Fat roll or light seals?
Geoff D F
p.1 #1Fat roll or light seals?
Shot on my Pentax 645N. Never seen this before but I could have been using a different back to my usual one (I can't remember if I changed them over or not) and the seals look to be missing compared to my other back. On the other hand, it only seems that the light has been leaking in from the left hand side. I'm not sure what a fat roll looks like but, if it were a fat roll, I would not have thought every frame would be affected on the roll and also completely across the frame from top to bottom .
I suppose the other possibility is a mistake at the lab.
000184710004 by Geoff F, on Flickr
000184710007 by Geoff F, on Flickr
000184710011 by Geoff F, on Flickr
Good news is I think I like Portra 400. Bad news is I may have torched a roll of Ektachrome too.
Your diagnoses please?
Nov 19, 2025 at 02:17 AM
retrofocus
Details
p.1 #2Fat roll or light seals?
I have seen something similar even not as severe when using one of the 6x6 backs for my Hasselblad 500 C/M. IMO definitely a light leak - in my case it was caused by missing baffles/seals which a former owner (I bought this film cartridge used) had removed most likely to put them into another back. I ordered the missing parts and replaced them myself. Works fine since!
Nov 19, 2025 at 06:56 AM
Desmolicious
Details
p.1 #3Fat roll or light seals?
Fat rolls are super easy to spot. The roll will not appear to be wound tight and if you squeeze it you will be able to compress it. With a properly tightly wound roll you would not be able to squeeze it.
However, fat rolls would show light leaks on both sides, and only on the last few frames.
This looks like a light leak in camera.
Edited on Nov 19, 2025 at 07:04 PM · View previous versions
Nov 19, 2025 at 02:12 PM
Geoff D F
Details
p.1 #4Fat roll or light seals?
Yeah, I think it must be a light leak. I think it is the only way one could have the whole length of the film fried in this way. That's what you get for buying a mint minus insert from ebay. I'll revert to my old insert and replace the seals on this one.
Expensive mistake having toasted a roll of portra and ektachrome.
Edited on Nov 20, 2025 at 01:33 AM · View previous versions
Nov 19, 2025 at 04:21 PM
Geoff D F
Details
p.1 #5Fat roll or light seals?
Stop the presses. The Ektachrome turned out ok. I must have swapped the dodgy film insert back out.
Gotta love the colours!
Tarago Pub by Geoff F, on Flickr
EK100 Three Sisters by Geoff F, on Flickr
Nov 20, 2025 at 01:11 AM
FM ForumsFilm Is Not Dead ForumJoin Upload & Sell
Switch to mobile view
