p.1 #1Do you think the wide-angle and tele conversion lenses for X100VI useful?
I'm on the fence. On one hand, they expand the capacity of the camera. On the other hand, (1) they destroy the compactness of the X100VI, (2) If one brings two extra conversion lenses, why not just bring an interchangeable lens Fuji body with 18/2, 23/2, and 35/2? and (3) 18-23-35 may be too close to each other to be covered by 3 separate lenses.
Mar 05, 2024 at 10:23 AM
RoamingScott
Activity
[X]
Details
p.1 #2Do you think the wide-angle and tele conversion lenses for X100VI useful?
For some of us, the X100 is our only Fuji camera, so in those cases, it could be useful to expand the capabilities of the single body vs buy into MILC Fuji + lenses.
The added size is definitely the worst aspect.
Now that the VI has 40mp, you can feel comfortable using the digital 50mm TC instead of lugging around the converter, but if you want 28mm equiv, there's no other option than the wide converter.
p.1 #3Do you think the wide-angle and tele conversion lenses for X100VI useful?
One could always combine 2 or 3 images in portrait orientation for a wider field of view panorama, but that's not very practical in many situations, especially those where the X100 series was designed for. However, it's something I usually do when only carrying one lens and the scene benefits from a wider view. This technique requires an extra step, but the benefit is also higher resolution.
p.1 #4Do you think the wide-angle and tele conversion lenses for X100VI useful?
I had both with the x100v and think you would be much better with the crop modes on the IV for the tele side. On the wide side not much in the way of options. The WCL adds 37mm of length, 150g/5.3oz to the camera which is more than an XF 18 f/2 116g/4.1oz. So an X-T5 with XF 18 2.0 is 2oz less than VI with WCL.
p.1 #5Do you think the wide-angle and tele conversion lenses for X100VI useful?
When dealing with telephoto capabilities, it can be confusing for many photographers as we need to consider equivalencies. With the 1.4X digital crop, the full-frame "depth of field" equivalence would resemble shooting with a 50mm lens at f/4.
However, when using the optical teleconverter, it's like to using a 50mm f/2.8 lens because the image isn't actually cropped. The X100 has a full-frame focal length and depth of field equivalent to 35mm f/2.8 initially.
With the 2X digital crop (70mm full-frame equivalent), the full-frame depth of field is equivalent to shooting with a 70mm f/5.6 lens. Of course we can combine the optical tele/wide converters with the in-camera crops to make this even more confusing.
By combining the optical teleconverter and the 1.4x digital crop, it's possible to achieve a 72mm f/4 full-frame equivalency in terms of focal length and depth of field. Alternatively, combining the optical teleconverter with the 2X digital crop results in a 100mm f/5.6 full-frame equivalent. Wow, I got a headache!
Mar 05, 2024 at 12:00 PM
RoamingScott
Activity
[X]
Details
p.1 #6Do you think the wide-angle and tele conversion lenses for X100VI useful?
Fred Miranda wrote: RoamingScott wroteFor some of us, the X100 is our only Fuji camera, so in those cases, it could be useful to expand the capabilities of the single body vs buy into MILC Fuji + lenses.
Now that the VI has 40mp, you can feel comfortable using the digital 50mm TC instead of lugging around the converter, but if you want 28mm equiv, there's no other option than the wide converter.One could always combine 2 or 3 images in portrait orientation for a wider field of view panorama, but that's not very practical in many situations, especially those where the X100 series was designed for. However, it's something I usually do when only carrying one lens and the scene benefits from a wider view. This technique requires an extra step, but the benefit is also higher resolution.
I do this frequently when my 24-120 isn't wide enough for a landscape...set to 35 and do a 3+ image stitch. However, if the subject is dynamic, that's a no go.
p.1 #7Do you think the wide-angle and tele conversion lenses for X100VI useful?
I'd love to know from those who use them if they have an effect on IQ. I'd consider the wide angle one, if the image doesn't fall apart. (Speaking as a V owner, not VI.) I can see the argument about just getting a small interchangeable lens camera, but if you're someone who basically always uses just this camera, but occasionally wants wider or longer, it's reasonable to go this route.
p.1 #8Do you think the wide-angle and tele conversion lenses for X100VI useful?
WCL/TCL is for one camera option. You can get away with cropping with higher MP, but WCL is a good option to have. I was looking a little wider option when I traveled with RX1/RX1 II...
I saw 2 comparisons of WCL, sharp as Fuji 18mm f2 and not sharp as Ricoh GR II:
There is also WCL-X70 which gives a little more wider but a little bigger. I don't how it compares with WCL-X100... Also higher MP of XVI will push these to the limits.... Ricoh came out with a bigger wide converter for GR III and that even covers FF Q2/Q3... It is just choosing sharpness over size, similar to lenses...
p.1 #9Do you think the wide-angle and tele conversion lenses for X100VI useful?
The new 40 MP sensor on the X100VI obviates the need for the telephoto converter, but the wide angle converter could still be useful, if, like serhan said, the X100 is your only camera.
Another thing is that an XT or XS body plus the 3 lenses (18/23/35) is about 20% more expensive than an X100V plus 2 conversion lenses.
p.1 #10Do you think the wide-angle and tele conversion lenses for X100VI useful?
I'm interested in the tele-converter lens. I'll hold off in buying it until I get my X100VI and try it out. If the eye-AF tracking technology is pretty good I might rent the TC and try it with one of the tennis coaches here when I hit some balls with her. Bringing my A6700 + 135/1.8 GM is a hit or miss in taking it in a tournament but I'm pretty sure I can get by with the X100VI and TC---not for the stadium but the reduced resolution should be good enough for the secondary tennis courts.
Mar 05, 2024 at 01:19 PM
RoamingScott
Activity
[X]
Details
p.1 #11Do you think the wide-angle and tele conversion lenses for X100VI useful?
You also get the digital TC functionality with the converters, so if you had both, you'd have a choice of 9 prime lengths to shoot at.
p.1 #12Do you think the wide-angle and tele conversion lenses for X100VI useful?
I had them for my x100F because I thought I would need them on a trip to Europe. I rarely pulled them out. They were just too big and ungainly, I thought. When I had it on I would try and keep them on but it seemed like I always needed to take them off. I think maybe out of the 600 pictures I took in Italy, I may have kept 2 or 3 that used the telecon.
I think I got much more enjoyment out of the x100 by training my eye to frame things in a more interesting 35mm way then relying on the converters. Just my preferences.
p.1 #13Do you think the wide-angle and tele conversion lenses for X100VI useful?
I had one or both when I had an early version of the X100 but I didn't like them, they ruined the feel of the camera. If I want a longer or wider lens I will shoot with a mirrorless camera like a Sony a7CII or Fujifilm X-T5. I don't even like big lenses on those cameras much.
