50s vs 50s ii
weezintrumpete
p.1 #150s vs 50s ii
I have a 50s that I occasionally use with the Mitakon 65mm. I don’t end up using it very much for two reasons… I don’t like the bulk of the body and I have a hard time focusing the lens wide open, which is where I want to use it.
I’m thinking about getting a 50s ii to solve the bulk issue (somewhat) but I’m wondering about the ability to critically manually focus accurately.
I am also considering the Fuji 55 mm 1.7 in the future and my understanding is that it’ll focus much better on the newer body. Is that true?
So basically what I’m wondering here is, is the upgrade worth it considering I’m looking for a reduction and bulk, potentially better manual focusing, and better AF?
Nov 23, 2025 at 06:58 PM
cbass
Details
p.1 #250s vs 50s ii
Short answer no. The 50s II is physically larger and heavier. The viewfinder magnification is 0.77x vs the 0.85x of the 50s.
https://cameradecision.com/compare/Fujifilm-GFX-50S-II-vs-Fujifilm-GFX-50S
Focus peaking, I think uses contrast. There are lenses with low contrast or low micro contrast that will be harder to use with focus peaking while others will just snap into focus and peak easily. The Mitakon may just be a lens that doesn't have much contrast at f/1.4 and thus focus peaking isn't the best.
AF. The 50s II should be faster, but I have never compared them. It will also have IBIS if you care for that. The AF even if faster will not be fast.
Nov 23, 2025 at 09:24 PM
Geoff D F
Details
p.1 #350s vs 50s ii
If you want a smaller camera, I don't think the 50sii is the answer, though i haven't compared it to the 50s. It is a camera you take for a purpose, not just something to bring along. Also the AF is not fast, more like adequate but not for action.
I find it ok for manual focus with focus peaking, but for critical focus with very shallow dof I would want to punch in, so it is going to be slow. While I don't have the 50mm f1.7, focus accuracy seems fine with other native Fuji glass and also Pentax 645 glass via the Fringer pro adapter.
Nov 23, 2025 at 09:56 PM
Steve Spencer
Details
p.1 #450s vs 50s ii
...Show more →
Having the 50S I suspect you have the same issue I have with that body and MF. It isn't the size of the viewfinder that is the problem--the viewfinder feels large to me--it is the way magnification works--at max magnification the image is a bit blurry no matter how sharp the lens is. I am not sure if this is better with the 50s II because I haven't used that body, but maybe someone else can comment on that.
If you want a smaller body, however, you might look into the 50r. It is significantly smaller and that might get you to carry it more. Otherwise it is pretty similar to the 50s. I kind of wish they would make a 100r with IBIS, but Fuji hasn't made that camera and I doubt they will, so the 50r might improve your experience.
Nov 24, 2025 at 07:06 AM
SGinNorcal
Details
p.1 #550s vs 50s ii
...Show more →
That site should be avoided, seems like simple AI full of errors. Contrary to what it says, the 50S with the EVF, battery, and memory card is a tiny bit heavier than the 50SII. Dimensions are similar except for the thickness due to the "big butt" of the 50S. Size wise, these to cameras could be considered about the same. Personally, I would take the nice built-in grip of the S or SII over the minor size and weight savings of the 50R but that's a personal choice. The major improvement of the SII, IMO, is the new style battery common to most other Fuji cameras and IBIS. They have the same AF. I had the 50S and really liked it. The AF didn't really bother me and I used the GF20-35 (doesn't really need stabe) and the GF45-100 which has its own stabilization. I didn't have any adapted lenses back then and didn't use manual focus much. Personally, I don't like MF much except on lenses that are fully manual. AF lenses don't seem to work well in MF mode, I can't explain why, that is simply my observation.
To me, coming from the 50S, the 50SII wasn't enough of an upgrade. I went to the 100S for very little differential cash. The 100S with better battery, IBIS, and AF is noticeably better. IQ is essentially the same with additional crop-ability. The 100S just feels a little more coherent of a package to me, kind of all grown up. I only wish they kept the control layout and d-pad of the 50S. But they are all bargains and we are blessed with such choices.
Edited on Nov 24, 2025 at 11:14 AM · View previous versions
Nov 24, 2025 at 10:52 AM
SGinNorcal
Details
p.1 #650s vs 50s ii
Regardless of which body, I recommend the 55/1.7. I love my adapted lenses but the native 55 is one of my favorite all around Gfx lens. I hear complaints about slow AF and a little hunting but it wins for me with its IQ. To my eyes, it beautifully threads the needle of sharpness vs. character. It gives you incredible resolution without appearing sterile or clinical. Its like the aperture becomes your dial-in of the look you want. I do realize that is the point of fast aperture lenses but the 55 actually delivers a nice slow gradient between razor thin DOF, super deep, and all in between.
Nov 24, 2025 at 11:06 AM
weezintrumpete
Details
p.1 #750s vs 50s ii
Thanks for the replies all!
I should have said that with the 50s, I really don’t like the big “butt” of it that makes it somewhat awkward to carry around on a strap casually. So the 50s ii, even if it’s ultimately the same size, seems like it would be a more casual carry. Not sure if that’s true or not.
It sounds like if I want better AF, I should really go for the 100S. But maybe the move is to go 50s and get the 55/1.7.
Regarding the viewfinder - the 50s is nice and large, but never feels that sharp. I saw a review that said while the viewfinder of the 50s ii is technically inferior (lower magnification, etc), it was actually easier for this guy to manually focus on it due to perceived better sharpness or contrast.
To those with the 55/1.7 and the 50s ii (or the 50s for that matter) - how is the af? Is it reliable enough for a family portrait shoot for posed (mostly still) photos? “Action” shots chasing kids around would be a different camera.
Nov 24, 2025 at 11:42 AM
SGinNorcal
Details
p.1 #850s vs 50s ii
I didn't notice any difference in strap carrying the 50S vs. 100S. I believe the 100S and 50Sii use the same EVF. I agree that despite the specs, I found the 100S/50Sii VF to appear to be clearer in use and that could be helpful with a MF lens.
Re: 55 AF, I think it would absolutely be a great choice for portraits, that's a strong point of this lens. That said, if you are wide open in less than great light, it never hurts to quickly verify your focus on any Gfx lens with high value shots. I'm assuming you want the 55/1.7 for its fast aperture. If you don't care about that and want smaller and cheaper, there's always the GF50/3.5 that can be had for 1/3 the price or less. It might be the fastest and most accurately focusing GF lens and is certainly the smallest. IQ is very good, just won't produce the wonderful out of focus DOF or bokeh of the 1.7.
Nov 24, 2025 at 12:26 PM
weezintrumpete
Details
p.1 #950s vs 50s ii
...Show more →
Thanks. The 55/1.7 would be used 95% of the time wide open for full body portraits.
I'm curious how that lens would autofocus on the 50S. I'm ok with it not being that fast, but I mostly want it to be accurate, to grab focus on faces reliably.
Interesting that you didn't notice any difference in strap carrying with the 50S vs 100S. That bump always knocks into me and being that the 50SII/100S is just like a bigger DSLR, I thought it would be better. Thanks!
Nov 25, 2025 at 12:13 PM
SGinNorcal
Details
p.1 #1050s vs 50s ii
Well I don't have the exact 50S+55mm experience you are looking for but with your intended purpose, I would expect you to be very happy with the 55/1.7.
Nov 25, 2025 at 01:01 PM
weezintrumpete
Details
p.1 #1150s vs 50s ii
Thanks. I think so as well, I'm just a little worried about the AF on the 50S. I've only shot mine with manual focus lenses, and my other work camera is a ZF (which has amazing AF), so I'm a little concerned that I'll be massively disappointed.
What I *really* want is a 65/1.7 AF to give me that 50mm look.
Nov 25, 2025 at 04:01 PM
Joseph.
Details
p.1 #1250s vs 50s ii
If you want reduction in bulk, get an X-T50 or X-E5. I sold all my GFX gear and went back to XF because I couldn't handle all that weight.
Nov 25, 2025 at 06:26 PM
Makten
Details
p.1 #1350s vs 50s ii
I'd get the GF 63/2.8 to start with. It's small, light weight and super sharp. Sure, not the same shallow DOF as the Mitakon, but it waaaay outperforms it at every aperture and IMO gives more "medium format look" thanks to nice rendering and technical superiority.
The main reason to go from 50S to 50S II would be IBIS. Which is a very good reason.
Edit: I think it's easy to get fooled by comparison numbers, because they often tend to leave out the viewfinder of the 50S. Which makes it seem smaller and ligher. IRL they should be very similar.
Nov 29, 2025 at 03:08 AM
zhangyue
Details
p.1 #1450s vs 50s ii
^^^ agree ^^^
IBIS and smaller footprint are more important to me. Definitely prefer 50S viewfinder (tilt-able) but not enough to change the direction.
Nov 29, 2025 at 08:56 AM
ibarrabenjamin
Details
p.1 #1550s vs 50s ii
I did not switch from 50S to 50SII, but from 50R. Titlable screen and the ability to shoot hand-held without hesitation has made a big difference for me. IBIS is really helpful for this type of camera/sensor.
Dec 15, 2025 at 10:29 PM
Switch to mobile view
