       2       3       end
Archive 2023 · Camera skins
phinix
p.1 #1 · Camera skins
Do you guys use camera protection skins?
Is it worth using one?
How hard is to apply it and take off if needed?
Would it damage actual body, or leave some glue etc?
I was thinking of buying one for my A7C.
May 05, 2023 at 03:10 AM
InFocus2014
p.1 #2 · Camera skins
I installed Alphagvrd skins on both of my A1’s. I was initially intimidated by the process, but it was easier than I expected - taking an hour and fifteen minutes per camera. I used the skins that match the camera, so the cameras do not look skinned. I couldn’t be happier and highly recommend installing them.
I have also skinned all of my lenses (12). In fact, it is the first thing I do after verifying sharpness/centering when acquiring new lenses.
May 05, 2023 at 06:03 AM
newdom
p.1 #3 · Camera skins
I use skins and screen protectors on all my cameras - it gives me great peace of mind to just get on with using the camera without worrying about wear and tear.
I used the JJC/Kiwifotos one on the A7c and the bottom half is very good but the top half (or rather than top section that is silver on the silver variant) is terrible - huge gaps, so I wouldn't recommend it. I used the JJC/Kiwifotos one on the A7iv and A7iii/A7riii as well and they're OK - they do the job.
I used an Alphagvrd/Life+Guard one on my A7Riv and it was far higher quality - the fit/cut was far better and a thinner (but still strong) material that fits into nooks and crannies better.
The all use 3M material and it comes off in seconds leaving little to no residue. If it does lose reside you can easily take it off with a lens cleaner/cloth.
May 05, 2023 at 07:33 AM
saaketham
p.1 #4 · Camera skins
I would like to apply skins, but it seems like a laborious process, that requires delicate hands.
On my a1, I have been using this silicone case that makes the camera slightly thicker and easier to hold
https://www.bhphotovideo.com/c/product/1637426-REG/ruggard_sg_sa1_sleekguard_for_sony_a1.html
May 05, 2023 at 08:03 AM
007Boarder
p.1 #5 · Camera skins
Here’s most of my line up…needless to say, I watched a lot of YouTube during the hours of applying all of them over a couple of weekends. It wasn’t difficult to install. Just time consuming. Camera was a little tedious. Lenses are really easy honestly. Again, just takes time. The camera, and especially when shooting with the 400 is a huuuge talking ice breaker. So if you don’t want people to comment and talk to you, don’t do it.
At the motogp races is Austin few weeks ago, I was probably stopped every 10-15 minutes to talk about it from people.
May 05, 2023 at 07:13 PM
docusync
p.1 #6 · Camera skins
I used to do the same until last summer when my A1 started overheating under direct sunlight. Now I use the “Arctic White” pattern which is slightly brighter than the 400&600 GM color. It really helps here in TN. The skin doesn’t look seamless anymore, but I don’t care as long as the camera runs cooler. I also re-skinned all my long “outdoor” lenses, so now the focus ring is the only part that’s getting warm.
May 05, 2023 at 07:43 PM
280zAl
p.1 #7 · Camera skins
The bright colors are quite a draw.
May 05, 2023 at 07:51 PM
NonDecaf
p.1 #8 · Camera skins
I'm curious if the skin leaves a residue if you ever would want to sell the camera.
May 05, 2023 at 08:01 PM
AmbientMike
[X]
p.1 #9 · Camera skins
I don't. Just doesn't appeal to me to put stuff on my cameras & lenses.
May 05, 2023 at 08:21 PM
1bwana1
p.1 #10 · Camera skins
I use the Alphagvrd on my Leica M11 to keep the camera finish perfect since that affects the resale value so much. Provides great protection, no residue when removed, and was easy to apply.
May 05, 2023 at 08:23 PM
chez
p.1 #11 · Camera skins
Any way for water or salt making their way under the skins between seams? That would be my main concern…salt has a way of getting into tiny places causing havoc.
May 05, 2023 at 08:24 PM
johnvanr
p.1 #12 · Camera skins
I don’t see the point, unless you’re dealing with the really expensive f/4 lenses. Even then, a lens coat and some gaffer tape works just as well.
May 05, 2023 at 08:27 PM
Douglas L
p.1 #13 · Camera skins
I have Alphagvrd skin on my two A1s, the 200-600, and just received one for my 600GM, haven't had time to put it on the 600 yet as I will need to use the lens tomorrow. Not hard to put them on but need to be careful in placing different pieces on the right places.
May 05, 2023 at 08:32 PM
rjensen11
p.1 #14 · Camera skins
+1 for Alphagvard. If you do a search for Alphagvard coupons, you can usually find one for 15-20% off.
They are quite forgiving. If you make a mistake, you can peel them off and re-do them. If you do that more than once the skin stretches. Just hitting it with a hair dryer for a second or two shrinks it back to shape.
I used the "obsidian black" on my A1 and smaller lenses, and the "urban camo" on my 200-600. However, after seeing the colorful collection on lenses above it is tempting to go that route...
May 05, 2023 at 09:07 PM
1bwana1
p.1 #15 · Camera skins
Although the seams don't appear to be weather proof, or have perfect seals, the skins themselves probably won't allow moisture between them and the body. They are just as waterproof in this way as a class protector on a rear screen. I have never seen that kind of problem with them.
May 05, 2023 at 09:56 PM
guitardirky
p.1 #16 · Camera skins
I have Alphagvrd on my 400 GM to protect against everyday wear and tear and I'd say that it's held up pretty well.
May 06, 2023 at 07:38 AM
Alex Phan
p.1 #17 · Camera skins
negative. Just peel right off.
May 06, 2023 at 11:20 AM
Alex Phan
p.1 #18 · Camera skins
if you order from https://alphagvrd.com, don't forget to use the code "alexphan15" for extra 15% off
May 06, 2023 at 11:22 AM
Alex Phan
p.1 #19 · Camera skins
negative. I have the combo under heavy rain many times and nothing go under.
May 06, 2023 at 11:24 AM
InFocus2014
p.1 #20 · Camera skins
No residue, whatsoever. It is the same 3M brand material that is used in vehicle wraps. I have re-wrapped three of my lenses due to a material design preference and tactile feel of the materials, with no residue when the original wrap was peeled-off. Aside from the Camo designs of my larger lenses, all my other lenses are either wrapped in Shadow Black or Carbon Black (sample shown, below). I like the tactile feel and look of these particular materials.
I do not have the courage to use the 'Sticker Bomb' design that 007Boarder uses.
May 06, 2023 at 01:43 PM
       2       3       end
       2       3       end
