renaming files on a Mac
Imagemaster
p.1 #1renaming files on a Mac
Using Finder > Rename, I want to get a space between the last file number and the .dng file format.
I can do it on an individual file, but not on multiple files.
Suggestions?
Nov 06, 2025 at 10:04 PM
rklee
Details
p.1 #2renaming files on a Mac
I use an app called "A Better Finder Rename 11.app" to make changes file names, and I just tried adding a space before the extension for a group of files and it seems to work. I didn't actually go ahead with the change, but I could see the result in a window. There's a newer version (12) now. I think you can try it out for a few files before purchasing.
Nov 07, 2025 at 12:42 AM
GoodEgg
Details
p.1 #3renaming files on a Mac
Try
instead of Format, use Replace Text.
1 In the 'Find 'field (not visible until you switch from Format to Replace Text), enter ".dng"
2 In the 'Replace with' field (not visible until you switch from Format to Replace Text), enter " .dng" (a space character before the period)
3 Click on the Rename button
I just tested on 63 "screenshot...hh.mm.ssPM.png" files.
Nov 07, 2025 at 12:45 AM
pr4photos
Details
p.1 #4renaming files on a Mac
I'll second 'A Better Finder Rename'. It's so simple to use. I batch rename all the time, and that's what I use. You can definitely set spaces
Nov 07, 2025 at 04:44 AM
Imagemaster
Details
p.1 #5renaming files on a Mac
GoodEgg wrote:
Try
Thanks. I tried that, but it only changed the name of the first file of the 30 that were selected. ??
Nov 07, 2025 at 10:00 AM
mcbroomf
Details
p.1 #6renaming files on a Mac
Imagemaster wrote:
GoodEgg wroteTry
According to his post you need to put just ".dng" in the Find cell. You put the whole file number in there so it only looked for that one.
Nov 07, 2025 at 01:39 PM
Imagemaster
Details
p.1 #7renaming files on a Mac
Thanks everyone.
Tony
Nov 07, 2025 at 03:26 PM
JBPhotog
Details
p.1 #8renaming files on a Mac
MacOS has an application to rename files built in to handle this, it is named Automator. Check YT for tutorials, it's pretty slick and doesn't require third party applications.
Nov 07, 2025 at 06:34 PM
Imagemaster
Details
p.1 #9renaming files on a Mac
As GoodEgg posted, it works with Mac OS Finder:
Nov 07, 2025 at 06:53 PM
schlotz
Details
p.1 #10renaming files on a Mac
Out of curiosity Tony, why the desire for the space before the extension?
Nov 08, 2025 at 05:50 AM
Imagemaster
Details
p.1 #11renaming files on a Mac
Because when I cull through my images individually I have to rename many one by one. With no space there it just makes it harder for me to place the cursor there.
Nov 08, 2025 at 09:05 AM
GoodEgg
Details
p.1 #12renaming files on a Mac
Rename multiple files on Mac the easy way
https://www.cultofmac.com/how-to/batch-rename-files
in case you like to save links
Nov 14, 2025 at 05:05 PM
melcat
Details
p.1 #13renaming files on a Mac
Imagemaster wrote:
schlotz wroteOut of curiosity Tony, why the desire for the space before the extension?
In Finder, click once to select the file name. Then wait long enough for it not to be seen as a doube-click, and click again; this will select the part of the file name before the dot. Now, as with any other selection on macOS, press right-arrow to place the insertion point at the end of the selection and cancel the selection. This leaves the insertion point before the dot.
It’s even easier in Capture One. Click on the file name under the thumbnail, which will hide the dot and extension and select what’s left of the file name. Now press right arrow to turn the selection into an insertion poiint at the end and make your edit. Press return to accept or ESC to discard the edit, and the hidden dot and file name will reappear.
Nov 14, 2025 at 09:35 PM
Imagemaster
Details
p.1 #14renaming files on a Mac
As I already posted above, it is easier and faster to do that with hundreds of files at the same time, instead of one at a time.
I don't use Capture One, and thanks, but others already showed me the more efficient way.
Nov 14, 2025 at 09:43 PM
Switch to mobile view
