Opinion on this light setup please!
Sharona
p.1 #1Opinion on this light setup please!
Hello - I'm buying a portable light set-up for our organization. They will be used for both stills and video. Our videographer has a larger set up, but these would be used - and be more handy for - on location shoots. The stills people (including me) need something to throw on some light in large conference rooms, or to add fill in other shoots that are reasonably well-lit. I did some searching and found these, but if there are other, simple, battery powered kits like this that you'd recommend, I'd love to hear about them.
Lume Cube Studio Panel Lighting Kit Two Edge-Lit LED Panel Lights with Stands
Thank you for your wisdom; I'm clueless when it comes to lighting.
Dec 09, 2025 at 09:36 AM
sungphoto
Details
p.1 #2Opinion on this light setup please!
I’d recommend just getting a speed lite aka on camera flash and bouncing the light against the ceiling, depending on how high they are. Godox V1 Pro is a reasonably priced solution, though their TTL (through the lens metering) can be a little less reliable than flashes native to your camera system. Profoto makes the A series lights but those are overpriced for what they are, though I prefer them for color consistency and interoperability with all their other strobes.
If you need a little additional light focused on a particular area or person, the Angler fastboxes work with the Godox V1 (and Profoto A series) and are also quite affordable.
Continuous lights are nice but they typically need to be plugged into the wall (though there are options with some lights to power with V mount or other batteries).
You’ll also want to think about either adding a color correction gel to match the ambient light from overhead lights or adjusting your camera settings to eliminate the ambient.
Dec 09, 2025 at 01:05 PM
Sharona
Details
p.1 #3Opinion on this light setup please!
Thanks - We need continuous light. Flash doesn't handle our needs. This set below is battery operated and I wondered if anyone has used it.
Dec 10, 2025 at 10:36 AM
story_teller
Details
p.1 #4Opinion on this light setup please!
You need to find out several things -
- How many lights are you going to need? How much light does each one actually provide?
- A fully charged battery only provides 80-minutes. Is the battery built in or can it be quickly changed out for a fresh battery to provide more shooting time?
- If the battery is fixed, can you charge the battery via commercial power while you’re shooting? Otherwise you’ll have to stop and wait while the battery charges.
You’ll find they are limited for use outdoors during the day.
I’ve used the Arri flat panel LEDs, but those are very expensive.
Dec 11, 2025 at 07:35 AM
Sharona
Details
p.1 #5Opinion on this light setup please!
...Show more →
Thank you. Excellent questions and thoughts. We will have to ponder this some more. Although 80 minutes is probably quite sufficient for what we do.
THanks again!
Dec 11, 2025 at 01:14 PM
EB-1
Details
p.1 #6Opinion on this light setup please!
Those are rather tiny (4.8 x 2.6 x 0.3") and not very bright (270 Lux), so mainly for close subjects.
Check your EV calculations to see if they are bright enough.
Dec 11, 2025 at 10:06 PM
Sharona
Details
p.1 #7Opinion on this light setup please!
EB - I think you were looking at the wrong setup. Here is the one I'm considering:
https://lumecube.com/products/studio-panel-lighting-kit
Edge Lit Technology - 200 inward-facing LEDs with built-in diffusion delivers powerful but soft light with even coverage
2700K - 7500K Color Temperature - Set the mood or maintain true-to-life skin tones in any environment
2100 lux at .5 meters - Ensures well-lit, detailed shots with enhanced clarity and definition
1800 Lumens - Provides the optimal level of brightness to illuminate you or your subject in unpredictable lighting conditions
96+ CRI Rating - Impeccable color accuracy ensures that you or your subject appear natural and vibrant
Dimensions - 10.5" (width) x 7.4” (height) x 1.0" (depth)
Weight - 1.54 lbs (700g)
Rechargeable Lithium Battery - 80 minutes of light at max brightness
Remote Control - Full control of your light from a distance, including convenient shortcut buttons
Barndoors - Custom-engineered barndoors allow you to focus and shape your light
Battery Life Indicator - LCD screen displays to-the-minute battery life that automatically updates as settings change
70” Stand - Easy to use lightweight aluminum stand adjusts from 18'' to 70''
Dec 13, 2025 at 07:41 AM
CharleyL
Details
p.1 #8Opinion on this light setup please!
You haven't yet said what you plan to shoot? A single person, group (how large), product, or still life (on table top or other)? Without knowing this, any light suggested will likely be wrong.
Charley
Dec 17, 2025 at 08:30 AM
Sharona
Details
p.1 #9Opinion on this light setup please!
Charley
Thanks - Group shots or single outdoor portraits, indoors in a medical center environment. I think we like this set up; I mostly wondered about the brand, is it reliable, is there something similar out there to consider, etc. Thanks again..
Dec 22, 2025 at 08:25 AM
sungphoto
Details
p.1 #10Opinion on this light setup please!
These lights won’t be powerful enough for the conditions and types of shots you want to accomplish, and the small size of the lights without diffusion will be harsh on skin.
Sharona wrote:
CharleyL wroteYou haven't yet said what you plan to shoot? A single person, group (how large), product, or still life (on table top or other)? Without knowing this, any light suggested will likely be wrong.
Charley
Dec 22, 2025 at 10:18 AM
Oscarsmadness
Details
p.1 #11Opinion on this light setup please!
These are my thoughts exactly. The panels that you're thinking about are good equipment, on paper. I'm concerned that they won't match with the way you're going to use them.
Are the Lumecube XL COB lights an option? You can get Bowens adapters for them, which means you can mount all kinds of diffusers and modifiers on the lights. Your video person can use them too (for now, I'm ignoring the reduced light output effect).
There may be something here that I don't know. I'd highly recommend you borrow or rent a set of light panels and do several test shoots before you buy them. Or, prepare a plan to sell them if you buy and they don't work out. Based on what I know from this thread, it's more likely than not that these panels won't do what you need them to do.
Jan 02, 2026 at 05:21 PM
sungphoto
Details
p.1 #12Opinion on this light setup please!
Oscarsmadness wrote:
sungphoto wroteThese lights won’t be powerful enough for the conditions and types of shots you want to accomplish, and the small size of the lights without diffusion will be harsh on skin.
...Show more →
Yeah some version of a COB LED light with a bowens mount would for sure be my recommendation too, somewhere in the 300-500 watt range. RGB would be nice but there would be some sacrifice in max power output, so daylight balanced would be best if they are being used outside. Some LED lights take V mount batteries so won’t need to be run with wall power.
If the video team mentioned in the thread has their own lights, they probably have some of these lights on hand. All that said, I would still opt for strobes as it would be cheaper and more portable.
Jan 02, 2026 at 08:42 PM
FM ForumsLighting & Studio TechniquesJoin Upload & Sell
Switch to mobile view
