DxO PureRAW - keep a copy of your original RAW file
Imagemaster
p.1 #1DxO PureRAW - keep a copy of your original RAW file
Should I delete my original image after processing it with DxO PureRAW?
This information applies to all versions
This depends entirely on you, and on what you intend to do with your images. Keep in mind that a RAW file is THE original, and cannot be replaced.
On one hand, DNGs created by DxO PureRAW can be considered 'perfect' files, and if you are sure that you won't ever want to reprocess them, you could delete your RAWs.
On the other hand, many users have been so impressed with the high-quality results delivered by DxO DeepPRIME that they decided to reprocess their archived RAWs, many
...Show more →
https://support.dxo.com/hc/en-us/articles/4433333661201-Should-I-delete-my-original-image-after-processing-it-with-DxO-PureRAW
Nov 24, 2025 at 09:30 PM
EB-1
Details
p.1 #2DxO PureRAW - keep a copy of your original RAW file
That's not specific to DXO. You should always keep RAW files in native format if having the original is important. Nobody knows what future software will bring and to what degree the same processing can be applied to any kind of DNG as the original RAW file. Obviously for (commercial) work that is completely finished it may not be worthwhile.
Nov 24, 2025 at 11:10 PM
msadat
Details
p.1 #3DxO PureRAW - keep a copy of your original RAW file
Dxo creates flatten dng, when I use it, I delete the raw files, I don’t need to keep two sets of raw file
Nov 25, 2025 at 05:41 PM
ruthenium
Details
p.1 #4DxO PureRAW - keep a copy of your original RAW file
The answer "it depends..." indeed.
It depends on where the subsequent processing would take place and whether the processing software/app (Lightroom, PS, Capture One, etc) works well with the DNGs from DxO PureRAW, or if processing from the genuine raw files somehow works better. For example, in my experience, I find that processing DNG files (generated by DxO) in Capture One works well, possibly even better than processing from the corresponding raw files.
Nov 25, 2025 at 07:42 PM
Oscarsmadness
Details
p.1 #5DxO PureRAW - keep a copy of your original RAW file
I keep my SOOC raws. That's just my choice. I reprocess old photos from time to time, sometimes to measure the improvements to modern software, sometimes to measure how my skill has improved (or not improved).
I've never had to use a RAW to establish provenance. That's probably a good thing, because if I ever have to do that, it likely will be an unpleasant way to spend my time.
Nov 30, 2025 at 09:40 PM
gdanmitchell
Details
p.1 #6DxO PureRAW - keep a copy of your original RAW file
Aside from true “missed” (grossly out of focus, terribly bad exposure, accidental shutter button presses while aiming at my left foot) I keep essentially all of my raw files.
Dec 01, 2025 at 09:26 AM
Switch to mobile view
