It looks like it's only just out but if anyone tries it could they post how well it works? SAR posts that it can combine exposure bracketing with focus bracketing which the A7R5 can't.
I don't own a cell phone or an ipad so I can't test it. I'd like to use it with an A1 and R4 (if it really works well I might consider getting an ipad).
Thx
Mike
Edited the title to show the name of the App and that it's Mac only
Thx
Mike
Hi Mike,
Thanks for the information and link. It is disappointing that it is only for Iphone and Ipad and has no Android support (at least at this time).
p.1 #4Focus bracketing app (Shutter : for iOS only)
Hi, the app author here. Thank you for bringing my attention to this post.
If you are unsure about Shutter, please note that if you don't like the app, you can very easily request a refund by following these instructions: https://support.apple.com/en-us/HT204084 You can do it no questions asked, but I would be very grateful for feedback through our usual support channels.
As for the Android version, it looks like after this release it's the #1 request from our community. At the same time, it's a TON of work. The current app relies heavily on Apple tools that simply don't work on Android. We've made some preliminary work to connect to the camera from Android device. While promising, it's also crazy scary to commit to such a huge development effort.
I think the focus for year 2023 will be making the iOS app even better - I have lots of ideas here. It's certainly easier to fix & improve than build from scratch. I'd rather have a few very happy users than a lot of somewhat disappointed users.
p.1 #7Focus bracketing app (Shutter : for iOS only)
Shutter will use built in exposure bracketing, but all of focusing happens independently in the app. Therefore you can combine focus + exp bracketing even if the camera doesn't support those two together.
Also, we currently don't list Sony a7R V or FX30 in supported cameras, but rest assured that those devices will work with Shutter. You will have to connect as if you were connecting to the Sony a7 IV and everything should work. I'll work on adding proper a7R V and FX30 instructions ASAP.
Any chance of adding the A7R2 and 3?
Unfortunately, no. Those cameras don't provide enough focus data. As you probably know, the Sony a7R III doesn't even allow "tap to focus".
p.1 #8Focus bracketing app (Shutter : for iOS only)
p.1 #9Focus bracketing app (Shutter : for iOS only)
This looks really interesting, what's the lag with video? I've been using Monitor+ with my a7sIII and a7IV, but sometimes the lag is annoying. Also does touch tracking in video work with this app? I have almost no video of me in the shot with my 11-month old daughter, I want to shoot more video with her going forward. Thanks!
p.1 #10Focus bracketing app (Shutter : for iOS only)
I'm afraid it's going to be more or less the same. Monitor+ developers did a really good job optimizing their app. Two things worth trying:
1) Make sure you use 5 GHz wireless band in camera settings. It increases performance at the cost of range.
2) Disable Bluetooth in iOS Settings app (important to do it in Settings!). It breaks my heart, but iPhones and iPads use the same antenna for Bluetooth and Wi-Fi which can cause some stutter.
p.1 #12Focus bracketing app (Shutter : for iOS only)
gswirski wrote: Earlier quoteSAR posts that it can combine exposure bracketing with focus bracketing which the A7R5 can'tShutter will use built in exposure bracketing, but all of focusing happens independently in the app. Therefore you can combine focus + exp bracketing even if the camera doesn't support those two together.
Earlier quoteAny chance of adding the A7R2 and 3?Unfortunately, no. Those cameras don't provide enough focus data. As you probably know, the Sony a7R III doesn't even allow "tap to focus"....Show more →
Hi Grzegorz,
From your comment regarding the A7rIII not allowing for "tap to focus", am I to understand that the ap will only work with AF and AF lenses? If so, then am I to understand that the ap will not work with manual focus lenses and as an example when a Sony body included such as my A1 or an A7rIV when used as a digital back when used with something like a Cambo Actus camera?
p.1 #13Focus bracketing app (Shutter : for iOS only)
In order for focus bracketing to work, the camera must be able to drive focus. If you have a fully manual lens, it's impossible for any app to change focus -- you need to physically rotate the focusing ring.
In other words, you can use focus bracketing only when your lens is in AF mode, and your camera body is set to MF.
p.1 #15Focus bracketing app (Shutter : for iOS only)
Hi Grzegorz,
Thank you. I was hoping that the ap would allow for doing the focus stacking of images even if they were adjusted manually. I guess this will need to be done then outside of any ap and performed manually through software including Photoshop, Zerene Stacker, and Helicon. Case and point for many applications then for me it would be better to use my Cambo Actus and a Sony body as a digital back whenever possible and to rely on using tilt and swing when appropriate.
p.1 #17Focus bracketing app (Shutter : for iOS only)
I like the idea of this!
I have an iphone 6s plus. I have moved to Android but kept the old iphone that still works as a tiny tablet when connected to wifi. I believe it should work fine as a remote with this app.
To the developer, any limitations on how old the phone or ios needs to be? I am on ios 15.
p.1 #18Focus bracketing app (Shutter : for iOS only)
Do you know of any lens limitations? Sony, 3rd party, SLR or other lenses with Sony mount AF adapters (eg Metabones/Sigma)?
I tried with everything I could get my hands on and it worked. But there are too many lenses out there to test them all. I would recommend giving the app a try, and if some lens that you care about doesn't work just let me know (best to use "Contact Us" button in the app, it's always me replying).
We don't do focus stacking (i.e. combining of pictures) at all. Only bracketing (i.e. taking exposures with different focus distance).
Obligatory iphone snow pic
Thanks for your support! Nice winter wonderland! We only have cold, grey skies and general winter sadness here in Poland.
We require iOS 14.2+ so you are good to go.
I don't expect raising this limit anytime soon. iOS 15 and 16 don't bring any new tools that we would like to use. And even if iOS 17 (still 1 year away) came out with some killer features, we would still need to wait a year or two before enough people switched. So... you get two-three years of updates at minimum, even with your old iPhone.
p.1 #19Focus bracketing app (Shutter : for iOS only)
I just bought the app for use with iPhone 14 pro max and Sony A1. Seems to work well but could really use an owners manual for the app. Or maybe I’m just not intuitive enough to figure somethings out!
