I've been enjoying shooting with the X100VI for a few days and learned a few tricks that really helped me streamline operation and improved my shooting. If you know some tips or tricks on the menu, please post it here:
Here are two I learned:
1) You can set up a custom button for “View Mode Settings” and choose which settings to toggle, instead of cycling through the four default options. Press and hold the Q button while in View Mode Settings to select your preferred options. I chose to toggle between LCD only and Viewfinder + Eye sensor. This setup works great for those who prefer to shoot with the LCD off and only activate the viewfinder when detected by the eye.
2) Quick format: Turn the camera on and press and hold the Drive/Delete button and the rear dial button simultaneously for about a second. The format option will appear.
My biggest QoL was to put the custom functions on Fn1 since rotating the command ring only cycles through the built in film sims. Putting the C settings on Fn1 allows for fast selection of custom loaded film sims.
RoamingScott wrote: Fred Miranda wroteUnrelated to the X100VI, the X-T5 also has a quick format trick:
Press and hold the Delete button (trashcan icon) and the rear dial button simultaneously for about a second.It's wild how many variations exist across Fuji bodies. The GFX you have to hold trash for 3 seconds, and then click into the wheel.
That you can't add formatting to My Menu is just...what?!
That's a difference between Leica and Fuji. Leica provides very similar software and button functionality across their cameras of the same generation.
Fred Miranda wrote: RoamingScott wroteFred Miranda wroteUnrelated to the X100VI, the X-T5 also has a quick format trick:
That you can't add formatting to My Menu is just...what?!That's a difference between Leica and Fuji. Leica provides very similar software and button functionality across their cameras of the same generation.
Part of the problem with Fuji, as you're seeing, is when they don't give the same physical controls across similar bodies (no rear wheel click on X100 for no good reason).
AZ Photo wrote: RoamingScott wrotePart of the problem with Fuji, as you're seeing, is when they don't give the same physical controls across similar bodies (no rear wheel click on X100 for no good reason).I thought that was for weather resistance
The X-T5/GFX/et al have a clickable wheel and are weather resistant
RoamingScott wrote: AZ Photo wroteRoamingScott wrotePart of the problem with Fuji, as you're seeing, is when they don't give the same physical controls across similar bodies (no rear wheel click on X100 for no good reason).I thought that was for weather resistanceThe X-T5/GFX/et al have a clickable wheel and are weather resistant
There was a rumour that not having the clickable wheel on the X-H2S improved weather resistance - as far as I know FujiFilm haven't published anything either way.
