How thick is the X-E5 with the 23mm f2 WR?
towlie
p.1 #1How thick is the X-E5 with the 23mm f2 WR?
I'm about to make my final decision between the x-e5 and the x100vi, and I'd like to know how “thick” the E5 is with 23mm f2 WR.
According to web, the x100vi has a depth of +-55mm.
Nov 09, 2025 at 11:40 AM
gdanmitchell
Details
p.1 #2How thick is the X-E5 with the 23mm f2 WR?
There are several websites that let you set up side-by-side comparisons: https://duckduckgo.com/?q=camera+size+comparisons&t=ipad&ia=web
Nov 09, 2025 at 11:59 AM
towlie
Details
p.1 #3How thick is the X-E5 with the 23mm f2 WR?
Unfortunately, I couldn't find the camera lens combination on the comparison websites.
Nov 09, 2025 at 12:39 PM
jstrawman
Details
p.1 #4How thick is the X-E5 with the 23mm f2 WR?
Nov 09, 2025 at 12:49 PM
Yogifi
Details
p.1 #5How thick is the X-E5 with the 23mm f2 WR?
Nov 09, 2025 at 02:26 PM
Nielk Mike
Details
p.1 #6How thick is the X-E5 with the 23mm f2 WR?
The 23f2.8 is not int heir database yet. Use the 27f2.8: https://camerasize.com/compact/#951.388,919,ha,t
Nov 10, 2025 at 01:25 AM
gdanmitchell
Details
p.1 #7How thick is the X-E5 with the 23mm f2 WR?
As Mike points out, the 27mm is a good point of comparison. The 23mm is nearly identical in length and diameter and 12 grams heavier.
27mm f/2.8 specs:
23mm length
62mm diameter
78g
23mm f/2.8 specs:
23mm length
61.8mm diameter
90g
Nov 10, 2025 at 10:00 AM
mdude85
Details
p.1 #8How thick is the X-E5 with the 23mm f2 WR?
The OP asked about the 23 f2 not the 23 f2.8.
As far as I can tell the XE5 with the 23 f2 lens is about 40 mm (1.5 inches) longer than the X100VI.
Nov 10, 2025 at 02:51 PM
gdanmitchell
Details
p.1 #9How thick is the X-E5 with the 23mm f2 WR?
Ah, silly me. I simply assumed — incorrectly — that the OP wanted to know about the new lens that comes bundled with the XE5. Now I see "f/2" right there. . Thanks for catching that.
Nov 10, 2025 at 07:04 PM
Switch to mobile view
