable is another good free choice but from own experience with it less intuitive to use. ...Show more →
You pretty much nailed all the pros and cons of shooting film that I can think of!
I currently have several film cameras in near pristine condition (three Canon FT QL's, two Pentax Super Programs, two Nikon F3HP's, a Nikon F with standard prism, Nikon F with FTN Photomic Viewfinder, Nikon F2A, Nikon F5, Nikon F100, Nikon FM2N, Nikon F80, Nikon S2 Rangefinder, Mamiya 645J, Mamiya 645E, Mamiya RB67, and I probably missed a few other film cameras I can't remember right now).
Regardless of all my film equipment, there are two things I don't have;
1. A good subject/location to photograph (I live in Florida, and other than the occasional bird, there is nothing of visual interest here to capture).
2. Resources (money and time) to travel to visually interesting locations outside of Florida.
So, my film equipment spends its life stored away. I recently learned the hard way that you need to "exercise" (use) film cameras frequently so they won't lock up. I lost two good cameras (a Nikon FM2N and a Nikon F3) because of lack of use.
Some very good responses here. You are all helping me solidify my thoughts. So thank you all.
Yes, but... It's an F-mount lens for my Z camera. I'm shooting everything with the FTZ adapter. I wanted to use all my old prime lenses, which BTW would cost me $5000 or more to replace with modern lenses. When I inquired about a scanning rig the shop had this Tamron for only $75; there isn't much demand F-mount lenses. It doesn't do AF but the viewfinder does show the internal focus indicator. So focus is not a problem. In any case, setting up a scan is something to be enjoyed slowly over a beer, much like shooting film but with beer!
snegron7 wrote: retrofocus wroteI rebooted my film photography skills 10 years ago after I was handed a free Beseler 45MXT enlarger with enlarger lens, and I was curious to set up my own darkroom to make silver gelatin prints from film. I started this after having fully moved to digital photography in 2005. Here are some pros and cons to consider when doing film photography again:
When already having a digital camera as you mentioned, you should vest in a decent post processing software program like Lightroom. Darktable is another good free choice but from own experience with it less intuitive to use.You pretty much nailed all the pros and cons of shooting film that I can think of!
So, my film equipment spends its life stored away. I recently learned the hard way that you need to "exercise" (use) film cameras frequently so they won't lock up. I lost two good cameras (a Nikon FM2N and a Nikon F3) because of lack of use....Show more →
Aren’t points one and two challenges rather than limits? Isn’t part of the challenge to make something visually interesting? I live in a flat, fast growing small town North of Dallas and I’ve more than once repeated the mantra contained in point one. So, this isn’t a criticism pointed at you any more than pointed at me. My problem isn’t my location, but rather my lack of imagination and creativity. I no longer live in Northern California, where I can step outside and there is something to photograph…and no, I don’t miss California at all. This isn’t Japan, or Korea where I find the cultural differences interesting. That said, after a week in Japan, an old Japanese guy warned me not to go into a restaurant and this was the first person, on the street, to speak with me. We talked for five minutes and he told me that he lived within five miles of where I live for over ten years and then he raved about Texas. Somewhat made me want to return home. So, your challenge is my challenge. Grab a macro lens. Set up a project with a specific goal, purpose and a measureable end point. For me, the end point is a printed album. I can document an old small town which two years ago was the fastest growing town in the U.S.
Desmolicious wroteIs your Tamron macro lens AF?Yes, but... It's an F-mount lens for my Z camera. I'm shooting everything with the FTZ adapter. I wanted to use all my old prime lenses, which BTW would cost me $5000 or more to replace with modern lenses. When I inquired about a scanning rig the shop had this Tamron for only $75; there isn't much demand F-mount lenses. It doesn't do AF but the viewfinder does show the internal focus indicator. So focus is not a problem. In any case, setting up a scan is something to be enjoyed slowly over a beer, much like shooting film but with beer!...Show more →
I’m just saying, it is much more accurate and light years quicker using an AF lens. It was by far the single best change I did to my scanning set up. Once you do it you’ll never go back. My scans went from ok sharpness to bitingly sharp.
On further review, the ruling on the field (as they say in NFL games) is that the idea may be foolish for now. The thrill of carrying two cameras on a walk (pretending I'm a world famous photojournalist ) and hearing the occasional ker-click of the Nikkormat's shutter will likely wear off quickly, especially considering what the Z can do. I may think otherwise one day. One day I may even buy an AF lens! But first I should at least finish processing the hundreds of slides still unviewed resting in their storage containers.
bwcolor wrote: snegron7 wroteretrofocus wroteI rebooted my film photography skills 10 years ago after I was handed a free Beseler 45MXT enlarger with enlarger lens, and I was curious to set up my own darkroom to make silver gelatin prints from film. I started this after having fully moved to digital photography in 2005. Here are some pros and cons to consider when doing film photography again:
So, my film equipment spends its life stored away. I recently learned the hard way that you need to "exercise" (use) film cameras frequently so they won't lock up. I lost two good cameras (a Nikon FM2N and a Nikon F3) because of lack of use.Aren’t points one and two challenges rather than limits? Isn’t part of the challenge to make something visually interesting? I live in a flat, fast growing small town North of Dallas and I’ve more than once repeated the mantra contained in point one. So, this isn’t a criticism pointed at you any more than pointed at me. My problem isn’t my location, but rather my lack of imagination and creativity. I no longer live in Northern California, where I can step outside and there is something to photograph…and no, I don’t miss California at all. This isn’t Japan, or Korea where I find the cultural differences interesting. That said, after a week in Japan, an old Japanese guy warned me not to go into a restaurant and this was the first person, on the street, to speak with me. We talked for five minutes and he told me that he lived within five miles of where I live for over ten years and then he raved about Texas. Somewhat made me want to return home. So, your challenge is my challenge. Grab a macro lens. Set up a project with a specific goal, purpose and a measureable end point. For me, the end point is a printed album. I can document an old small town which two years ago was the fastest growing town in the U.S....Show more →
I've been living in Florida for over 25 years. There isn't a bug, bird, or beach I haven't photographed several times over! My inspiration flourishes whenever I travel outside of Florida. At least in Dallas you can drive for a few hours and grab some great images at Palo Duro Canyon in Amarillo. You can also do astrophotography; light pollution in Florida is pretty much everywhere.
At one point I used to shoot weddings. However, I gave that up a long time ago. The only people I photograph are friends and family members.
There are no old towns, pretty marinas, or picturesque trails anywhere near me. There are only mini-malls, gated communities, and cookie-cutter homes everywhere. I can barely find anything worthwhile to photograph with my digital cameras, let alone my film cameras.
We have plenty of grand vistas, rocky shorelines, waterfalls and unique architecture here in Oregon but over the last year, we have had so many various medical appointments or other events that we did not venture very far from home. The one time we did, a major Pacific storm kept us in the motel room for several days. A while back, I started photographing details and textures. It's fun to find the abstract. Take some time to look at the images in the Show Us Your Film Shots forum.
Use Other Door
Kodak Retina IIa, Schneider 50 2.0,Fujicolor 400
Ole Bolle, Fujica Super 6, 75mm 3.5 Fujinar, Fomapan 100, Rodinal 1:50
Almost exactly 12mths ago I had the same urge
Bought a used fully working canon eos1 incase my old eos600 should die, then bought a dozen rolls of film…
It ended right there
The cost of developing and printing is just too high for me…. Especially given the limited frames…24exp in my case. I just couldn’t commit to loading the film onto the camera
I like this thread. I just re-read it after a bit of living life. It’s Christmas and my focus has been on finding TTL speedlights that function with my X2Dii. Have many Godox.. forget it..I can control a number of lights in manual, but I want to be able to do TTL for fill-flash. I discovered that I had so many systems that I really can’t use any of them effortlessly. Anyway, I picked up a Profoto Connect, A10 and A2 light with some modifiers and they work great with the Hasselblad. The reason why this was good news, is that I’m really taken with the X2Dii and will be selling my M11 Monochrom, along with two XCD prime lenses. So, when I fly I’ll take the X2Dii, 20-35mm, 35-100mm, Profoto Connect and the A2. My previously favorite camera, the M11M will be gone.
I understand the frustration of limited time and resources. My expensive camera equipment is now funded by selling 50+ years of buying equipment slowly over time. My personal challenge, when traveling, is to get images a little bit different than what every smartphone captures and endlessly post online. I can think of two new challenges to accomplish this. First, the use of the flash and second macro-photography. So, maybe the scenery near where you live hasn’t changed, but possibly you could record that scenery in a different ‘light’/context.
I’ve obtained parts to bring my Jobo back to full functioning order and purchased film & chemicals to get back to processing and copying everything at home.
My friend of fifty years and I recently completed a long road trip. He brought his never used M11 Monochrom and I took my not recently used Mamiya 7ii. He took two photos with the Leica and used his phone for the rest of the trip. I found that I really enjoyed shooting film. He’s now talking about buying a Leica EV-1 and using his 24mm lens, which approximates the lens in his smartphone. I’m sure he will still use his smartphone for the majority of shots. The point here is that each of us must determine what we find enjoyable. For me, I like the film process, from having a limited number of shots, relatively fixed ISO, a variety of film looks, no chimping and the development/copying process. Others prefer smartphone and upload to Instagram.
Merry Christmas.. hopefully each of you has some family and friends to celebrate the day.
