fredmiranda.com Login
This topic is in the 2023 archive. You can read it and like its posts here. It is read only.
Archive 2023Lighter gear options?
Colin F
p.1 #1Lighter gear options?
Since being diagnosed with ALS 2.3 years ago, I haven’t been very active on this forum, but have continued to shoot, and will do so for as long as I can. My progression has been relatively slow, but my balance & walking is getting quite bad, along with overall weakness, and a few other symptoms. It’s a progressive disease, so it will only get worse.
I have the Sony A1; 600 f/4; 200-600; 1.4 TC; 2X TC, and a Tamron 28-75 f/2.8 and Tamron 70-180 f/2.8 which rarely get used, as I mostly target birds.
It had been a while since I had last taken the 600 f/4 out, but I did the last two mornings, and sadly found that it is getting difficult to hand-hold it, as my left arm in particular is getting weaker. This got me wondering if there’s a better option for me what with Nikon’s latest PF lenses and all. *I know that I could use my tripod for BIF, but that is quite limiting & frustrating when you need to quickly turn to the far left or right for an incoming bird whilst seated on a camping stool, which is what I need to use now, as I can’t stand for long periods.
Unfortunately, after looking at all of the combinations and their weights, each option has me giving up something significant, and has me wondering if I should sell the 600/4 and 2X TC, and just use the 200-600, as it does work well with the 1.4 TC.
Any other suggestions, besides hiring a Sherpa - ?
Thanks
PS: I don't do any video; stills only.
https://images20.fotki.net/v1684/filePZ7v/a/8/3978958/15056834/SonyvsNikon.jpg
Edited on Nov 26, 2023 at 10:32 PM · View previous versions
Nov 26, 2023 at 01:11 PM
tsdevine
Details
p.1 #2Lighter gear options?
Have you considered a monopod vs a tripod and gimbal?
Nov 26, 2023 at 01:22 PM
RoamingScott
[X]
Details
p.1 #3Lighter gear options?
I was also going to suggest a monopod for the birding.
Nov 26, 2023 at 01:23 PM
Colin F
Details
p.1 #4Lighter gear options?
^^^ I do have a monopod (used it once years ago and hated it), but perhaps it's worth a try. My fear is that my balance is so bad (even when seated) that the weight of the camera & lens could easily pull me over, and my ability to save myself is almost nil.
Nov 26, 2023 at 01:32 PM
tntcorp1
Details
p.1 #5Lighter gear options?
@ColinF - sorry to hear of your medical condition. i know your were quite active on this forum in the past.
i'm aware this is a sony forum, but you should pm @morris.
he's using the olympus om-1 + nikon 500mm pf with great success. the setup should be lighter with the same reach on a crop sensor.
r/
Nov 26, 2023 at 01:41 PM
berimbolo
[X]
Details
p.1 #6Lighter gear options?
Have you considered making a switch to OM1?
Nov 26, 2023 at 01:43 PM
Colin F
Details
p.1 #7Lighter gear options?
No. What can you tell me about it? (pros & cons).
Nov 26, 2023 at 01:44 PM
AGeoJO
Details
p.1 #8Lighter gear options?
tntcorp1 wrote:
@ColinF@ - sorry to hear of your medical condition. i know your were quite active on this forum in the past.
r/
I believe Morris is using a Fuji XH2S camera and not Olympus with a Nikon PF lens.
Nov 26, 2023 at 01:46 PM
berimbolo
[X]
Details
p.1 #9Lighter gear options?
Colin F wrote:
berimbolo wroteHave you considered making a switch to OM1?
I've never used it, but two of my friends love them (they are brand ambassadors, in fairness). The OM1 + 150-400 F4.5 is a super lightweight combination. I think 50FPS with AF on a 20mp stacked sensor. Very good image stabilization and possibly class leading weather sealing. Definitely much lighter than any full frame combination.
Downsides:
m43 sensor => worse low light performance.
Autofocus is not nearly as good as the A1
20mp -> may not matter as the 150-400 is effectively 300-800mm and it has a built in 1.2x TC.
Nov 26, 2023 at 01:50 PM
mitesh
Details
p.1 #10Lighter gear options?
Hey Colin,
It pains me to hear of your most recent struggles; I know how much both physical fitness and photography have meant to you. If there’s anyone who has the mental and physical strength to fight this disease, you’re the one.
If you’re interested in lighter weight gear that comes close to the level of performance you get from your Sony gear, Olympus is worth a look. I’ve posted a number of images in the Micro 4/3 forum using the OM-1 camera in combination with the 150-400mm 1.25x tc lens. Happy to chat anytime you want.
Nov 26, 2023 at 02:00 PM
1bwana1
Details
p.1 #11Lighter gear options?
I wish you the best in dealing with your condition. I very much understand your need to downsize.
I think that the Nikon PF lenses do offer you a better choice in long light weight lenses. However, this will be offset somewhat by the increased body weights, especially with the Z9. I don't think you will give up anything performance or IQ wise if you make the switch. You will likely have to adjust your workflow in AF however. No big deal in that.
Considering that ALS is a progressive condition, it is likely that the weight savings from switching to the PF lenses is not enough for the long term, and you will be looking for an even smaller system. Have you thought of just moving to a Micro four thirds system in one step. Certainly a less expensive route to take especially if you do just one move.
Really good Black Friday deals right now too!
https://explore.omsystem.com/us/en/
Nov 26, 2023 at 02:19 PM
Colin F
Details
p.1 #12Lighter gear options?
Thanks guys. It would indeed be tough to go from 50MP to 20MP, and worse ISO and AF performance, but certainly worth a look.
Nov 26, 2023 at 02:55 PM
tntcorp1
Details
p.1 #13Lighter gear options?
@AGeoJO - oopsie.. is my memory that bad.. i remembered he had adapted the 500pf on a aps-c system.. 🤔
AGeoJO wrote:
tntcorp1 wrote@ColinF@@@ - sorry to hear of your medical condition. i know your were quite active on this forum in the past.
r/
Nov 26, 2023 at 03:13 PM
tntcorp1
Details
p.1 #14Lighter gear options?
@AGeoJO - yea, you're correct 👍
@morris recent post below!
https://www.fredmiranda.com/forum/topic/1834184
r/
Nov 26, 2023 at 03:19 PM
bs kite
Details
p.1 #15Lighter gear options?
Hi Colin
Good to hear that you are still out there. I have a few suggestions.
>. If the 200-600 and 1.4 work for you, why not stick with them for now?
>. I always say that we nature photographers become so engrossed with the photography/gear that we overlook the most enjoyable part of every outing..... enjoying the nature. And this may be more so with you. Would you have been able to produce the stunning images of nature you are known for..... had you not been fascinated with nature?
>. When I was at my worst with non-hodgkins lymphoma I was very weak. But nature was the last thing I would give up.
One day when I was in a rural field of milkweeds and monarchs, it dawned on me that if I tripped/fell from the thick viney ground cover (vetch) I would not be able to get up. I decided to slowly work my way back to the truck being extra careful with my steps.
After that day my nature outings were limited to natural areas where people were and where the surface was easily traversable. That was 5 years ago. I can walk where I want now but I'll never carry heavy equipment again. My current go-to........
The 500 PF weighs 1450 grams (3.2 pounds)
FTZII weighs 119 grams (4.2 ounces)
Nikon TC 14II = 204 grams (7.2 ounces)
Z8 with battery = 910 grams (2 pounds)
___________
total weight = 2683 grams (5.9 pounds)
A link showing how the 500 PF performs with the TC14II
https://www.fredmiranda.com/forum/topic/1809885/18#16332242
Robert
Edited on Nov 26, 2023 at 04:29 PM · View previous versions
Nov 26, 2023 at 04:09 PM
Craig Gillette
Details
p.1 #16Lighter gear options?
The A7RC (or A6700) and 70-350 might be worth a look.
Nov 26, 2023 at 04:17 PM
1bwana1
Details
p.1 #17Lighter gear options?
I am also a bit on the mobility challenged program these days. I am still able to shoot the A1 200-600 (1.4TC when needed) setup comfortably. In my opinion if you wat to stay FF this is probably your best choice. Bonus, instead of spending money you get a bunch back by selling the 600mm and 2X TC. Spend that on a couple of amazing wildlife adventures while you can still go!
Nov 26, 2023 at 05:19 PM
jowul
Details
p.1 #18Lighter gear options?
Alex Phan started this thread :Sony FE 300mm f/2.8 GM Image Thread
It looks like the A1 with this new lens and a 2 x TC competed quite well probably at a considerably lower weight.
Nov 26, 2023 at 05:39 PM
Maxxus46
Details
p.1 #19Lighter gear options?
Maybe consider a quality Gimbal head? They're very fluid and with some practice you can nail BIF shots while the camera and lense remain light as a feather . Good luck on your decision
...Show more →
Nov 26, 2023 at 05:52 PM
Colin F
Details
p.1 #20Lighter gear options?
Maxxus46 wrote:
Maybe consider a quality Gimbal head? They're very fluid and with some practice you can nail BIF shots while the camera and lens remain light as a feather . Good luck on your decision
Yes, I do have a Wimberley on my tri-pod, it's just that when sitting in front of it, one cannot quickly shoot to the extreme left or right when needed, as you can't get your eye/head behind the viewfinder when you swing the camera over. I will have to give it a try next time I go out to see if those lost shots are few enough not to matter.
Nov 26, 2023 at 06:25 PM
