Archive 2022 · Desperately seeking tripod ring for old Canon 300mm f/2.8L IS USM
outermagnolian
p.1 #1 · Desperately seeking tripod ring for old Canon 300mm f/2.8L IS USM
I "helped" a friend with limited budget find a fine used 300mm f/2.8. It arrived without the tripod collar and I've searched until my fingers are sore - no luck finding a replacement part.
Seeking suggestions. Posting on the buy/sell forum too.
Jul 04, 2022 at 01:45 PM
armd
p.1 #2 · Desperately seeking tripod ring for old Canon 300mm f/2.8L IS USM
You could try https://uscamera.com/ or any camera repair facility looking for a used collar. I suspect that with covid, a few have folded, so this might be a difficult find. I don't know if you can pull one off another lens and adapt one to fit an old 300?
Sorry, I just checked and it didn't score a hit. The part # is: YG9-0618 and it is unlikely you'll find one easily. I think you might want to look for a lens of similar dimension and try to find a collar which might fit? Another possibility is to reach out to: http://www.hejnarphotostore.com/default.asp. He machines a variety of replacement feet and other parts for lenses though I don't believe he offers tripod rings? I can vouch for the quality of his components and perhaps he can craft something for you? Alternatively, you could reach out to Kirk enterprises? They make some tripod rings though I don't believe they have one for the 300 f/2.8. Best of luck.
Jul 04, 2022 at 02:24 PM
tiggy
p.1 #3 · Desperately seeking tripod ring for old Canon 300mm f/2.8L IS USM
I got one of those (early, non-IS version), and it had the collar, but not the tripod foot. I found this extremely difficult to find, as that earlier model's foot was quite different than the later 300 f/2.8s. I eventually got it sorted, and in the process came into possession of a later model's foot that didn't work for me. So if anyone is looking for a foot, lemme know. I have an extra and am willing to give to a good home. -tig
Jul 05, 2022 at 08:35 PM
nhanzero
p.1 #4 · Desperately seeking tripod ring for old Canon 300mm f/2.8L IS USM
You could try asking Hejnar if he could machine the ring.
Jul 05, 2022 at 09:44 PM
Bill Gass
p.1 #5 · Desperately seeking tripod ring for old Canon 300mm f/2.8L IS USM
I was just going to say that, have a friend or a machine shop make one.
https://www.fredmiranda.com/forum/topic/1735842/0?keyword=collar#15815022
https://www.fredmiranda.com/forum/topic/1730551/0?keyword=collar#15781112
https://www.fredmiranda.com/forum/topic/1730548/0?keyword=collar#15781089
https://www.fredmiranda.com/forum/topic/1729050/0?keyword=collar#15771908
How bout these ?
Some look a little wimpy for that lens but maybe buy a few parts here and there and make one.
Jul 06, 2022 at 08:01 AM
Photonadave
p.1 #6 · Desperately seeking tripod ring for old Canon 300mm f/2.8L IS USM
Here's a wild and crazy idea. Even though this lens is no longer supported by Canon I would give the Canon Parts Order Desk a call at (866) 481-2569 anyway, unless you already tried, and see if by chance they still have one hanging around in their stock somewhere. I see that there is also a lower level parts list for the 14 part numbers with quantities that it is comprised of that may be a longshot if all are still in stock.
Search "Canon EF 300mm f2.8L IS parts catalog".
Hey, nothing ventured nothing gained.
Jul 06, 2022 at 01:28 PM
Choderboy
p.1 #7 · Desperately seeking tripod ring for old Canon 300mm f/2.8L IS USM
5704327786276
That's 'another' part number for it.
While you are searching, I'd measure the lens.
Diameter and width.
Good chance there's another collar that would fit, or fit with a sleeve.
Jul 07, 2022 at 05:54 AM
Mike Sowsun
p.1 #8 · Desperately seeking tripod ring for old Canon 300mm f/2.8L IS USM
I didn’t think that lens had a removable collar but I found a photo of one on ebay.
https://hosting.photobucket.com/images/y17/msowsun/D76A7F71-7A78-4B0B-90B1-EC721FEE4C76.jpeg
Jul 07, 2022 at 06:47 AM
1crazyporsche
p.1 #9 · Desperately seeking tripod ring for old Canon 300mm f/2.8L IS USM
After seeing this thread, thought I'd chime in to give anyone looking for a solution for a long gone discontinued part.
I found this adapter from Amazon https://amzn.to/42rJlcP
It's not a perfect fit as the inner diameter of this is 87mm, the outer diameter of the collar mount is 88mm. With a little dremel magic on the collar i was able to push it past through the 4 screws in the collar mount. Might need to use a pry bar to open the collar up just enough so you could slide it through. A few dabs of oil/lubricant will ease the process. Overall it's rock solid and the best thing is it's already Arca mount.
https://i.imgur.com/QkJYtXm.jpg
https://i.imgur.com/yajyedB.jpg
Note, the lens is already scratched up before i installed the ring.
Hope this helps!
May 10, 2023 at 05:42 PM
