This topic is in the 2022 archive. You can read it and like its posts here. It is read only.
Archive 2022Misaligned aperature ring on my newly purchased 50mm f1.2 GM
edx1105
p.1 #1Misaligned aperature ring on my newly purchased 50mm f1.2 GM
See this image: https://www.dropbox.com/s/w5fpot7bev4fwlk/Photo%20Nov%2004%202022%2C%203%2043%2058%20PM.jpg?dl=0
This is newly purchased from BH.
As a 2000 usd lens, I don't want any compromise.
Not sure if there is anything i can do to fix it, if not I will start a replacement process.
Nov 05, 2022 at 09:36 PM
JustLo
Details
p.1 #2Misaligned aperature ring on my newly purchased 50mm f1.2 GM
Seems pretty nit picky to me. Unless it’s effecting how the aperture is selected I would say that you’d be the only person to know it’s like that.
Nov 06, 2022 at 12:56 AM
QuietOC
Details
p.1 #3Misaligned aperature ring on my newly purchased 50mm f1.2 GM
All the Sony aperture controls are like that. I have the ZA, three G's, and a GM all with vague detents that don't precisely align with markings. They feel even worse. If it bugs you you probably want to avoid Sony lenses. Sigma lenses have more precise detents and markings even on their least expensive lens, but Sigma also doesn't offer the ability to declick. At least Sony seems to do a decent job getting the optics aligned now.
Edited on Nov 06, 2022 at 07:36 AM · View previous versions
Nov 06, 2022 at 04:45 AM
SNJOps
Details
p.1 #4Misaligned aperature ring on my newly purchased 50mm f1.2 GM
I own the 1 G and 4 GM lenses with aperture rings and none of them are out of alignment like in the OP’s photo.
To the OP I suggest sending it back for another copy that is properly aligned.
QuietOC wrote:
All the Sony aperture controls are like that. If it bugs you you probably want to avoid Sony lenses. Sigma does a much better job with how parts fit together even on their least expensive lens. At least Sony seems to do a decent job getting the optics aligned now.
Nov 06, 2022 at 07:11 AM
cwnchkn
Details
p.1 #5Misaligned aperature ring on my newly purchased 50mm f1.2 GM
Is it misaligned at every aperture or just at the "Auto" position? If the latter, maybe it is not an alignment problem but an engraving problem.
Nov 06, 2022 at 07:21 AM
gchappel
Details
p.1 #6Misaligned aperature ring on my newly purchased 50mm f1.2 GM
I checked my own lenses- the detent on my 70-200mm gm2 is"off" a few mm, as are a few others.
I could care less.
If the lens functions properly this is in my opinion a non issue.
A $2000 lens, or a $100000 car will have issues if you look for them.
Go shoot, make art. Worry about the big stuff.
gary
Nov 06, 2022 at 10:07 AM
Gunzorro
Details
p.1 #7Misaligned aperature ring on my newly purchased 50mm f1.2 GM
I agree with posters that say "A" doesn't need to be exactly aligned mark-to-mark. If the apertures don't align, that is a big problem for me, as I usually shoot with manually set aperture priority.
It is too bad the quality control/engineering isn't a little more precise for such an expensive piece of equipment.
Nov 06, 2022 at 10:24 AM
edx1105
Details
p.1 #8Misaligned aperature ring on my newly purchased 50mm f1.2 GM
I own 5 GM lenses and this is the only one that has such obvious misalignment. All other gm lens have a much more acceptable misalignment.
Nov 06, 2022 at 01:06 PM
liggy
Details
p.1 #9Misaligned aperature ring on my newly purchased 50mm f1.2 GM
If it works I wouldn't bother exchanging it. Never really thought to check the alignment and I don't shoot in auto-aperture in any event
Nov 06, 2022 at 01:44 PM
osv2
[X]
Details
p.1 #10Misaligned aperature ring on my newly purchased 50mm f1.2 GM
the detent marker is off by maybe a third of the width of the line?
did you test it for a tilted element or decentering?
Nov 06, 2022 at 03:37 PM
1bwana1
Details
p.1 #11Misaligned aperature ring on my newly purchased 50mm f1.2 GM
I just checked my 3 GM lenses with this type of aperture ring.
70-200 f/2.8 GM II
50 f/1.2 GM
35 f/1.4 GM
None are dead nuts perfect. All are about the same, at about 1/2 as misaligned as what is shown in your picture. That basically keeps the smaller line inside the wider line buy not perfectly centered. They all function perfectly, so all are fine for me.
I hope that information is helpful for you in making your decision.
Nov 06, 2022 at 04:40 PM
InFocus2014
Details
p.1 #12Misaligned aperature ring on my newly purchased 50mm f1.2 GM
70-200 f/2.8 GM II
50 f/1.2 GM
35 f/1.4 GM
I just checked the same three lenses. The 35 and 50 are 1/2 misaligned and the 70-200 is nearly perfect. My Sigma lenses are all perfectly aligned.
I’m really happy to see that there is someone more ‘anal retentive’ than I am.
Nov 06, 2022 at 04:54 PM
KarmaKramer
Details
p.1 #13Misaligned aperature ring on my newly purchased 50mm f1.2 GM
Its all small stuff in here.
I could care less.
gary
Nov 06, 2022 at 08:32 PM
Jesse Evans
Details
p.1 #14Misaligned aperature ring on my newly purchased 50mm f1.2 GM
Send it back for a better aligned one. Resale value will be less with an obvious defect.
Nov 07, 2022 at 12:25 AM
vdo1
Details
p.1 #15Misaligned aperature ring on my newly purchased 50mm f1.2 GM
Save the planet, send it here for environmentally conscious disposal.
Nov 07, 2022 at 07:12 AM
fotografur
Details
p.1 #16Misaligned aperature ring on my newly purchased 50mm f1.2 GM
Tough call. I understand you want it to be perfect, and it should. On the other hand if it's perfect where it counts, centered, sharp and accurate focus I wouldn't want to send it back for an inferior copy, that may also have a misaligned ring.
Nov 07, 2022 at 07:21 AM
AGeoJO
Details
p.1 #17Misaligned aperature ring on my newly purchased 50mm f1.2 GM
Frankly, I didn’t pay any attention to the aperture ring alignment of my lenses until this thread. I just checked all my GM lenses and they all are okay; some are perfectly aligned and some are not 100% but good enough for me to even notice that before.
To the OP, I don’t know whether you use the aperture ring to change your aperture or not but if NOT set on “A”, is the set aperture off as noticeable as on “A” or is it off but not as noticeable as on “A”? Just curious…
Nov 07, 2022 at 08:19 AM
Jochenb
Details
p.1 #18Misaligned aperature ring on my newly purchased 50mm f1.2 GM
People here are sometimes criticized for sending back a decentered lens. So a lens that has an optical flaw...
This tiny misalignment of your aperture ring does nothing to the optical quality.
If it doesn't have any optical flaws I would absolutely keep it. I wouldn't be this nitpicky.
But it's your money in the end...
Nov 07, 2022 at 08:20 AM
Ayoul
Details
p.1 #19Misaligned aperature ring on my newly purchased 50mm f1.2 GM
That's the most nit picky concern ever ^^
A 2000$ lens seems expensive for a lot of photographers, but a GM lens, even at this price, remains a consumer lens, it's not a 15000$ cinema lens and there will be copy to copy variation. In your case, this copy to copy variation is about something purely cosmetical.
So if everything else is perfect (like fotografur said : centered, sharp, accurate focus), you should keep it and don't come back to the lottery for such a silly thing...
But hey, after all, it's your money, if you want to gamble it again, no worries. But if you show us this, it tells me that you're expecting a few comments about it. Mine is this : this concern is silly and you should keep your lens ^^
Seriously, I thing that at worst there will be 1 photographer on 500 that will be concerned by that. It will have zero effect on resale value.
Nov 07, 2022 at 08:28 AM
Erichimedes
Details
p.1 #20Misaligned aperature ring on my newly purchased 50mm f1.2 GM
This is a pretty funny thread. Gold-plated problems to be sure.
But to the OP: does it matter? Not at all. Should you exchange it? Probably, if it's going to bug you every time you use the lens. Though it is a gamble, you may get another one that's the same or worse.
Nov 07, 2022 at 08:52 AM
