Alex Phan wrote:
Ripolini wrote
They wrote: If users wish to use multiple E-mount lenses with ETZ21 Pro, when changing lenses, please turn off the camera and then remove ONLY the E-mount lenses originally being mounted on the camera. Removing both the lens and adapter may cause adapter malfunctions.
What happens if I use only one E-mount lens? can I remove both the lens and adapter without causing adapter malfunctions?? Yes you can. Since the adapter so thin, just be gentle with it.
Resurrecting this thread...I have an ETZ21 Pro on the way, and will be comparing it to the Fotodiox...the manual for the ETZ21 appears to basically say never to remove the adapter and lens as a single unit...says always to remove the lens, then remove the adapter, which isn't really a viable field solution.
But you're saying we're good to just leave it on the lens and attach as a unit? Don't want to fry it.
