fredmiranda.com Login
Half Frames - Samuria X3-ZII, Pen F-FV, Pentax, Canon etc *Add Yours
James Markus
p.1 #1Half Frames - Samuria X3-ZII, Pen F-FV, Pentax, Canon etc *Add Yours
The 1987 camera arrived, and was "near mint", It did require the replacement of an internal battery to set the clock, and to date stamp the film if I choose to - I did not. My dad was right to get excited about this weird camera. The zoom lens is a good effective range 25-75mm approx 35-105mm (full frame equivalent). It is sharp throughout it's entire range. The auto focus is slow, and seems to take two steps - an initial AF, and then a second fine tune. The first roll was 5222-XX 24 exposure which yielded 53 frames. It's was a great match for tones, and contrast. I took about 5-10 minutes to set up the first 48 raw file scans which chugged along while I had dinner (about 40 minutes at 4800 ppi). All the exposures were good - even when the camera decided to use fill flash. (you get no control over this). Looking forward to trying some finer grain film.
The radical SLR horizontal orientation design
Silverfast isn't good for finding frames - so I defined all 48
Outdoors
Forcing some limited DOF
busy high contrast area
Inside and dark area
inside flat light
backlit by a window
Edited on Apr 11, 2026 at 03:53 PM · View previous versions
Aug 09, 2025 at 08:47 PM
Desmolicious
Details
p.1 #2Half Frames - Samuria X3-ZII, Pen F-FV, Pentax, Canon etc *Add Yours
That camera is in amazing shape, and excellent results.
Aug 09, 2025 at 09:59 PM
James Markus
Details
p.1 #3Half Frames - Samuria X3-ZII, Pen F-FV, Pentax, Canon etc *Add Yours
I'm going to put together a short Youtube on how to get into the camera to replace the internal battery. (It was leaking, but caused no damage) There doesn't seem to be any good documentation on the X3, and X4, but there is on the newer Z, and Z2 (there were four models total) The X4 was refined, and has more capabilities than any of the other models, but apparently people didn't like more complicated features. So, Kyocera made the Z and Z2 smaller, lighter, and less capable.
Aug 09, 2025 at 10:13 PM
Details
p.1 #4Half Frames - Samuria X3-ZII, Pen F-FV, Pentax, Canon etc *Add Yours
You should try a left-handed model. I hear they're even better.
Aug 10, 2025 at 04:41 AM
James Markus
Details
p.1 #5Half Frames - Samuria X3-ZII, Pen F-FV, Pentax, Canon etc *Add Yours
Not sure there was a left-handed X3, but definately later models exist. They claim one hand operation, but the manual shows using two hands and the button layout isn't even close to my hand size or finger length.
Aug 10, 2025 at 07:57 AM
James Markus
Details
p.1 #6Half Frames - Samuria X3-ZII, Pen F-FV, Pentax, Canon etc *Add Yours
Samples of the focal length range. I did not move my feet while leaning against a tree, apparently I was listing a bit. It was 95 degrees.
25mm
approximately 50mm
75mm
Aug 10, 2025 at 12:18 PM
James Markus
Details
p.1 #7Half Frames - Samuria X3-ZII, Pen F-FV, Pentax, Canon etc *Add Yours
Reading about the Samuria X4 prompted me to give it a try. On paper there were many improvements, and the two models that followed it (Z & Z2) were dumbed down more and more to satisfy the public. Here are my take-aways between the X3 and X4
Improvements in the X4
-AF is faster
-Low light AF works better, less hunting
-AF has an added confirmation beep
-Fits my hand better
-Strap is more secure than the T handle
-Shutter sounds better (quieter yet sharp)
-Time lapse added
-Flash is more powerful plus a diffuser attachment
-Flash shoe has been added
-Dedicated TTL flash attachment available (CS-140) for even more power & control)
-Focal range is better-25-100mm instead of 25-75mm
-Front thread has increased from 49mm to 52mm (I have more 52mm filters)
-Mirror slap is better dampened
-Film advance is faster
-Night mode with NO FLASH - x3 HAS IT TOO - I missed that
-X4 Focuses closer
side by side
Kyocera-Samurai-X4-Kentmere-100-Used&ReplenishedXtol_1:1-10.5min-72-degrees_SF
Aug 19, 2025 at 09:11 PM
Desmolicious
Details
p.1 #8Half Frames - Samuria X3-ZII, Pen F-FV, Pentax, Canon etc *Add Yours
The X4 has a built in flash AND a hot shoe.
Aug 20, 2025 at 12:51 AM
James Markus
Details
p.1 #9Half Frames - Samuria X3-ZII, Pen F-FV, Pentax, Canon etc *Add Yours
Yes, and the CS-140 dedicated flash has a good feature. To turn it on it tilts back about 15 degrees. This does a couple things since both strobes will fire. One, it will throw light towards the ceiling creating a bounce effect which should minimize the shadow caused by the builtin strobes direct light path. It also extends the range of the flash(s) further out, and extends the lower iso films coverage range. Being TTL it should be getting some feedback to adjust exposure accordingly. Fortunately, the X4 came with a snap on diffuser that fits into the hot shoe, and should make lighting less harsh than the X3. I taped tissue paper over the X3, and that helped. You could just hold a white card over the flash on the X3 angled towards the ceiling a bit to get the same effect as running two strobes on the X4. A lot of thought went into these two cameras.
Aug 20, 2025 at 09:09 AM
freaklikeme
Details
p.1 #10Half Frames - Samuria X3-ZII, Pen F-FV, Pentax, Canon etc *Add Yours
I had zero familiarity with this camera. If I've ever seen one, I'm sure I dismissed it as some sort of strange 8mm experiment. But you got my curiosity up and I didn't want to hit you with obnoxious questions like, "Where does the film go?" So I looked up the manual. Here it is for the curious.
X3 Manual
Sep 16, 2025 at 01:05 AM
James Markus
Details
p.1 #11Half Frames - Samuria X3-ZII, Pen F-FV, Pentax, Canon etc *Add Yours
X3 Manual
I dismissed it when my engineer dad got one in the 1980s. Huss's half frame fetish got me curious about yet another rabbit hole of photography. When I realized it had Zeiss optics, Yashica's practicality, and such an innovative design (plus it was cheap) I just had to see one. My dad was right again. I wish they had continued with more and more user control, but the Japanese public did not want a complicated camera. That drove development for later models.
Sep 16, 2025 at 07:36 AM
Desmolicious
Details
p.1 #12Half Frames - Samuria X3-ZII, Pen F-FV, Pentax, Canon etc *Add Yours
James Markus wrote:
freaklikeme wroteI had zero familiarity with this camera. If I've ever seen one, I'm sure I dismissed it as some sort of strange 8mm experiment. But you got my curiosity up and I didn't want to hit you with obnoxious questions like, "Where does the film go?" So I looked up the manual. Here it is for the curious.
X3 Manual
.. Huss's half frame fetish got me curious about yet another rabbit hole of photography...
Hey! I wouldn't go as far as saying it is a fetish. More of an unhealthy obsession.
Sep 16, 2025 at 06:39 PM
James Markus
Details
p.1 #13Half Frames - Samuria X3-ZII, Pen F-FV, Pentax, Canon etc *Add Yours
Desmolicious wrote:
X3 Manual
Didnt mean to offend. I meant you have brought attention to overlooked cameras and gear, because of your obssesive love of eclectic things. You literally have brought items to my attention that I didnt know about.
Sep 17, 2025 at 06:23 PM
James Markus
Details
p.1 #14Half Frames - Samuria X3-ZII, Pen F-FV, Pentax, Canon etc *Add Yours
Did my first color roll in the Samuria X4 - Portra 160.
Forgot to put away the Hummingbird feeder
Budding Lilac leaves
Mina
Apr 11, 2026 at 03:38 PM
Desmolicious
Details
p.1 #15Half Frames - Samuria X3-ZII, Pen F-FV, Pentax, Canon etc *Add Yours
James Markus wrote:
Desmolicious wrote
X3 Manual
Sorry just saw your comment. I know you meant it in jest
My fetish is in all things film photography. My obsession is with dogs….
Apr 11, 2026 at 06:15 PM
Desmolicious
Details
p.1 #16Half Frames - Samuria X3-ZII, Pen F-FV, Pentax, Canon etc *Add Yours
One of my halfers…. The incomparable Kodak Reto H35. Incomparable because no-one else makes a halfer in this colour:
Apr 11, 2026 at 06:18 PM
Desmolicious
Details
p.1 #17Half Frames - Samuria X3-ZII, Pen F-FV, Pentax, Canon etc *Add Yours
Pics from it:
Apr 11, 2026 at 06:25 PM
ftllens
Details
p.1 #18Half Frames - Samuria X3-ZII, Pen F-FV, Pentax, Canon etc *Add Yours
Oh the color samples look great. I'm going to be hunting for a good copy of the Samurai this month in Japan. I do know the major half-frame models but is there any obscure stuff I should be looking for in case I come across one? I'm trying to frontrun the digi-cam trend cause prices are going to go up right before summer when all the cool kids start snapping them up lol
Apr 12, 2026 at 12:00 AM
James Markus
Details
p.1 #19Half Frames - Samuria X3-ZII, Pen F-FV, Pentax, Canon etc *Add Yours
I think the whole catagory of half frame cameras is "obscure stuff" I keep finding models by different manufacturers that i never knew about.
Apr 12, 2026 at 07:49 AM
bjhurley
Details
p.1 #20Half Frames - Samuria X3-ZII, Pen F-FV, Pentax, Canon etc *Add Yours
I saw an interesting-looking Fuji one (the TW3) and thought about getting it until I saw that it has a non-replaceable, non-chargeable lithium battery. The battery should last for several years but still. It's apparently very easy to replace if you have a soldering iron (which I don't and haven't used one in decades): https://mikeeckman.com/2021/06/fuji-tw-3-1985/
I'm really happy with my Canon Demi EE17, although the light meter died after three rolls so now I use it in manual mode.
Apr 12, 2026 at 08:59 AM
FM ForumsFilm Is Not Dead ForumJoin Upload & Sell
